Old 01-19-2009, 09:23 AM   #1
dave6666's Avatar
Default SRT brake upgrade weight
I really wasn't going to do a full blown comparison of my old brake parts to the new brake parts in regards to weight but some have expressed interest in what some of the parts weighed. I may or may not have the individual parts listed you want, but it's the best I can do.
MY OLD BRAKES
Factory stock 2001 with about 32K miles. No weights are corrected to represent un-worn parts like all the new stuff is.
MY NEW BRAKES
SRT calipers with EBC Reds
14" Euroteck front rotors all corners
Big Brakes mounting kit
Big Brakes e-brake kit
Big Brakes SS hose kit all corners
Big Brakes spare tire adapter
WEIGHT OF ROTORS
-> OE rear (pr) 29.8 lbs.
-> OE front (pr) 43.4 lbs.
-> Euroteck (ea) 17.8 lbs.
Net change is minus 2 pounds.
WEIGHT OF BIG BRAKES PARTS
Everything was already bolted on the car when this weight program got started so I had to reverse engineer the weight as a bulk lot of parts. It's accurate enough for this exercise.
24.9 pounds of Big Brakes stuff includes:
-> Caliper brackets
-> E-brake kit
-> Hoses
-> All hardware
Subtract from that this stuff that was removed from the car:
-> The old rear caliper mounting lugs that were sawed off the rear hubs (both sides) 16.3 oz.
-> OE nuts and bolts etc. 46.5 oz.
-> OE rear caliper brackets (pr) 75.6 oz.
Net change is add 16.25 pounds.
WEIGHT OF CALIPERS
-> OE rear with pads/hose but not bracket (included in list above) (ea) 7.8 lbs.
-> OE front with pads/pins/hose (ea) 9 lbs ea.
-> SRT with pads/pins but not hose (included in list above) (ea) 10.4 lbs.
Net change is add 8 pounds.
SUMMARY
Add the red and the green numbers together and it is 22.25 pounds added to car.
Realistically though that number is a little high because...
-> My old OE parts are worn rotors and pads. New will weigh more for sure.
-> When I reverse engineered the Big Brakes stuff I used the FedEx tracking declared package weights (they round up) and then subtracted 2 pounds for packaging. So my 24.9 pounds for all of that may be a few pounds high.
Bottom line is somewhere around 15 to 20 pounds added to car.
OTHER STUFF
I bought the Big Brakes spare tire adapter and it weighs 3.5 pounds.
Old 01-19-2009, 02:53 PM   #2
ViperJohn
Virginia/Maryland VCA President
ViperJohn's Avatar
Default Re: SRT brake upgrade weight
Thanks for taking the time to add all this up.
Just curious how the ride feels? Between the wheels, tires and brakes you have increased your unsprung weight. Notice any differences in ride quality?
ViperJohn is offline   Reply With Quote
Old 01-19-2009, 04:43 PM   #3
dave6666's Avatar
The ride is actually much smoother now. Everything I've read about the Pilot Sport versus the PS2 would suggest that. Less groove tracking, less vibration etc. I am not however impressed that the PS2's have that much more grip than my Pilot Sports. Taking off from some slight inclines still gave me some occasional tire spin at 70 degrees ambient with my now equivalent gear ratio of 2.92.
And anyone that says my Pilot Sports were old and hard for whatever reason they would want to do that, I'll make a fool of you just for trying. Because if I'm good enough to predict someone would say that, I'm damn sure good enough to smear it in your face.
Old 01-20-2009, 11:52 AM   #4
ViperJohn
ViperJohn's Avatar
Where you Pilot sports you changed the original set that came with the car?
Old 01-20-2009, 11:59 AM   #5
dave6666's Avatar
No. They were about 2-1/2 years old. I think I got the last set Michelin made.
Old 01-20-2009, 02:00 PM   #6
ViperJohn
ViperJohn's Avatar
That's probably why you aren't noticing any traction difference. When I changed mine this past spring, I was replacing the original Pilot Sports. The difference in acceleration was astounding. The care had a completely different feel under full throttle acceleration.
40MM Rear Brake Upgrade from Tom & Big Brake Dave Special Dave's Big Brakes New Products and Supplier Specials 0 01-20-2007 07:17 PM
anyone looking to upgrade to the BIG BRAKE KIT??? venomblue550 RT/10 and GTS Discussions 1 07-03-2006 06:01 AM
Best brake upgrade for Gen 1 ? Yves Performance Modifications 9 11-15-2003 08:09 PM
Brake upgrade. So many which one should I go for? Duce RT/10 and GTS Discussions 14 01-06-2003 04:03 PM
Who should i consider for a brake upgrade? Vip-RT10 Archive Management 4 05-17-2001 11:02 PM
