Old 06-30-2003, 05:52 PM   #1
Larry 03 SRT-10
Default Wind Noise?
I went from a 2000 GTS to the 2003 and the only problem I have is the wind noise with the top up.
Is this normal for a rag top or can the top or doors be adjusted to help the wind noise.
The noise on my car is at the back of the window glass where it meets the top.
Larry
Larry 03 SRT-10 is offline   Reply With Quote
Old 06-30-2003, 06:03 PM   #2
gtsviper
gtsviper's Avatar
Default Re: Wind Noise?
I have the same condition. It gets louder with the fan on higher speeds. It seems to increase the positive interior pressure so that the air escapes from the window seal behind the driver and passenger's heads.
gtsviper is offline   Reply With Quote
Old 07-04-2003, 01:14 AM   #3
luv2race2
Guys, my top actually separated between the window and the top within the first month of ownership. Make sure the staples holding the material to the top of the window are holding. Get a passenger to check out while your driving. Mine actually I could feel loose staples then it finally seperated. Hartzeim Dodge let me take it to a professional upholstery shop to get it fixed. Works fine now!!
luv2race2 is offline   Reply With Quote
Window wind noise? Coloviper SRT10 and SRT10 Coupe Discussions 12 04-27-2007 03:17 PM
Very loud wind noise at high speeds.. Falconeer RT/10 and GTS Discussions 5 01-25-2006 05:00 PM
Wind noise in the new coupes ? twinvipers SRT10 and SRT10 Coupe Discussions 7 01-18-2006 12:15 AM
Wind noise/leak 1TONY1 SRT10 and SRT10 Coupe Discussions 8 12-28-2003 10:14 PM
In GTS, is it normal to have wind noise coming from the window at 60 mph? SF Final 286 RT/10 and GTS Discussions 12 07-04-2003 12:31 AM
