Go Back   Viper Club of America Discussion Forums > General Non-Viper Discussion > Sneaky Pete's Place
Sneaky Pete's Place The place to gather to swap stories about non-Viper related issues or events and to hold non-Viper related casual but serious discussions. Intended to be for the "non-jokers" of the community.
Sponsored By: GP Motorsports "Arrive and Drive"
Old 04-22-2002, 07:29 PM   #1
FUSCUCLA1
Default Need computer help
To make a long story short, I needed a new hard drive and I got one from my friend. Installed it, the OS (windows 98), and all the drivers and software. It worked fine for a few weeks but now after I start up and am using the computer I get a blue screen "error writing to drive C" or something to that effect. The blue screen comes up sometiomes minutes after start up and sometimes an hour or so. After resetting the computer doesnt recognize (primary=none) the hard drive but letting it sit for 5 mins or so and then restarting the thing starts up with no problems until the blue screen eventually shows again. Any ideas???
FUSCUCLA1 is offline   Reply With Quote
Old 04-22-2002, 07:38 PM   #2
-RUNNR
Site Programmer
-RUNNR's Avatar
Default Re: Need computer help
If the HD was recently replaced like you said, it sounds as though the HD controller is dying, or BIOS is corrupt.
If your BIOS is battery backed, pull the plug to reset.
If it's the HD controller, and it's built into the motherboard, you'll need to replace the motherboard. Otherwise, replace the controller card.
-RUNNR is offline   Reply With Quote
Old 04-22-2002, 08:26 PM   #3
Ulysses
Allen,
I would try replacing the internal battery.
(I take it you don't like USC )
Old 04-22-2002, 08:57 PM   #4
ACR Larry
Allen,
Where are you in Southern California? If you are close by, I can take a look at it.
Larry
ACR Larry is offline   Reply With Quote
Old 04-23-2002, 12:44 AM   #5
FUSCUCLA1
Thanks guys, the controller is on the mother board.
Ulysses, Its mostly a joke but I'm not a huge fan of SC, I actually went there for one day, after I had graduated from UCLA, and withdrew. I had come up with the name way back when UCLA football was in the middle of that long winning streak, old history nowadays.
Larry, I am near Pasadena.
Sorry I would email everyone but my comp is flaky and posting here is just easier under these circumstances.
Old 04-23-2002, 03:05 PM   #6
AJ
controllers very rarely go bad. most likely your new hard drive is failing after the initial burn-in period. it happens very often especially with the new high-rpm drives.
just imo
alex
02 gts
few other cars
AJ is offline   Reply With Quote
Old 04-23-2002, 04:20 PM   #7
JGK95
Virus, Virus, Virus.... hmmmm. Im sensing a theme here....
Jay K.
JGK95 is offline   Reply With Quote
Old 04-23-2002, 06:45 PM   #8
SapphireGTS
Everyone thinks they are a computer whiz
To work around this issue, disable IRQ steering. To do so, follow these steps:
1: Restart your computer. Press and hold down the CTRL key until you see the Windows 98 Startup menu, and then choose Safe Mode.
2: Click Start, point to Settings, and then click Control Panel.
3: Double-click System, click the Device Manager tab, and then double- click the System Devices branch to expand it.
4: Click PCI Bus, and then click Properties.
5: Click the IRQ Steering tab.
6: Click the Use IRQ Steering check box to clear it.
7: Click OK, and then click Yes to restart the computer when you are prompted.
Good Luck!
Old 04-23-2002, 07:18 PM   #9
2tall
Uh... we spent 6/8 hours per work day surfing this board.
I think that qualifies
2tall is offline   Reply With Quote
Old 04-23-2002, 07:35 PM   #10
SapphireGTS
no doubt
<FONT COLOR="#ff0000" SIZE="1" FACE="Verdana, Arial">This message has been edited by SapphireGTS on 04-23-2002 at 07:36 PM</font>
Old 04-23-2002, 07:36 PM   #11
SapphireGTS
ahhh yeeeeah.
Peter, yeeeaahhh Im going to need you to come in on Saturday
OKaaaaay?
Need help on AEM Computer. ab RT/10 and GTS Discussions 1 04-08-2007 04:45 PM
What comes with the AEM computer set up? ab RT/10 and GTS Discussions 13 09-24-2005 08:47 AM
Need a computer for 96 GTS v96gts RT/10 and GTS Discussions 2 06-09-2004 12:58 PM
I got the first 3D computer ElDiablo Viper Sneaky Pete's Place 8 11-10-2003 05:48 PM
old school computer geeks help me!! cant get old computer to recognize cdrom drive. Ken Larsen Sneaky Pete's Place 12 08-16-2002 12:03 AM
