Go Back   Viper Club of America Discussion Forums > General Viper Forums > SRT Engineering Q/A Area
SRT Engineering Q/A Area This area is for the SRT Engineering Team Q&A Discussions. Please stay ON TOPIC and follow the rules which are stickied inside this section!
Old 06-13-2007, 10:48 AM   #1
arjay
Default Has 'heat problem' been fixed on 2008 ?
I am on my fourth viper.
I am wondering if the cabin heat problem was addressed and fixed on the coming 2008 SRT/10. My 2004 seems to get very hot in the cabin only in slow/stalled traffic. Your comments are appreciated.
arjay is offline   Reply With Quote
Old 06-13-2007, 11:10 AM   #2
mike & juli
mike & juli's Avatar
Default Re: Has 'heat problem' been fixed on 2008 ?
I am guessing yes, due to the new exhaust, new cylinder heads, larger valves and Variable Valve Timing which electronically adjusts when the exhaust vales are open and closed according to engine speed and load, allowing the engine to 'breathe' cleaner and more efficiently (as quoted in SRT edge)...no more crossover pipes, so it's gotta be cooler, IMO. ~juli~
GTS Blue 08
w/ Silver Stripes Vert
RED '08 436hp Corvette
Orange 08 Busa
Old 06-14-2007, 06:19 PM   #3
rcl4668
rcl4668's Avatar
These are some quotes from the chat with the SRT engineering staff yesterday:
They stated that they had “adressed part of the interior heat issues by eliminating the cross over. You're no longer sitting in a ‘ring of fire’ You'll find it a bit cooler in the cabin.” Also, “Interior heat management has improved due to the elimination of the exhaust crossover pipe, a more effective cooling module, and the relocated hood louvers. The new hood louvers are in a lower pressure area of the hood, making them more effective at extracting hot underhood air.”
/Rich
Old 08-08-2007, 12:12 PM   #4
RTTTTed
Western Canada VCA Member
RTTTTed's Avatar
I read that the variable exhaust cam timing is oil pressur controlled, not electronic.
Ted
FIXED TROTTLE STICKING, TRY THIS VERY EASY FIX IF YOU HAVE THE SAME PROBLEM WANTED RT/10 and GTS Discussions 5 04-25-2006 01:08 PM
Fixed my running hot problem - run the AC! AG98RT10 RT/10 and GTS Discussions 3 05-26-2004 05:46 AM
See What's Behind You -- An SRT-10 Problem is Fixed HiYoSilver New Products, Supplier Specials, and Group Buys 1 10-14-2003 09:54 PM
What was the solution to the "heat" issue? Is it fixed? jwwiii SRT10 and SRT10 Coupe Discussions 7 11-23-2002 06:32 AM
"Hanging Idle" problem fixed (Finally) JimDavis MT 97GTS 650R Archive Management 4 06-21-2001 08:39 AM
