(Almost) new Viper owner, saying hi
ViperDefender
ViperDefender
Portland, ME
Well, I *finally* took delivery today! Pictures to come soon. New question: while maneuvering it into my garage, an upwards orange arrow lit up on my central display...overheat warning?
ViperDefender
ViperDefender
Portland, ME
New question: does anyone else have to crush their clutch against the floor in order to get their Viper to start?
When I tried starting the Viper to do some garage re-maneuvering, I pushed the clutch to the floor, but the vehicle wouldn't start. Only after I put as much weight against the pedal as I could, got it to move a hair more, the car started.
Seems...overly temperamental...but maybe that's what I've gotten myself into?
TalonTSi90
Prob just need to adjust the clutch switch, was an issue on the DSM's too. For some reason i thought you got a Gen II? Is that an Autoform hard top? I cant see the seam on the front edge.
ViperDefender
ViperDefender
Portland, ME
Alright, thanks, I'll put that on the list. Gen I for me, and that *is* an Autoform top--nice piece.
ViperDefender
ViperDefender
Portland, ME
Alright, so after getting over a bug, I'm finally getting around to posting some more pics--I took way too many, so this is just a sampling:
Super excited to get this thing on the road, summer can't get here soon enough.
TalonTSi90
Was mid to low 50's I think today, perfect for swapping out the rad on my friends '03 Liberty with just a long sleeved tee over a short sleeved one. No sweating and no freezing. Was kinda nice working on a Mopar again...
ViperDefender
ViperDefender
Portland, ME
Yes, definitely jealous. Our temps have been climbing, which is nice, but it has left the roads an absolute mess. Actually bent a wheel a few weeks ago, the roads are so bad from frost heaves and plows.
Maine summers are gorgeous, but the trade-off is a grueling winter.
ViperDefender
ViperDefender
Portland, ME
So as people may have noticed in my pictures from a couple posts ago, there is black shading in front of the exhaust **** (and on the front of the exhaust cover, but isn't visible in the picture I posted). At first I thought this was plastidip the previous own put on (they plastidipped the wheels), but I just saw a couple other Vipers with the exact same shading in the exactly same spots. Did some Vipers have this from the factory, or is this some sort of aftermarket thing?
ViperDefender
ViperDefender
Portland, ME
Bueller? Anyone have insight on this? Sorry to bump this post, just trying to figure out what these dark patches are, if they can be removed, etc.
speedracervr4
Lancaster, PA
Are you sure it's not clear bra material that has aged? Either way it's not factory. Unless it's painted it should be able to be remove with a heat gun and peeling.
ViperDefender
ViperDefender
Portland, ME
It could be, but it's weird--I see some sort of a clear coat/membrane type of layer near the edges, and the darkness itself looks somewhere between weird paint and aged discoloration.
But thanks for the info--now I have more confidence in seeing if I can get it removed.
Aaron1651
I had the same issue when I first bought my Viper. What I did is looped the clutch safety switch. No need to even push in the clutch when starting the car now, just make sure you are in neutral. If you want to keep the switch you have, when pressing the clutch down, move it off to the right and it will help with the starting issue.
ViperDefender
ViperDefender
Portland, ME
Awesome, thank you so much for this info--this is going to be one of the first things I tackle.
steve e
I would not loop the switch, keep the safty switch, to many bad things could happen, go under by the switch and ajust it so it engages sooner, you might have to bend the tab that its on but easy to do.
ViperDefender
ViperDefender
Portland, ME
Yeah, if I can find my way well enough, I'll try to adjust it/bend it accordingly.
ViperDefender
ViperDefender
Portland, ME
So I got down into the footwell to try and adjust the clutch switch, but I couldn't find anything to adjust...
Above are a couple pics. The S-shaped piece is the clutch pedal, and it is connected to the copper-colored piston/rod.
Is the clutch switch hidden somewhere else? It's a very cramped, awkward space down there, so maybe I missed it.
Javadog62
