Old 02-06-2010, 06:44 PM   #1
bushido
Default Short ratio gears with 3:54s? Or 3:33s?
I plan on doing close ratio gears ( 5th and 6th ). At the moment my car has 3:54 rear gears & Tru-Trac differential, and my car is putting down 600rwhp.A head/cam 97 GTS. So would it be a good idea to change out the 3:54s for 3:33s? Thanks
bushido is offline   Reply With Quote
Old 02-06-2010, 06:50 PM   #2
bushido
Default Re: Short ratio gears with 3:54s? Or 3:33s?
I'm currently rolling on 19inch wheels.Tire size is 345/30/19s..
Old 02-06-2010, 11:11 PM   #3
PhoenixGTS
Then I would say definitely 3.55 if not 3.73 (perhaps 3.73 if you have a raised rev-limiter). The taller Gen III size rear tires effectively turn a 3.55 in a Gen II into 3.33 gearing, and 3.73 with the tall tires is effectively a 3.55 on a Gen II. I say don't be afraid of short gears unless you do a lot of drag racing and you calculate that that big power car of yours will run out of top end in 4th gear in the quarter mile.
That is a lot of power for just heads/cam etc. Can you describe your set-up?
Old 02-07-2010, 07:56 AM   #4
Mopar Boy
VCA member
Mopar Boy's Avatar
I run 3.73 with the 20" rim so I am equal to a 3.45. I like it. Seems about right. Does rev a little higher on the freeway but for more of the speed limits around here are 60 MPH anyways so....
Not sure you would like a 3.73 on your car...too low.
What goes vroom....crunch? Me running over Chad's slow red Viper!
Mopar Boy is offline   Reply With Quote
Old 02-07-2010, 04:04 PM   #5
bushido
On my setup I have JM stage 3 ported heads ( milled for higher compression 10:5to1)LSM Cam, Ported intake manifold, American Racing 5-into-1 stepped headers,no cats, Borla exhaust system, and Crower 1.7 RRs.Last, Exotic Engine valve cover breather system. All done, and tuned by DC Performance. Stock PCM + Stock fuel system..
Old 02-08-2010, 06:46 AM   #6
2001 GTS
Yo Bushido!
I'm running the 3.55s with my 19s as well and think they are perfect man!
Old 02-08-2010, 06:49 AM   #7
Simms
Simms's Avatar
Did you ask Dan Cragin his thoughts?
96 GTS - M2 Twin Turbo
Built and tuned by Macedo Motorsports
Simms is offline   Reply With Quote
Old 02-08-2010, 07:14 AM   #8
SquadX
I have 355 and will be switching back to stock. In 5th at redline I am at 148mph. sucks.
SquadX is offline   Reply With Quote
Old 02-08-2010, 05:25 PM   #9
Brake Dust
Brake Dust's Avatar
HOW ABOUT 6TH
Brake Dust is offline   Reply With Quote
Old 02-08-2010, 08:38 PM   #10
PhoenixGTS
I'm thinking there is some clutch slippage at play there. Before all the good gear calulators disappeared I calculated my 3.55 car with a 0.64:1 6th and Gen II height rear tires as theoretically capable of right at 200 mph at 6,200 rpm (not enough power to really get there) which I believe would put me at 160 at fuel cut-off in 5th.
Old 02-08-2010, 09:09 PM   #11
Burntrubber
AZ VCA Member
something might be up, should be 165mph @5500rpm in a stock GTS w/ 3.55s
Burntrubber is offline   Reply With Quote
Readings on 3.55 gears vs stock gears Viper44 RT/10 and GTS Discussions 8 11-09-2007 07:54 PM
3.33 gears vs. 3.55 gears, Gen I Vipers??? 00prowler RT/10 and GTS Discussions 19 10-10-2002 02:25 PM
A/F Ratio? Marc Lublin Performance Modifications 3 11-08-2001 11:32 PM
Close ratio &short shifter Sale Svsi Performance Modifications 6 11-17-2000 03:09 PM
Close ratio &Short Shifter Sale Svsi New Products and Supplier Specials 0 11-03-2000 03:19 PM
