Old 09-24-2009, 06:44 PM   #61
mbccenter
MN VCA Member
Site Sponsor
mbccenter's Avatar
Default Re: Roe Supercharger
Originally Posted by KNG SNKE View Post
Ok went to finish my last steps prior to supercharger, install my wideband and finish mounting my gauge. Had a bad viper day today.
I pulled off the drivers turnout to have the wideband mounted, no problem. Go to put it back on, no problem. Go to reattach exhaust hanger and snap a damn bolt. Problem number 1.
I have my turnout butt clamped to straight pipes. Well I could not get them back clamped together without it massively leaking. So now I have to wait for 2 more butt clamps. I am going to head to the local exhaust shop next to my house to see how much they would want to either make me longer straight pipes with a flared end or to put flanges on the ends so I can just bolt new things in there.
The band clamps are one time use.
M&M Performance Headers
Viper owners producing the best Viper headers.
mbccenter is offline   Reply With Quote
Old 09-24-2009, 06:47 PM   #62
KNG SNKE
Virginia Maryland VCA Member
KNG SNKE's Avatar
I did not know that. Makes sense. This frustration is leaning me towards contacting you sooner even though I'm not ready for that step.
KNG SNKE is offline   Reply With Quote
Old 09-24-2009, 06:50 PM   #63
EllowViper
Central Florida VCA Member
EllowViper's Avatar
Be patient. I was over last night and checked out his project. BEAUTIFUL Snake and he's doing all the right things very methodically. No hurry...no worry. Love that annodized black blower with the Yellow powdercoated tubes. It will be a thing of artwork once installed. Love the AEM wideband too. Makes my Innovate look cheap. I'll be back in the area mid-October...might actually drive up from Tampa this time with my "Twinkie" Viper. LOL.
2001 Race Yellow GTS, Unknown PSI Kenne Bell/ROE
Old 09-24-2009, 06:58 PM   #64
KNG SNKE
KNG SNKE's Avatar
Hey by that time I might be close to installing this supercharger .
Just kidding I want this thing installed soon.
Old 09-24-2009, 09:56 PM   #65
1TONY1
GA VCA Member
1TONY1's Avatar
I reuse band clamps all the time......preferably on the same joint. If one is not sealing correctly take aluminum foil and fold it over four or five times and put it over the joint / under the clamp.
From what I gather....you have a true butt joint. If so that's not a good way no matter what you do. Get a longer pipe flared and do it correctly. I have seen band clamp instrutions that even say they are not made for a butt joint.
CPE Twin Turbo !!!! My old set-up: 1996 Roe supercharged GTS: 9.28 @ 151mph with nitrous / 9.68 @ 144mph no nitrous
Dealer-installer for CPE turbos and Roe s/c's
Old 09-25-2009, 03:32 AM   #66
KNG SNKE
KNG SNKE's Avatar
Sorry they are butt joint clamps. Might try the aluminum foil thing today. It wont be set up this way for long since I will have headers with long tube turnouts in my near future.
Old 09-25-2009, 04:50 PM   #67
KNG SNKE
KNG SNKE's Avatar
You my friend are the reason why I am a VCA member. That is great advice. I am normally good about thinking out of the box but that never came to mind. Worked like a champ!!
Todays update is VEC soldered in and wiring cleaned up, AEM UEGO up and running, just need to grab some 3m tape to hold the pod down, and exhaust leak has been fixed. Last step before supercharger is wire AEM gauge into the VEC which will take about 5 minutes, 3m tape the gauge pod, and pick up a new exhaust hanger bolt. Pretty sure local hardware store will have one.
Old 09-27-2009, 10:32 AM   #68
KNG SNKE
KNG SNKE's Avatar
Front of the car is on jack stands and my garage has been cleaned out and lined with supercharger parts. I plan on starting either later tonight or this week and take it nice and slow. Will need my friend to help with the pinning of the crank but I believe that will be my only issue. I am leaving the hood on only because I have no where to leave it off at and I can't remove by myself.
Old 09-27-2009, 05:48 PM   #69
KNG SNKE
KNG SNKE's Avatar
Moving right along. Called it a night but no big issues as of yet.
Manifold off, heads cleaned and taped off, manifold stripped.
Old 09-27-2009, 07:11 PM   #70
RTTTTed
Western Canada VCA Member
RTTTTed's Avatar
Seeing that aluminium inside of the intake gaskets make my grinder hand twitchy. If you lived close I'd port your heads for cheap. Oh well, I'd offer to sell you my Belanger headers if you lived close as well.
Anyway, parts are nice and clean looking. If you want to recoup some of your supercharger expense the intake manifold is a used piece in high-demand. Lookin' good so far.
Ted
Roe SC'd 01 Sapphire GTS, M2 built 720rwhp.
2000 ACR. Paxton/Nitrous 600-802rwhp for sale
Rest-mod 440 Duster 4sale,TDs, Stealth TTs, IROC R/Ts
Old 09-27-2009, 07:17 PM   #71
looking good.
Old 09-27-2009, 07:46 PM   #72
KNG SNKE
KNG SNKE's Avatar
Was pretty clean. I cleaned up the heads and taped them off, then sprayed out the dirt and dust with an air hose. I did have a slight bit of oil come out of cylinder 9 and 10 but I doubt that is anything to worry about.
I would love a set of Belanger headers but I am tapped out dry for a long time. My navy bonus is covering the expensive of the supercharger. Most likely when I decide to get a set of headers I will go with M&M. Price is right and he includes turnouts.
Old 09-27-2009, 07:57 PM   #73
RTTTTed
RTTTTed's Avatar
The problem selling my headers to you would also be the shipping. With all the fuel taxes, green fees, it would be cheaper to buy a set of headers close to you. I think I paid over $150 for shipping from there.
If your 9 & 10 plugs run black/dark/fat after the Supercharger is set up remember that the Vec will allow individual cyliner fuel trims.
Ted
Old 09-28-2009, 06:45 PM   #74
KNG SNKE
KNG SNKE's Avatar
Day 2 of the install. Today was not as productive as yesterday, small issues. Installed the coil spacer in the rear of the motor. Removed the thermostat housing to install 170 degree thermostat, what a pain that was. I used a putty knife and goof off to remove the gasket then hit it with 1000 grit to polish it right up and reattached. That took a long time.
On a positive but negative note, noticed something. My valve covers have been removed before. My passenger side valve cover has a bolt that is half way un-threaded and it seems to be cross threaded. No oil leaking there but someone has been in there. Might have rockers done since my car came slightly modified. Will find out on Thursday.
Tomorrow I have duty so no progress then but Wednesday I will be hitting it hard and hopefully Thursday I will be touching up all the loose ends.
Old 09-28-2009, 07:58 PM   #75
pics or ban !!!
Old 09-28-2009, 08:09 PM   #76
BOTTLEFED
ID VCA Member
BOTTLEFED's Avatar
I took the time to go through and clean up the threads on the heads with a tap. Almost every bolt on the heads has the same thread pitch - valve cover, intake manifold, exhaust header, etc.
97GTS B&W: Roe S/C 6.5#, VEC3, custom W/M, Borla headers and catless exhaust, smooth tubes and K&Ns, JM stg3 heads, 1.7 Arrow RR, 3.55 gears, Fidanza, B&M sst, 661hp/683tq
Old 09-28-2009, 08:14 PM   #77
dodgefever
Virginia/maryland VCA Member
dodgefever's Avatar
John, will this be ready for a cruise on October 17? I'm working on a Colonial Parkway/Williamsburg Winery cruise. You have 3 more weeks!!
'99 GTS, Silver, Connolly leather, Random Tech exhaust. 3.55 gears, B&M short shifter. Poly suspension. T&D Roller Rockers, Aluminum flywheel. 441 RWHP before exhaust install. Drilled and slotted 2 piece rotors. Driven and enjoyed 80,100 miles
dodgefever is offline   Reply With Quote
Old 09-28-2009, 08:22 PM   #78
KNG SNKE
KNG SNKE's Avatar
No pics for today, looks the same as the photos posted yesterday.
Tom, the goal is Thursday to be done. The rest of the install is fairly straight forward. Just a slow section with the stupid gasket.
Old 09-29-2009, 08:32 PM   #79
BAD68GTO
Good thread, I did my Roe and VEC 2 myself and it took me 3 full days.... I could do it in two now, but that time included the soldering and crank pinning and different injectors and such. Never dynoed it, but I do my own tuning and would love to get mine on the dyno.
BAD68GTO is offline   Reply With Quote
Old 09-30-2009, 07:39 PM   #80
KNG SNKE
KNG SNKE's Avatar
Getting closer
(Don't say anything about the valve covers, will be done after the car is up and running)
Old 10-01-2009, 06:05 AM   #81
Red Snake
Gateway VCA Member
Red Snake's Avatar
Lookin good!!!!!
97 GTS Red/Black Stripes - Roe S/C
De Oppresso Liber
Red Snake is offline   Reply With Quote
Old 10-01-2009, 02:25 PM   #82
KNG SNKE
KNG SNKE's Avatar
DONE!!! Well kinda. Cosmetic work left. Car started right up, drives solid all the way through the power band. There is plenty more HP to be gained since it is running between 10 and 10.5 at WOT but it feels solid so I probably won't mess with it. I also left the OEM spark plugs in. I have read a lot about this setup and a lot of folks who drive normally with the occasional stomp the gas said the OEM plugs work fine and so far so good.
Now before the photos are posted I don't need any McViper or McSupercharger jokes because it does look like a McDonalds icon lol.
Also if anyone out there is upgrading their throttle bodies and want smooth tubes for them I have a black set for trade for your black ones. Even swap. The inside diameter of these smooth tubes measures 74mm roughly so I believe they are for 70mm TB's.
Old 10-01-2009, 02:49 PM   #83
Red Snake
Gateway VCA Member
Red Snake's Avatar
Welcome to the Roe club.
It's a blast, ain't it?
De Oppresso Liber
Old 10-01-2009, 02:52 PM   #84
KNG SNKE
KNG SNKE's Avatar
Can't stop smiling. Will smile bigger when everything matches.
Old 10-01-2009, 02:52 PM   #85
FATHERFORD
FATHERFORD's Avatar
you need some red rims.
Old 10-01-2009, 02:56 PM   #86
VIPER BAZ UK
UK VCA Member
VIPER BAZ UK's Avatar
LOOKING GOOD!!!!!!!!!!
Well done its a fun build.....
Support Tators
10lb Roe running SCT remap 743hp ..Thanks to
DC Performance, Inc
Old 10-01-2009, 03:07 PM   #87
Red Snake
Gateway VCA Member
Red Snake's Avatar
Are you doing black or yellow valve covers????
De Oppresso Liber
Old 10-01-2009, 03:22 PM   #88
KNG SNKE
KNG SNKE's Avatar
Yellow with black lettering. Black smooth tubes as well. If I can't trade these 70mm smooth tubes off I will just buy a set.
Old 10-01-2009, 03:29 PM   #89
VIPER BAZ UK
UK VCA Member
Dont forget your PS vent tube.......
Support Tators
DC Performance, Inc
Old 10-01-2009, 03:48 PM   #90
way to go !!!
Supercharger LIRacer RT/10 and GTS Discussions 29 01-17-2010 05:40 AM
gen 1 supercharger??? maxdaddy RT/10 and GTS Discussions 11 01-15-2008 02:03 AM
Some Help on NOS in the UK or perhaps S/R Supercharger Paul S Lacey RT/10 and GTS Discussions 10 11-15-2002 05:40 AM
supercharger yea or nea??? Dr Roof RT/10 and GTS Discussions 9 01-27-2002 11:15 PM
DIY Supercharger?? GO 4LO RT/10 and GTS Discussions 28 08-16-2001 01:44 PM
