Go Back   Viper Club of America Discussion Forums > General Non-Viper Discussion > Sneaky Pete's Place
Sneaky Pete's Place The place to gather to swap stories about non-Viper related issues or events and to hold non-Viper related casual but serious discussions. Intended to be for the "non-jokers" of the community.
Sponsored By: GP Motorsports "Arrive and Drive"
Old 11-09-2002, 10:13 PM   #1
v8huntr
Default air compressor
i'm looking to buy air compressor and air guns. it needs to remove crank bolt. which one should i get? i only have 120v in my house. i don't have 240v.
i just returned my husky compressor. it is 22gallon tank rated at 125max psi but it didn't do anything to crank bolt. my air gun is rated at 500max ft-lbs.
i also found 330ft-lbs electric impact. do you think 330ft electric impact can remove most crank bolts?
v8huntr is offline   Reply With Quote
Old 11-10-2002, 12:28 PM   #2
brianflynn
Banned
Default Re: air compressor
It's not the tank rating it is the airgun rating.
brianflynn is offline   Reply With Quote
Old 11-10-2002, 04:31 PM   #3
Fast Freddy
i assume you got that husky air compressor from home depot. since they carry alot of this product. they also carry ingersoll rand compressors. i bought what was supposed to be the most poweful air compressor at home depot for use with 120v. but the 6 hp motor kept tripping my circuit breaker. so i returned it to home depot and exchanged it for the ingersoll rand garage mate air compressor (5 hp motor) and never have had a problem. i have a husky 3-speed 500 ft. lb max air gun. this will work for your crank.
Fast Freddy is offline   Reply With Quote
Replacing AC Compressor 427Aggie RT/10 and GTS Discussions 2 04-22-2006 09:21 PM
Has anyone put AC on a non AC Gen I? I did, the compressor will not come on pattymelt3605 RT/10 and GTS Discussions 14 06-27-2005 09:43 AM
replacing the A/C compressor... ab RT/10 and GTS Discussions 0 08-31-2004 09:53 PM
have any of you ever wired in your own compressor? Eddie N RT/10 and GTS Discussions 8 02-19-2003 09:32 AM
A/C compressor going? SteveBCloud9 RT/10 and GTS Discussions 0 10-30-2001 03:38 PM
