Old 05-31-2006, 11:58 AM   #1
wormdoggy
wormdoggy's Avatar
Default Belanger SRT-10 install........any problems with
O2 sensor wiring being underneath the heat shield ( post converter ). You literally have to fold the shielding over the wiring and then bring it back over the shield to the stock connection. I thought of cutting the shield( just slightly ) and then fish the wiring ( shielded of course )through the opening but I was concerned about the heat possibly burning the sills.
In my opinion there should be a setup where the sensor wiring travels over the heat shield and not underneath it as with the Belanger setup.
Second time I had to remove the sills to access the o2 sensor wiring ( post converter ). This time I wrapped the wiring with heat tap, sheild , header tape and finally one more layer of heat tape. Hopefully it will do the job.
Paid $ 300.00 for a set of new 02 senor wiring CDN. Damn !!!
Does this problem exist with the Corsa set-up as well. Where is the 02 sensor wiring on the Corsa? Does it travel over the shielding or underneath it and what do you use to protect it from the heat? I would really like to compare it with the Belanger set-up since I understand this is a common problem.
Patrick
wormdoggy is offline   Reply With Quote
Old 05-31-2006, 02:33 PM   #2
Racer Robbie
New England VCA Member
Racer Robbie's Avatar
Default Re: Belanger SRT-10 install........any problems with
It depends on which corsa system you are using. If you go with Random Cats there is no problem. There are kits availble to put over the o2 sensor and wiring that will keep them from being damaged from exhaust heat. They reflect the heat away. They are also used on race cars to cover the spark plugs and wires.
Robbie
Old 05-31-2006, 03:23 PM   #3
Vipermann
My O2 wiring was cooked several times. A common problem from what I hear. I have two 3" high-flow cats and I ended up replacing the second O2 sensors with O2 simulators.
Vipermann is offline   Reply With Quote
Old 05-31-2006, 08:05 PM   #4
wormdoggy
wormdoggy's Avatar
Can you please let me know what o2 simulators are and where I can find them ? Who carries these?
Everyone I have asked has no idea what they are?
Thanks for your help.
Patrick
Old 06-01-2006, 01:04 AM   #5
dallas
type in "02 simulator" under google something will come up.
dallas is offline   Reply With Quote
Old 06-01-2006, 01:06 AM   #6
dallas
www.O2SensorSimulator.com
Old 06-01-2006, 09:01 AM   #7
Racer Robbie
I went to the above web site and read it completely. I do not agree with the following statement form their web site:
"The second (secondary) sensor is downstream from the converter and its only job is to report if the converter is working properly."
When I studied to pass the ASE Certification Tests I was told the secondary O2 sensor reports to the ECM and further adjusts the fuel for optimal fuel to air ratio and emissions which results in a more efficiant running engine. Also in the companies FAQ question section is the following comment:
"After installing the O2 Sensor Simulator, my Check Engine Light (CEL, MIL) is still on."
I believe this tell something about what I feel is a SNAKE OIL PRODUCT.
I will say I have never tried this product and these are my opinions. maybe it works, maybe it does not. I would love to see dyno sheets from before and after they were installed with no other changes.
Robbie
Old 06-01-2006, 10:35 AM   #8
KenH
KenH's Avatar
The primary (upstream) O2 sensors are the ones used for A/F calibration. The secondary (downstream) sensor is only there to monitor the effectiveness of the catalytic converters. If the A/F measured at the downstream sensor is the same as measured at the upstream sensor, the catalytic converter is shot (or missing). The PCM expects to see a difference between the two readings if the catalytic converter is doing its job.
Using an O2 sensor simulator in the downstream location to fool the factory PCM is perfectly valid when removing catalytic converters.
Old 06-01-2006, 02:51 PM   #9
Kenny
Absolutely correct, ask any of the dozens of legitimate tuners who use sims.
Atro is AGAIN clueless.
Kenny is offline   Reply With Quote
Old 06-01-2006, 07:57 PM   #10
Vipermann
I've had them on my car for a year ... no issues. But ... the purpose was because I changed to 3" H-F cats ... so the real test will be if I pass emissions testing.
Still, I'm happy with not worrying about melted wires.
Old 06-02-2006, 11:57 AM   #11
Racer Robbie
Up I am again Clueless
From my statement above: "After installing the O2 Sensor Simulator, my Check Engine Light (CEL, MIL) is still on."
Please explain why this is if the system is so foolproof?
Lets just say we agree to disagree!
Robbie
Old 06-02-2006, 01:09 PM   #12
Kenny
Robbie
Properly installed they are foolproof. The fact that you don't know about O2 sims (which I was using SIX years ago on my Camaro) shows that you truly know very little about the modification of performance cars.
You truly are a blight upon this forum.
Old 06-03-2006, 12:54 AM   #13
ROGUE
Robbie
No we definitely agree (Kenny and I that is), you are 100% WRONG. On a DODGE, the post cat O2 sensors do nothing but monitor the condition of the Cats. Thats it, they play no proprietary role in the function of the engine what so ever.
If the MIL is on, it could be a faulty sim, but that hasn't changed the state of the engine tune now has it? And just the fact that you have to name drop the ASE test just to prove some credibility is a joke. Click Here Read that thread, specifically the first post, and it pretty much sums up your whole existence here.
ROGUE is offline   Reply With Quote
Old 06-03-2006, 04:10 PM   #14
Racer Robbie
I never said I had not heard of them. I said I do not believe in them. I believe we should all do our part to keep our air clean and we are not doing that by bypassing emission control parts. One can get the nsame rsults on the street with out having to bypass emission parts
Old 06-03-2006, 05:13 PM   #15
Kenny
You are such an idiot. You contradict yourself on the same thread. For those who don't want to scan up this thread, this is what you said about six posts ago:
Robbie
Old 06-04-2006, 09:51 AM   #16
Racer Robbie
To ROGUE, KENNY & ZORROESPANO
Rouge, When you make off colored comments about me you are really showing your ignorance. You do not know me, have never met me, and have not spoken with me in your whole life so to make such a comment is just as wrong as what I did regarding exhaust sims .Everybody makes mistakes, I am far from perfect, and I am man enough to admit that I screwed up when discussing the sims that take the place of O2 sensors and I am sorry. I had never heard of them before, we never used them in NASCAR.I was wrong to call them "Snake Oil" as I have been educated in there use and there are people using them successfully. But to say I do not know what I am doing in my field is slanderous and just as wrong as me calling sims snake oil. I have never felt that it is right to recommend a product that I have never heard of or have tried personally as we all know there are a lot of snake oil products out there like that ECM add on module that some guy on eBay was selling awhile ago. I do not know of anyone, except god, who is perfect and knows everything that is out there on the market in the performance world today. We have many happy customers who have bought our exhaust products, along with other products, and they do not feel they have been ripped off as they feel they received a high quality product. If there is any doubt in anyone's mind as to the quality of our products or our before and after sales support you need to go no further then these to post from two customers that bought our exhaust systems.
http://www4.forum.viperclub.org/show...amp;PHPSESSID=
http://www4.forum.viperclub.org/show...rue#Post682797
We have been in business since 1979 and have a perfect record with the Better Business Bureau. Again I am not perfect but I must have done something right during 27 years in business with with the 2500 customers that I have.
Again I am sorry, and apologize, for coming on as strong as I did but I am as passionate about vipers as the rest of you.
Robbie
AtRo Racing Products
Old 06-04-2006, 11:55 AM   #17
Kenny
First off, I really would love to know what you've donr in NASCAR because most of your comments lead me to believe you have little if any automotive knowledge. My guess is that you may have had people working for you who knew what they were talking about, but you certainly don't.
Second, NASCAR is miles away from what we are talking about here. Nothing even translates---not motors, not drivetrain, not suspension.
Third, you are a product whore. You gone on everyone's threads and try to hock your [******]. My guess is you have always been a salesguy and not a tech.
Finally, in an attempt to hock your [******] you give advice that is AT BEST unrelated and at times could cause them problems.
You have zero credibility on this forum because of your constant posting and half ass, unknowledgeable advice. No credible parts tuner or parts distributor acts as you have.
I have received numerous PMs from people thanking me for telling it like it is regarding you.
Old 06-05-2006, 08:04 AM   #18
Racer Robbie
To Rogue, Kenny, and Zorroespanol
Except for Kenny who is listed as a club member the other two of you are enthusiast. Do any of you personally own a Dodge SRT-10 Viper?
Robbie
Old 06-05-2006, 09:58 AM   #19
Racer Robbie
Just so the three of you totally understand, As I quoted dagger before" I am done with you" I will never never again respond to any of your childish comments and sucker shots form you three again. Just in case you do not know who you are let bme remind you, Zorrooespanol, Rogue, and Kinny. I refuse to lower myself to your standards. good day.
Robbie
Old 06-05-2006, 01:55 PM   #20
06red/whitecoupe
i installed complete bellanger system tip to toe in early april; after 600 miles fried the wire to the 02 senser on pasanger side; engine light came on; took about 2 and a half hours to fix and re-route. the "service engine soon" light re-set itself within ahout 100 miles so i didn't have to go back to dealer to turn light out.
06red/whitecoupe is offline   Reply With Quote
Old 06-05-2006, 04:43 PM   #21
wormdoggy
wormdoggy's Avatar
No need to go back to the dealer to turn the check engine light off. Just disconnect the battery ( negative terminal ) for a few minutes. Works like a charm.
Just in the event it happens again.
Patrick
Old 06-07-2006, 10:00 AM   #22
JonB - PartsRack
Site Sponsor Since 1998
JonB - PartsRack's Avatar
Can you please let me know what o2 simulators are and where I can find them ? Who carries these? Everyone I have asked has no idea what they are?
Thanks for your help. Patrick
"HALF OF ALL ADVERTISING IS WASTED"
PartsRack has em
Old 06-07-2006, 06:16 PM   #23
rleminv
At least the other half isn't.
rleminv is offline   Reply With Quote
Old 06-08-2006, 07:41 PM   #24
Kaya
Kaya's Avatar
Sorry to hijack this thread, but Kenny...email me at eschete344@bellsouth.net I can not send you a PM because it says you aren't accepting PMS.......I was trying to respond to your PM.
Kaya
Kaya is offline   Reply With Quote
Old 06-08-2006, 09:38 PM   #25
Krazy PSI
Just so the three of you totally understand, As I quoted dagger before" I am done with you" I will never never again respond to any of your childish comments and sucker shots form you three again. Just in case you do not know who you are let bme remind you, Zorrooespanol, Rogue, and Kinny . I refuse to lower myself to your standards. good day.
Robbie
LMFAO!!!!!!!!!!
Nice work guys.
Krazy PSI is offline   Reply With Quote
Belanger install gain of 23RWHP wormdoggy SRT10 and SRT10 Coupe Discussions 8 06-11-2006 11:36 PM
Belanger header install sparty116 RT/10 and GTS Discussions 3 03-22-2006 12:48 PM
Belanger Header and Exhaust Install In Progress ScottB7133 RT/10 and GTS Discussions 7 03-07-2005 12:12 PM
Belanger Coated Headers--anyone have problems with them? Casey RT/10 and GTS Discussions 20 11-18-2004 05:54 PM
Belanger header install question... fe155 Performance Modifications 4 08-25-2003 01:07 PM
