Old 08-07-2005, 07:24 PM   #1
Muzz B Yellow
Default red fluid in engine compartment
To make a long story short I blew something in the engine compartment that threw a good amount of red fluid out the hood vents into my windshield Is this a power steering hose and if so is it tied into any other hoses?
Muzz B Yellow is offline   Reply With Quote
Old 08-07-2005, 07:58 PM   #2
Steve-Indy
IN/KY VCA Member
Default Re: red fluid in engine compartment
Probably Mopar ATF+4...used as factory fill in 2004 and 2005 SRT-10's power steering pump...which also drives the cooling fan. Have heard of a couple of 2005 pump failures...may be a leak at pump or from the lines.
Old 08-08-2005, 07:49 AM   #3
LynnS
Sorry to hear that you are having trouble. As Steve-Indy said, it probably the Power Steering. I experienced the same thing and the Dodge Service Rep said that one of the hoses had come loose at the Power Steering unit. Note, continuing to drive the car may result in further problems as the Power Steering Pump also drives the hydraulic engine-cooling fan. My engine certainly overheated quickly. I believe that one Viper owner who had like problems stated that his Power Steering unit was ruined by the time he returned home, perhaps due to running the car with the Power Steering unit "dry". Good Luck and please post your findings when known. Lynn
LynnS is offline   Reply With Quote
Old 08-10-2005, 12:55 PM   #4
Steve-Indy
IN/KY VCA Member
Any news, Muzz B Yellow ??
Old 08-11-2005, 12:35 PM   #5
Muzz B Yellow
OK here's the deal... finally got the car properly flat bedded to the dealer sixty miles from my home.. now I know the proper tow hook locations..suggest you check it out BEFORE it happens to you...anyway the power steering seal blew out, not a hose connection or even a hose...service rep said they spent more time cleaning the under carriage then it took to put in the new pump...all and all very happy with the service nothing like a happy ending!
Old 08-11-2005, 02:22 PM   #6
VCA Member/Site Sponsor
Viper Specialty's Avatar
Dodge must have changed something in the 2005 pumps... perhaps manufacturers? I have not heard of a 2003 or 2004 failure, except for the recall in 2003- but have heard of multiple 2005 failures.
Old 08-11-2005, 03:20 PM   #7
Steve-Indy
IN/KY VCA Member
Muzz B Yellow...thanks for the update...glad you're back in action.
Agree, Dan...wonder what's up??
Help on cleaning engine compartment SHADOW RT/10 and GTS Discussions 8 08-01-2005 03:22 AM
Best way to clean the engine compartment? Abq Bill RT/10 and GTS Discussions 13 04-17-2005 12:21 AM
Canīt find fuse box in engine compartment: please help ! whitesnake RT/10 and GTS Discussions 5 06-17-2004 11:04 PM
engine compartment fires? onerareviper RT/10 and GTS Discussions 6 03-16-2002 07:45 AM
BRIGHTEN UP YOUR ENGINE COMPARTMENT WHILE GAINING UP TO 10 RWHP!!! Tom Welch Archive Management 3 01-22-2001 09:14 PM
