VENOM badge
LifeIsGood
Viper Lane, Arizona
Venom members: You may have noticed that your Venom badge on the forums is not the color it used to be. In order to correct that, you'll need to login to your VCA members portal at https://www.viperclub.org/membership/ and set your badge of choice there.
I logged into my Member Account page...changed the image selection at the bottom to venomby.jpg and hit the 'update forums' buttom...doesn't save my selection...tried multiple times.
In fact, the selection always shows venomblack.jpg while my actual badge color on the posts is venom3.jpg. :confused:
-RUNNR
Site programmer
District 4, Moon
Ok, let me take a look at the "why" it's happening. I see you in the member database with black, so you'll be good to go shortly.
-RUNNR
Site programmer
District 4, Moon
As mentioned in the sticky at the top of all forums, you are now in control of your venom badge and can change it to whatever you wish.
Mopar Boy
Ontario and Ohio
Runner - Is there any way we can change the color codes in the choice dropdown so that there is more of the words? I am going to go out on a limb here and say there is many that will have difficulty with setting it up as even I found it took a bit to follow the code.
PDCjonny
Can I add a second one like I used to have?
I'm just so damn special....:smirk:
-RUNNR
Site programmer
District 4, Moon
There's images in my FF and my MSIE8, what browser are you using?
Mopar Boy
Ontario and Ohio
I thought I was using ie8 till now...;)
I could not see the logo until after I took a stab at what was yellow. Did not see anything before.
-RUNNR
Site programmer
District 4, Moon
Ya, IE is kinda nasty like that. I had to put special code in there for it... In FF, they show up in the select box. But then again, FF is HTML standards compliant vs MSMakeMyOwnStandards
InjectTheVenom
Is there a way to give me back my NY/CT Associate Member title and posting abilities in the members only section like I used to have them?
If people want me to pay for it I am all ears because I would love to support the club!
-RUNNR
Site programmer
District 4, Moon
A methodology for monitoring and configuring associated members is in discussion right now. I'll get back with ya once things have been figured out.
InjectTheVenom
Thanks, it used to be NY/CT Associate Member by the way. Posting abilities are still there.
Viper123456
