Old 01-08-2006, 09:14 AM   #1
fastmd
NJ VCA Member
fastmd's Avatar
Default Stupid question about the stock runflats?
My rear driver side tire seems to be losing pressure, and I was wondering if this could be from the valve stem?
Do the stock run craps seal the tire if there is a puncture? My car is currently in hibernation, so I keep all tires at 40psi, and this tire just won't hold ?
I did read that the tire will be replaced free of charge for the first 2 years, so I am debating just calling the dealer and asking him to order a new tire.
Any suggestions ?
fastmd is offline   Reply With Quote
Old 01-08-2006, 11:55 AM   #2
rcl4668
rcl4668's Avatar
Default Re: Stupid question about the stock runflats?
fastmd --
Sorry to hear about your tire woes. I would first do a visual on the tire to see if there is any obvious puncture. Barring that, just mix up a small amount of dish washing liquid in water and put it in a spray bottle; then spray the tire, rim and the valve stem/cap assembly. If you see little bubbles forming anywhere that is your leak. If that does not work, take the wheel to your dealer or an authorized Michelin dealer to have them check it out. Leakage can occur from improperly installed valve stems or a tire that has not been properly seated on the rim.
Good luck.
/Rich
Old 01-08-2006, 05:36 PM   #3
Yellow32
TX VCA Member
Yellow32's Avatar
There is no liquid sealant (aka 'royal seal') in the run flats, just more rubber/thicker sidewall, etc
-J
Yellow32 is offline   Reply With Quote
Stock Runflats for sale MikeR SRT10 and SRT10 Coupe Discussions 0 04-17-2007 11:44 AM
Tire Pressure for Stock Runflats as well as BFG DR's INFURNA SRT10 and SRT10 Coupe Discussions 6 02-13-2006 06:18 PM
Stupid question...? pattymelt3605 RT/10 and GTS Discussions 1 05-06-2005 02:47 AM
Another stupid question (I like stupid questions) Mike_W Performance Modifications 13 02-23-2004 10:17 AM
Really stupid question 2tall RT/10 and GTS Discussions 4 08-06-2001 11:45 PM
