Old 10-14-2009, 01:59 PM   #1
AviP
AviP's Avatar
Default Locking and unlocking the GTS
I saw a lot of key fob threads lately and here's mine finally. For more than a decade, my Viper key fob has given me a nervous breakdown everytime I need to use it. Either it will give me a hard time locking or a hard time unlocking. To be specific, while standing within 5 feet of the car, I can get the car to lock/unlock only about 5% of the time on the first attempt. Lately it will not lock the car. What gives? A decade too late but I'm hoping someone can clue me in.
I have done all of the following:
- Key fob batteries: they always have well over the 3V charge needed.
- Key fob terminals: I have cleaned the inside of these terminals (circuit under the buttons) with alcohol.
- I have always pointed right at the car but pointing underneath seems to work better.
- Car battery is brand new currently.
Where is the alarm/IR sensor? Do I need to clean it? Did I pick up something on it years ago, that never got cleaned (not that I clean the car much anyways)? I have the service manual but it doesn't cover the alarm.
-Avi
Cars: 97 Viper GTS B/W, 01 PT Cruiser
Bikes: 99 YZF R1, 00 R1100 RT
Trucks: 07 Ram 1500 Hemi Mega cab
Old 10-14-2009, 02:32 PM   #2
Steve-Indy
IN/KY VCA Member
Default Re: Locking and unlocking the GTS
Suggest you look for posts on this by Ron. He wrote the key fob reprogramming instructions in the upgrade section.
Old 10-14-2009, 03:05 PM   #3
DarcShadow
Have you adjusted the spring that pushes against the batteries? I've had mine stop working and all I have to do is crack it upen, bend the spring/prongs up a little and it works like a champ. You said you cleaned the button contacts, you might also try cleaning the battery contacts as well.
DarcShadow is offline   Reply With Quote
Old 10-14-2009, 04:22 PM   #4
Sweet Ride
AZ VCA Member
Sweet Ride's Avatar
I clean the contacts from time time and that usually clears up any problems I have. Do you have two remotes or just one? If one works and the other doesn't, I would say it's a remote circuit board issue.
Red/Black 97 GTS. Paxton Blower, Corsa Cat-Back, Unitrax Shafts, 3.73 Gears, MGW Gripper, Ported TB's, AB's Wires, Woodhouse Mounts.
Sweet Ride is offline   Reply With Quote
Old 10-14-2009, 05:30 PM   #5
eucharistos
Originally Posted by DarcShadow View Post
Have you adjusted the spring that pushes against the batteries? .
good point, wonder if the right battery also (thickness)
eucharistos is offline   Reply With Quote
Old 10-16-2009, 07:42 PM   #6
AviP
AviP's Avatar
Battery thickness is good. Battery contacts have been cleaned. I'll check the spring that pushes into the battery and let you know.
Does anyone know where the IR sensor is on the car?
-Avi
Old 10-17-2009, 05:24 PM   #7
AZTVR
AZTVR's Avatar
The fob is an RF transmitter (at least on my '02); so, there shouldn't be anything to clean at the receiver. (If there is something that looks like an LED or dark plastic bubble on your fob, then it is likely IR. I am not familiar with older Viper configurations.)
Jim
2002 GTS ACR Graphite Gray w/silver stripes
Old 10-17-2009, 05:33 PM   #8
Asp Man
Western Canada VCA Member
Asp Man's Avatar
They are all RF day one to present. The batt may have 3V, but does it have that under load? ie: when the button is depressed.
Could try a new remote, but I'd still suspect the battery first. The reciever is the EECM itself, as it is RF it does not need line-of-sight to work properly. Could try disconecting the box, three connectors, and recon., see if that helps.
Good luck with this, speaking from experience here.
VP/Membership Director
Western Canada Region
Asp Man is offline   Reply With Quote
Old 10-19-2009, 05:00 PM   #9
99VPRGTS
When I bought my Viper, I had the old style key fob. I got two new ones and followed this programming/re-programming method and they have worked great since then.
Key Fob Programming (Gen I/II) - Viper Alley - Dodge Viper Forum
99VPRGTS is offline   Reply With Quote
Old 10-26-2009, 06:38 AM   #10
Isn't there an antenna wire off of the EECM? That if installed incorrectly or missing or ??? could be a problem?
Tags
alarm sensor, key fob, unlocking
Gen II GTS locking gas cap??? 96GTSBW RT/10 and GTS Discussions 4 05-09-2009 05:23 AM
Locking gas cap??? dano RT/10 and GTS Discussions 11 11-23-2007 10:18 AM
unlocking viper? Leslie RT/10 and GTS Discussions 5 07-05-2005 05:21 PM
GTS Locking Gas Cap??? Steve-Indy RT/10 and GTS Discussions 3 11-20-2001 01:21 PM
Need help on GTS locking gas cap viperdrummer Archive Management 4 07-05-2001 10:06 AM
