Old 06-14-2006, 06:05 PM   #1
Viper X
So Cal VCA President
Viper X's Avatar
Default Guys with Moton Club sports - what settings?
What settings do you guys use on your Moton Club Sports.
Rebound / compression, street / track / drags?
Old 06-14-2006, 07:02 PM   #2
SCLSSRT10
IL VCA Member
SCLSSRT10's Avatar
Default Re: Guys with Moton Club sports - what settings?
Start with them set at the middle settings, then adjust as necessary for each track.
SCLSSRT10 is offline   Reply With Quote
Old 06-14-2006, 08:32 PM   #3
gtsviper
gtsviper's Avatar
It doesn't really matter what the shock settings are....the fuel will leak and the oil seals in the paxton will to so you don't need to worry about how much the car bounces!
gtsviper is offline   Reply With Quote
Old 06-14-2006, 08:45 PM   #4
Vipera Russelli
I have 500 and 700 lb springs front and rear, respectively, and initially set both the bump and rebound to 3 on the fronts and 4 on the rears, all on the recommendations of John Archer's shop. To me the car still felt a little soft on the track, so I changed both bump and rebound to 4 on the fronts and 5 on the rears. The car now feels great to me on the track. I don’t bother changing the settings for the street since I do most of my driving on the track, but I do whence when I see a small bump coming up, which is almost always a jarring experience.
Vipera Russelli is offline   Reply With Quote
Old 06-15-2006, 05:03 AM   #5
VIPER D
VIPER D's Avatar
500 front and 700 back?
are you sure its not the other way around?
vd..
VIPER D is offline   Reply With Quote
Old 06-15-2006, 10:01 AM   #6
Vipera Russelli
vd..
I'm sure. Do you know of a case where someone put heavier springs on the front than on the rear?
Old 06-15-2006, 10:33 AM   #7
Bill Pemberton
Kansas City VCA Member and Site Supporter
Bill Pemberton's Avatar
Viper D may be thinking of some other cars, as I do not know of a case where we have done heavier springs in front on a Viper, but on Mustangs this can be the case depending on the year and set-up.
You might call Mark Jorgensen at 1-800-889-1893 and check with him for your applications. He is our Performance Service Coordinator and he is usually very willing to help out.
Good Luck.
Bill Pemberton is offline   Reply With Quote
Old 06-15-2006, 04:25 PM   #8
VIPER D
VIPER D's Avatar
no no no
what I meant was
Its should be 700 fornt and 500 back
vd..
Old 06-15-2006, 05:32 PM   #9
VIPER D
VIPER D's Avatar
vd..
I spoke to the sales vp of elbach
he told me that there is more weight in the front thus heavier spring.
vd..
Old 06-15-2006, 05:46 PM   #10
Paul Hawker
Paul Hawker's Avatar
SRT's actually have rear weight bias. 48/52.
Don't know about spring weights though. They all seem very heavy to me.
Paul Hawker is online now   Reply With Quote
Old 06-15-2006, 05:49 PM   #11
Daniel Cragin/DC Performance Inc
The heavier springs always go in the rear.
Daniel Cragin/DC Performance Inc is offline   Reply With Quote
Old 06-15-2006, 05:54 PM   #12
ILLSMOQ
CA VCA Member
ILLSMOQ's Avatar
We have some bad roads in San Jose so on our streets I run; compression = 3 rebound = 2. (the starting point recommended in the instructions)
It's pretty comfortable at that setting.
Track settings for me are; compression = 4, rebound = 5. Wheel hop is almost gone at this setting.
track for me is more straight line type stuff.
Old 06-15-2006, 06:47 PM   #13
VIPER D
VIPER D's Avatar
I was told by the vp of eibach (the makers not some reseller) that the 900 lbs front and 700 rear.
I will look into this tomorrow but the viper rides great. I havent even done a wheel alighment yet!
vd..
Old 06-16-2006, 12:28 AM   #14
Kai SRT10
Kai SRT10's Avatar
I've got spring rates of 550 front; 750 rear.
I have played around with shock settings quite a bit, and have kept a log of my impressions. (Which is the only reason I can remember this stuff, as I haven't driven my car in ages.)
I ran 3 bump, 2 rebound for quite a while on the street. It gives a very good ride quality. 3 and 3 also seems good. I go back and forth between these two settings. 2 rebound seems more comfortable. 3 rebound seems a little less smooth, but seems a little "tighter" for canyon carving and fast cornering.
I tried 2 bump, and 3 rebound, and that didn't seem to work very well. The car seems squishy and less responsive to me at bump settings less than 3.
I tried running 4 rebound, 3 bump on the street. It's quite a bit harsher, and the gains in response didn't outweigh the added bumpiness compared with my regular street setting.
On smooth tracks, I run 4 and 4. On bumpy tracks, I run 4 rebound, 3 bump.
For high speed open road racing with speeds over 130mph, I run 5 rebound, and either 3 or 4 bump, depending on the road surface (3 for rough, 4 for smooth.)
For drag racing, I would dial the rear bump way down to 1. I don't think it really helped all that much. The best 60 foot time I've ever done (1.641) was on a pass where I had the car set at 3 and 3.
Old 06-16-2006, 01:24 AM   #15
madman
Banned
I tried 3b/2r but it gave me way too much of a body roll for my taste. although the car for almost the same comfy as my wife's M3:-). Now I run 4/4 on the street and 5-6/4 on track which is just about perfect for me. I needed to settle rebound to one value since once you put car down there is no way to change it easily without going on the lift.
madman is offline   Reply With Quote
Old 06-16-2006, 08:46 AM   #16
Vipera Russelli
If I had to do the install over again, I would go with these spring rates.
Old 06-16-2006, 10:36 AM   #17
VIPER D
VIPER D's Avatar
thank you for !!!!!!! you are right!!!!!!!!
i will start a seperate thread about what happened!!!
thanks again
vd..
Old 06-16-2006, 10:49 AM   #18
Kai SRT10
Kai SRT10's Avatar
One thing I forgot to mention is that the gas pressure on the Motons is adjustable between 100 and 300 pounds. I believe that the factory set pressure in these shocks is 175 lbs.
I bumped my pressure up to 210 lbs, so my settings might be a little bit soft for somebody with the standard 175 pounds.
Old 06-16-2006, 06:43 PM   #19
Viper X
Viper X's Avatar
Thanks for the responses.
According to Moton, the recommended "starting" settings are compression 2, rebound 3 front and rear. Initial gas pressure is 175 psi per Lex @ Moton.
I went with 500 lb front, 800 lb rear, 8-inch long, 2.25-inch diameter Eibach springs with helper springs at each corner per recommendations from Woodhouse.
The ride is really pretty good on the street. Firm but not too harsh. Haven't been to the track yet with this set up but the front end "body rolls" a bit more at this setting than I'd like. A bit higher settings would likely help and switching springs is very easy with the Club Sports.
I'm currently trying to get the ride height correct and this has been a challenge.
Dan
Old 06-16-2006, 10:45 PM   #20
VIPER D
VIPER D's Avatar
is it nessasary to get a wheel alighment after the moton setup if the car feels fine?
vd..
Old 06-17-2006, 09:23 AM   #21
ILLSMOQ
CA VCA Member
ILLSMOQ's Avatar
Viper D - when you go as low as you did, you should re-align. Otherwise inside tread of your tires will wear out quicker.
Viper X, my mistake, I got the initial settings mixed up. I run the settings you posted on the streets.
Thinking of selling my Motons Club Sports w/ Springs VIPER D SRT10 and SRT10 Coupe Discussions 7 05-26-2006 01:18 PM
Moton Club Sport shocks for Viper GTS? Boxer12 Performance Modifications 2 02-08-2006 11:32 PM
Best place to buy Moton Club Sports? Noredline SRT10 and SRT10 Coupe Discussions 4 12-20-2005 06:55 PM
Anyone tried these Moton/KW Alternative? slither SRT10 and SRT10 Coupe Discussions 0 12-15-2005 07:30 AM
Moton Suspension INSOMNIAC SRT10 and SRT10 Coupe Discussions 2 09-16-2005 09:13 AM
