Old 02-22-2005, 10:13 AM   #1
vipersrt10
Default my car wont start
is the battery dead? it just clicks when i push the starter, i dont drive the thing that much,, maybe thats the problem
vipersrt10 is offline   Reply With Quote
Old 02-22-2005, 10:17 AM   #2
SRTJOE
SRTJOE's Avatar
Default Re: my car wont start
It sounds like a battery to me.
SRTJOE is offline   Reply With Quote
Old 02-22-2005, 10:41 AM   #3
ViperInBlack
Banned
May be a good idea to use a trickle charger if you are not driving very often.
ViperInBlack is offline   Reply With Quote
Old 02-22-2005, 11:02 AM   #4
quickysrt
is it a vette?
quickysrt is offline   Reply With Quote
Old 02-22-2005, 12:24 PM   #5
SRT10
Since you don't drive much,put into sleep mode.
SRT10 is offline   Reply With Quote
Old 02-22-2005, 02:54 PM   #6
Paul Hawker
Paul Hawker's Avatar
This is a common issue with Vipers that are not driven regularly.
The security and other systems slowly draw down the battery. Easiest solution is a under $40.00 battery tender. You can hook up the wiring easily, and leave the connector accessable through the side gills. Then simply unplug it when you need to go for a slither.
As a safety item, you can put a stickey note on your dash to remind yourself to unplug the tender before driving off.
It is a smart little gadget that will not overcharge your battery, even if left on continously while parked.
Old 02-22-2005, 03:36 PM   #7
SRTJOE
SRTJOE's Avatar
It really is worth the $40.00! Not only does it keep you batteries charged up but it make them last a lot longer I use it on my boat,waverunner and viper it has saved me money on batteries that is a fact!
Old 02-22-2005, 04:25 PM   #8
SRTRICKY
what does a battery tender look like?? :$
SRTRICKY is offline   Reply With Quote
Old 02-22-2005, 08:31 PM   #9
Paul Hawker
It's a small red/black (maybe other colors too) about the size of 3 packs of cigarettes. Weighs a few pounds. Would fit in a glove box. It usually comes with both a set of small +/- clips for temporary hook up, and a more permenant pigtail that can be put on terminals and can quickly and easily plug in the unit.
I have seen them at Wal-mart, K-Mart etc.
Believe it is made my Schumacher.
It's great to have around. Also hook it to the electric start lawn mower or snowblower or motorcycle when they are not going to be used for a while.
Old 02-23-2005, 09:23 AM   #10
vipersrt10
thanks, im going to get one. will it charge the battery enough to start the car, or should i jump start it first? at this point its still really low
Old 02-23-2005, 10:10 AM   #11
Steve-Indy
IN/KY VCA Member
Battery should charge in a few to several hours with a "battery tender"...remembering that these devices use a very low output (range of 1.25 amps for a 12v Deltran Battery Tender Plus). While we have all done it in the past, I try to avoid a car-to-car "jump" whenever possible given the sensitive electronics on board cars these days. I do keep a battery pack available for such occasions.
Old 02-23-2005, 10:55 AM   #12
Paul Hawker
Battery tender is not designed to charge a fully dead battery. It takes "forever". Better idea is to charge it most of the way with a regular charger, or jump it and take it out for a few hours drive, then on the tender for a few days.
Keeping it on the tender when the car is stored will eliminate this issue.
Don't forget SRT's have a special sleep mode that is outlined in the manual. Reduces drain.
Old 02-23-2005, 12:34 PM   #13
Steve-Indy
IN/KY VCA Member
Point taken, Paul...I had figured that with NO charger or tender to date, he was NOT likely to buy TWO...and, since he said "it just clicks ", that the battery is not totally gone. Under similar circumstances, Battery Tender Plus has indeed charged Viper batteries to the point of successful "start" in "several hours" in my experience, though, admittedly...I'm usually in a little more of a rush and use a battery pack or a 10 amp charger.
P.S. If one does use a real charger, one might want to refrain from hitting the high amp "start" switch to be on safe side...hate to blow PCM !!!
Old 02-23-2005, 01:14 PM   #14
quick2tr
My previous post 2 weeks ago:
Did not think I would need a trickle charger, but something drained my battery quicker than expected, not sure what. Not even enough juice to power the door solenoid. I jumped it and went for an hour spin to charge it back up. Curious if anyone else has had similar experience:
Viper has been parked unlocked in a COLD garage in normal mode (not power saving mode).
Two weeks ago the Viper was started/idled for 15 minutes (seemed fine).
One month ago the Viper was driven.
Anyone else experienced an unusually fast drain? Normal? Should I be using the "power save" mode for anything more than a week?
Thanx.
This thread answered my previous question. I am now using the "power saving" mode. Only comment I would make about jumping is to follow the directions in the Viper owner manual. Give the Viper 10-15 minutes while on the cables to get the voltage up before hitting the starter.
quick2tr is offline   Reply With Quote
Old 02-23-2005, 05:29 PM   #15
redsrt03
I've been trying to drive mine a few hours each month. So far, I haven't had any problems.
Starting it up and letting it idle for only 15 minutes, probably drew more current than you put back it.
Living in San Diego, I would have thought you would have more of an opportunity to drive. But then again, southern CA has been getting soaked from what I see on the news.
Good luck.
redsrt03 is offline   Reply With Quote
Need help fast, car wont start GotAViper RT/10 and GTS Discussions 20 06-05-2006 07:09 PM
94 wont start FLOORIN04 Engine, Drive Train, and Suspension 5 01-22-2006 04:38 PM
94 roadster wont start!!! rvc9911 RT/10 and GTS Discussions 3 08-22-2002 06:09 PM
Help!!! Viper Wont Start!!!!! MikeDGTS RT/10 and GTS Discussions 5 03-15-2002 09:15 PM
Help Viper wont start toddt RT/10 and GTS Discussions 5 11-14-2001 09:28 PM
