| Service Manual/Technical Updates Viper Competition Coupe Service manual and technical upgrades. This is a "read only" forum. |
TECHNICAL SERVICE BULLETIN NUMBER 07 – 2 Date: May 7, 2007 Subject: Spark plugs Recent dynamometer testing and examination of spark plugs removed from service after the Sebring, Florida race indicate the heat range of the current Competition Coupe spark plug – Champion RC12ECC has marginal safety from pre-ignition problems. There have been no instances of engine damage or failure due to pre-ignition reported from the field using EC12ECC plugs. However, it is recommended that a colder plug, preferably a design with a precious metal fine wire center electrode that is at least a range colder be used in its place to improve the safety margin. One such plug is the Champion RC7PYCB4. These plugs are in stock and available through EPP. This plug has a shorter nose projection, which may degrade idle stability. The platinum fine wire should help offset this tendency. For further details contact Irv Zwicker. Irv Zwicker Dodge Motorsports Email: ikz@daimlerchrysler.com |
Does this apply only to the Competition Coupe? Thanx for heads' up! ~juli~
GTS Blue 08 w/ Silver Stripes Vert RED '08 436hp Corvette Orange 08 Busa |
Hi Juli,
Yes, this Technical Service Bulletin only applies to the Cometition Coupes. - Tracey |
Thank you Tracey!!!! ~juli~
WC's on 100 octane or regular Comp Coupe with 93 octane??
Thanks, Mickey Craig CC #33 |
Applies only to the WC comp coupes that require 100 octane gas.
| Technical Service Bulletin - Splitter Cable Mount | Viper_Race_HQ | Service Manual/Technical Updates | 0 | 06-26-2007 01:15 PM |
| VCC Technical Service Bulletin: Engine Oil Cooler Service Tool | Viper_Race_HQ | Service Manual/Technical Updates | 0 | 05-07-2007 09:29 AM |
| Technical Bulletin - Fire Suppression System - Immediate Inspection Needed | Viper_Race_HQ | Service Manual/Technical Updates | 0 | 11-10-2004 04:13 PM |
| Service Bulletin - Air Jack Lines | Viper_Race_HQ | Service Manual/Technical Updates | 0 | 04-05-2004 03:45 PM |
| Tech Service Bulletin 03-05-95, Where Can I Get It? | MR VENOM | RT/10 and GTS Discussions | 2 | 03-19-2004 09:24 PM |
