Go Back   Viper Club of America Discussion Forums > Viper Competition Coupe Discussion > Service Manual/Technical Updates
Service Manual/Technical Updates Viper Competition Coupe Service manual and technical upgrades. This is a "read only" forum.
Old 05-07-2007, 09:29 AM   #1
Viper_Race_HQ
Default VCC Technical Service Bulletin: Engine Oil Cooler Service Tool
VIPER COMPETITION COUPE
TECHNICAL SERVICE BULLETIN
NUMBER 07 - 3
Date: May 7, 2007
Subject: Engine Oil Cooler Service Tool
Recently, a number of engine oil coolers were found to have cracked joints where the oil cooler hose fitting bosses are joined to the cooler core.A simple tool is in use at the VCC build facility to help prevent twisting these fitting while the hoses are being installed. It is recommended that a similar tool be used when installing the oil cooler hoses on a Comp Coupe when these items are being serviced by the various teams. For your convenience a drawing of the tool is attached to this bulletin. The tool at the build facility is made from scrap mild steel. It can be easily made from aluminum as well.
The tool locks the two oil cooler bosses together while the hose ends are being tightened and prevent the bosses from being twisted during the hose tightening procedure.
A drawing of the tool is attached to this document. For further details contact Irv Zwicker
Irv Zwicker
Dodge Motorsports
Email: ikz@damilerchrysler.com
Viper_Race_HQ is offline   Reply With Quote
Technical Service Bulletin - Splitter Cable Mount Viper_Race_HQ Service Manual/Technical Updates 0 06-26-2007 01:15 PM
Technical Service Bulletin: VCC Spark Plugs Viper_Race_HQ Service Manual/Technical Updates 5 05-16-2007 02:05 PM
Service Bulletin - Air Jack Lines Viper_Race_HQ Service Manual/Technical Updates 0 04-05-2004 03:45 PM
Tech Service Bulletin 03-05-95, Where Can I Get It? MR VENOM RT/10 and GTS Discussions 2 03-19-2004 09:24 PM
Service Bulletin - Hydraulic Fan Replacement Viper_Race_HQ Service Manual/Technical Updates 0 01-08-2004 04:55 PM
