Going to get a spare set of half shafts for the car as a "just in case".
![]() So, whats considered a decent price for a used (but in VERY nice condition) set of 02 half shafts? Also, is there a differance between the different years of shafts? I know date code will be different but???? ![]() One last question. I remember reading of a place where you could get replacement straps at like $5.00 a set. Did a search but could not find the place. Anyone know? Thanks! Robert
What goes vroom....crunch? Me running over Chad's slow red Viper! |
I bought a used very good set off of a rolled 04 with low mileage. Paid $750 for the pair. Don't know if that's a good price though.
2006 Supercharged First Edition 2008 Viper Bright Blue Roadster Keep building the Viper!!! |
#3 | |
The place I get joints and straps from for dirt cheap is shaftmasters dot com. The Spicer part numbers are 5-799X for the joint and 3-70-28X on the strap kits.
#4 | |
![]() ![]() ![]() Last edited by TCurtner; 07-01-2009 at 08:36 AM. Reason: ! |
dave6666, I believe you are correct, the SRT half shafts don't fit the Gen 1 & 2's but I offered up the price just for comparison.
Tcurtner, I believe the Wizard posted something about a right rear click on 08s. You can do a search. The problem that he's seen on several 08s is a loose 13mm bolt over the right rear tire undet the inner fender apron. Remove tire and screws to rear part of apron. Pull apron back, you should see the bolts above center of tire. Check them to see if they are tight. Mine were although I still have a clicking sound when my top is up on my 08 Vert. I think its the top though.
#7 | |
#8 | |
replace with a better product all together like the HD shafts from unitrax. is just not worth it if you broke a set already. a lot of BAD can come of a busted half shaft at speed.
#10 | |
I have been running them for a year now.
RON; 2001 Viper GTS-10 lb Roe-541 HRE's, 1970 Road Runner HT,1970 Road Runner vert, 2006 Charger Daytona Top Banana #88, 1998 Durango, 2005 Ram SRT 10- Yellow Fever #247 |
Primary here was torsion failure of the shaft tube. This shortened the assembly, causing the male splined joint to pull out of the socket. Too much force over too small a spline contact area caused the female end to fracture.
'96 GTS - EMI Penske 3-ways, Aeroquip brake lines, Porsche brake deflectors, S.T. front slots, Tom's 40mm calipers, HMS CF airbox, oil pan baffles, aluminum flywheel, rear X-pipe, '71 GTX exhaust tips. 414/452, 11.88/123.0 best et/mph |
Yes, that is exacly what took place after the hop hop hop off the start line!
![]() There was also a big crunch sound! ![]() ![]()
So let me get this straight....the male's joint came out of the socket and fractured the female, I bet she is pissed!
She was none too happy!
Made alot of strange noises all the way back to the pits! ![]()
#15 | |
2001 RT/10 Sapphire Blue, one of very few!
![]() ![]() It would seem! ![]()
I have bought several from Flea bay. If they are about 70-80 bucks, its a good price. (per shaft)
750 bucks for 2 half shafts????? They better be HD or you got raped.
1993 RT/10 "Blown and Bottle fed" |
Wonderful! Thank you Sir!
| looking for used half shafts | charmer006 | RT/10 and GTS Discussions | 4 | 05-04-2005 07:05 PM |
| Anyone Need Some Half Shafts? | BigCarrot | RT/10 and GTS Discussions | 33 | 02-01-2005 05:52 AM |
| Looking for half-shafts for 800+ HP | FLX109 | RT/10 and GTS Discussions | 4 | 12-18-2004 02:53 PM |
| Help - Half shafts... | rgavitt2002 | RT/10 and GTS Discussions | 2 | 05-16-2004 01:16 PM |
| Half Shafts | kowalski vanishing point | RT/10 and GTS Discussions | 5 | 11-07-2001 08:00 AM |
