Standard Konis are adjustable, I've done it, its good
Joel
Ireland
Standard Konis are adjustable, I\'ve done it, its good
I asked around quite a few people at VOI and not many knew that the standard Konis are adjustable. I wasn't entirely sure myself, so I decided to find out on my return from VOI. I felt that my 99 GTS was definitely set up on the comfort side of good handling, with a general looseness in corners and an un-nerving wallow especially around the point where the rear end breaks away and grips again. Not confidence inspiring ! The spring rates felt reasonably good for fast road use, but the damping was way too soft, mainly in rebound.
I removed the spring/shock assembly from the car starting at the front, and with a set of spring compressors, removed the spring, then the plastic washer and the rubber bump stop(both split to facilitate fitting and removal). Then by clamping the bottom mounting of the Koni in the vice and fully compressing the shocks travel ( not the vice!) you will be able with a slight turn ( whilst fully compressed ) to feel the internal adjuster engaging. Whilst looking down from the top of the Koni, turning it anticlockwise, whilst still compressed, will reduce the rebound damping and clockwise increases it. There is a total of one and three quarters of a turn adjustment.
Mine were already turned fully anticlockwise ( minimum softest setting ), so I started by increasing the fronts to a half turn clockwise and reinstalling them, A road test showed no appreciable difference.
So out they came again, this time I tried a few different settings on the bench, and its difficult to feel any change until the adjuster is past one full turn clockwise. So I settled on one and a quarter turns all around, front and back, which leaves the Konis noticeably stiffer to fully extend by the very scientific method of standing on the bench above the vice and heaving as hard as I could to extend it.
After re-installing everything and it is a fair bit of work, it took me a full day and a bit of messing about, a roadtest revealed a greatly improved viper, no I'll say that again.... A TRANSFORMED VIPER !! The handling feels as I imagine it was designed to feel, better turn in, less after turn in wallow, much greater precision on the road, (and some of the roads in the UK and Ireland tax viper handling to the maximum). It is actually possible to feel what is happening with the suspension and the feedback from the road surface and tyres is altogether better.
I always knew that Konis were good dampers, and for no outlay, apart from my time, I have enabled them to start doing the job they were intended to do. I am delghted
Neil - UK
ENGLAND
Re: Standard Konis are adjustable, I\'ve done it, its good
I can foresee another upgrade for the Battleship, when ever your ready
VIPER BAZ UK
ENGLAND
Is that the same for a 94 RT. Niel thats a fast battle ship
Mr U-2
Smithfield, VA
Joel,
Great Post. Bill P told me about the adjustable shocks when I bought the car but I'm still too new in the seat to consider adjusting yet. Perhaps in time. I wonder if all come from the factory at the min-soft setting you describe?
Anyway thanks..good info.
Cheers.
J
Joel
Ireland
Not sure if a gen 1 would be the same, but if its on Konis they should be adjustable. I think that the gen 1's were a bit stiffer than the gen 2 anyway. Also not sure if all years and markets are set the same. Drove Chris's (Y2KGTS) 2000 GTS at VOI ( unbelievable generosity...thanks Chris
) and it felt a little tighter than my 99. Also **** 97 feels firmer than my before setting, but softer than my after setting. Incidentally, when I took them out initially, one of the front Konis was set at a quarter turn, the rest at minimum
Take a free day and just try adjusting, its one of the few things on a viper that costs nothing but time.
jcaspar1
Sacramento, CA
Great info Joel. I was wondering why I had never seen a post about adjusting the stock non-ACR shocks. I will give it a try. What kind of spring compressor did you use?
Neil - UK
ENGLAND
Gen 1 were a LOT stiffer, don't think you'd want to much harder
for street use
VIPER BAZ UK
ENGLAND
Did'nt no if i could soften it up just a bit as the roads are not that good around here and she jumps about a bit..
tradin1
Dallas, TX, USA
You can adjust the Koni's on the GEN I cars the same way. Makes all the difference in the world. Made an even more of a difference after installing the Eibach springs.
J
Joel
Ireland
Neil, we'll get the battleship sorted out for next season, take a day some time and start working on it, reckon if we do a side each, half a day should sort it out. Until then there is a whole winter of polishing ahead
DEVILDOG
VCA Member North TX
VENOMVILLE, TEXAS, USA
Joel,
Great post! Did you notice any difference in ride quality ie. over potholes, bumps, rough pavement? Is it a kidney buster or tolerable? Thanks.
J
Joel
Ireland
Ride Quality is great, harder yes, but feels more "sporty" definitely not a gut buster, just a better controlled suspension.
DEVILDOG
VCA Member North TX
Thanks again. I'm changing to max firm this weekend! Will post my seat of the pants results also.
J
Joel
Ireland
Devil, be careful about the max stting, ie, one and three quarter turns, the rebound damping is very strong at this level and may actually be a little to heavy for the standard springs. Try my one and a quarter setting first and see how you like it !
Snake Bitten
Southern Kalifornia
So said Joel
Mine were already turned fully anticlockwise (minimum softest setting)...So I settled on one and a quarter turns all around, front and back...
THANK YOU JOEL FOR THE R&D! One of the last things I had left to do on my "winter" list...What a piece of cake, due to your post...Mine were set to the minimum as well...took your advice and did 1 1/4 turns...My RT is still on stands for a couple more weeks...Hell, it snowed 2 inches last night...but spring is in the air! Can't wait to try the Koni adjustments out on some of my favorite "private tracks"...Thanks again! :cool:
Qualitywires.com
Louisville, KY
If you are going to remove your springs, becareful of those spring compressor tools that require you to turn a bolt for the claws to compress the spring. You can go to harbor frieght and buy a hydralic spring compressor for $80-100 and they work awesome!! I can have my suspension on my car off all fours in about 1 hour. (If you have air tools). The suspension on the viper is actually pretty easy stuff in my opinion.
jcaspar1
Sacramento, CA
Another thanks Joel for the great research. I did this last week. Mine were set at 1/4 turn. Went with your suggested 1 1/4. It has made a HUGE difference. The ride is a bit harsher but not bad at all. Really seems to hug the road now. Can't wait to try it out on a track. I used this spring compressor which worked quite well. 29$ from Habor Freight. Took about 1-1.5 hr per wheel once I figured out how to do it thanks to your great instructions.
jrkermode
Los Altos, CA, USA
I adjusted my shocks per Joel's suggestion (1 1/4 turns) just prior to the Thunderhill Viper days. It was definitely better than the stock setting (1/4 turn), however, I still found myself waiting for the car to settle prior to turning in. This was especially the case where it was bumpy entering the turn and when turn-in was proceeded by a change in direction. I'm going full max.
I have yet to notice any significant change in ride quality when simply motoring down the road.
Tom F&L GoR
Wappingers Falls
Just a hint/comment: You don't have to set all four the same. You might want to try stiffer in the front than the rear before you go full stiff on all four. Stiff front will make steering feel "quicker" but being softer on the rears will help maintain a little traction. Full stiff on the fronts and not more than half way stiff on rears has been good for me.
Snake Bitten
Southern Kalifornia
Just got my RT off stands from winter...took it for a rip...and I just had to say WOW! Handling is substantially improved!
jimandela
Western New York, USA
Gerald,
how long did it take you to adjust them?
Might have my vipertech adjust mine....
thanks
Jim
jcaspar1
Sacramento, CA
It took me about 1.5 hours per corner once I figured it out. The remove/replace is the easier part. It takes a little fiddling around to get the springs compressed. You could always have the tech do the adjustment and do the R/R yourself.
Moundir
Ny
sweeet :) I cant wait to adjust mine to full out street racer lol. The car feels like a Caddy right now :eek:
J
Joel
Ireland
Glad to have been of help and I hope that the simple adjustment of the shocks (or dampers for the technical purists) enhances the driving experience. I'm with Tom in that the front and rear don't need to be at the same settings. One and a quarter turns is toward the max I'd recommend at the rear, since there is a danger that the rebound setting will be too strong for the std springs and make the rear suspension too slow to respond. However at less than one turn there is very little change. At the front it may be ok to adjust a bit more, buts its a bit of a fiddle and I just ran out of time to experiment any more before the winter season brought things to a close.
V10 MOJO
Youngstown, Ohio
well, im going to give this "trick" a try tonight. anything i shoudl know going into this job before i get the car in 50 pieces and then find out the hard way? eibochs wuldnt make any difference to the amount of adjustment does it?
J
Joel
Ireland
There is nothing complicated about it, just mind all your "bits" when you are using spring compressors and don't forget to retighten the shock mounting bolts with the suspension at ride height or at least with the wheel jacked up to ride height (if you know what I mean ) so that the bush is not torsionally stressed. Don't think Eibachs will make any difference although they do have a slightly higher rate than std, so perhaps could support a fraction stiffer adjustment.......just try it and see. Good luck.
Toby
Mason, OH (Cincinnati)
One thing to remember is a stiff setting may cause loss of contact with the road on a bumpy surface that cold result in total loss of traction under heavy acceleration or turning.
I noticed when driving my father-in-laws ZR-1... when you set the shocks to the firmest setting the rear tires often would bounce right off the pavement when hitting a bump around a turn.
The middle setting was best for aggressive street driving and the soft setting made the car feel like it was "floating"
I think when I adjust my GTS I will set the front to firm and the rears in the middle somewhere.
Viper123456
