Go Back   Viper Club of America Discussion Forums > Viper Competition Coupe Discussion > Service Manual/Technical Updates
Service Manual/Technical Updates Viper Competition Coupe Service manual and technical upgrades. This is a "read only" forum.
Old 05-07-2007, 09:47 AM   #1
Viper_Race_HQ
Default Engine Coolant Rules
VIPER COMPETITION COUPE
TECHNICAL SERVICE BULLETIN
NUMBER 07 - 4
Date: May 7, 2007
Subject: Engine Coolant Rules for Racing. Blocked Open Thermostats.
Please refer to section 2.9.3.16.2 of the 2007 SCCA PRR. Viper Competition Coupe engines ARE NOT to be run in competition with any glycol based coolant. This rule also applies in virtually any racing series. In any case, plain water is a far better coolant than 50/50 glycol in terms of ability to absorb heat. Typically the system should be filled with clean water with a small amount of water pump lube and water wetter (if desired).
In addition, the thermostat should be permanently blocked open as a reliability measure. All engines sent back for overhaul in the future will have this done to the thermostat as standard procedure if required.
Another option would be to place a restrictor orifice in the thermostat housing in place of the thermostat. An orifice opening of 1.125 inch is suggested.
Irv Zwicker
Dodge Motorsports
Email: ikz@damilerchrysler.com
Viper_Race_HQ is offline   Reply With Quote
Engine coolant temp sensor Allan88 RT/10 and GTS Discussions 5 07-30-2005 05:04 PM
Engine coolant level question Tomas RT/10 and GTS Discussions 13 04-29-2004 06:49 PM
Engine coolant on ground! Any Ideas? Sniper Engine, Drive Train, and Suspension 11 12-29-2003 09:53 PM
Check Engine: "Coolant Temp -40 Degrees".....WTF? Bugeater RT/10 and GTS Discussions 11 03-02-2003 09:16 PM
Engine coolant/Voltage guage Jack B RT/10 and GTS Discussions 0 07-16-2001 12:36 AM
