Go Back   Viper Club of America Discussion Forums > General Non-Viper Discussion > Sneaky Pete's Place
Sneaky Pete's Place The place to gather to swap stories about non-Viper related issues or events and to hold non-Viper related casual but serious discussions. Intended to be for the "non-jokers" of the community.
Sponsored By: GP Motorsports "Arrive and Drive"
Old 11-27-2001, 09:43 AM   #1
SapphireGTS
Default Acid etch/chromate primer
Does anypne have much experience using Acid etch and chromate primer. I have heard you can get them separate or as a single combination primer. I have some ruffed up aluminum I need to paint blue like my car.
ALSO Does anyone sell the Sapphire color in spray cans? I know I can get some for my Magnetic red vette.
THANKS!!!
Old 11-27-2001, 01:59 PM   #2
Joel
Default Re: Acid etch/chromate primer
Yes, I have used it on aluminium and it means your top coat stays on just the way you want it to. Mine was just called "Acid" and went on just like an ordinary grey aerosol primer. Always use it on bare alloy.
Joel is offline   Reply With Quote
Old 11-27-2001, 05:29 PM   #3
SapphireGTS
Thanks Joe (I changed my user name). Did you have to rough up the aluminum?
Old 11-27-2001, 05:33 PM   #4
Chuck 98 RT/10
Spiffy Florida VCA Member
Chuck 98 RT/10's Avatar
I used it to spray my PartsRack wing. For prep I just cleaned the aluminum thoroughly.
Keep in mind though that it is not a filler. If you have fine scratches and want a polished finish you'll need to shoot over the etch with a filler.
Old 11-27-2001, 06:53 PM   #5
SapphireGTS
Cool. What kind of filler do you reccommend?
THANKS!!!
Old 11-27-2001, 08:47 PM   #6
Chuck 98 RT/10
# 34 is a track car, so I wasn't overly concerned about finish. If I remember correctly I shot the red directly over the etch. It's good enough for the track. For a better finish any primer filler should do, but if you don't get the info here ask the autobody supply store and they'll point you in the right direction.
Good luck.
btw I used DuPont. Thats the wing in my avatar.
Old 11-29-2001, 01:18 PM   #7
SapphireGTS
Sounds good. Thanks for the info.!!
HVLP question regarding high build primer Tom and Vipers RT/10 and GTS Discussions 21 10-03-2006 04:10 PM
Success with GTS fuel pump Primer Timer - one question, though Tom, F&L GoR RT/10 and GTS Discussions 2 07-22-2006 08:38 PM
What color is primer? viperct2001 RT/10 and GTS Discussions 3 06-26-2006 10:25 AM
Need a Viper Brake Primer GoFish Tire , Wheel, Brake and Suspension 3 02-02-2006 08:46 AM
Internet Primer Ulysses Sneaky Pete's Place 0 10-27-2004 07:46 PM
