Old 11-12-2007, 06:15 AM   #1
rcl4668
rcl4668's Avatar
Default Lightest rims in 18 x 10 and 19 x 13?
I have a set of the SRT "Sidewinder" wheels that I will be mounting on a 2008 Viper with Michelin PS2 tires. These are the same rims used on the new ACR. This setup will be used for normal street driving.
The fronts are 18 x 10 and the rears 19 x 13. I weighed these on a bathroom scale and got 17.5 lbs for the fronts and 25 lbs for the rears which is about 35 lbs lighter total than the stock wheels on the 2003-2008 Vipers. I have done just a little research on this and the lightness of the Sidewinders is impressive even when compared with aftermarket rim manufacturers.
Nevertheless, I am also interested in getting a set of dedicated track rims in the stock OEM sizes to mount some Michelin Pilot Sport Cup tires or possibly the Hoosier R6 tires. What is the lightest (including magnesium, composite and carbon fiber construction) set out there that would be durable enough for regular track and autocross use?
Thanks in advance for your advice.
/Rich
Old 11-12-2007, 11:55 AM   #2
Kai SRT10
Kai SRT10's Avatar
Default Re: Lightest rims in 18 x 10 and 19 x 13?
Per the published specs for Sport Cups, wheels of 19x12.5 size would probably be better.
2004 SRT-10 609rwhp; 609rwtq, Naturally Aspirated
Old 11-12-2007, 12:01 PM   #3
rcl4668
rcl4668's Avatar
Kai --
Thanks, I noticed that on the Tirerack website as well. However, I want to keep my rim size and tire sizes the same as OEM because I may use the car in SCCA Solo2 events and I believe their rules provide that you can still qualify for their stock class with aftermarket wheels and tires so long as you use the same tire and rim sizes as OEM. Also, I noticed that the new ACR uses the new 345/30/19 Pilot Sport Cup size on the rear Sidewinder rim which is 19 x 13, not 19 x 12.5.
/Rich
Old 11-13-2007, 10:42 AM   #4
j-rho
Hi Rich,
I'll be interested to see what you find, as I am searching for similar wheels. I've talked to John Purner at CCW (Complete Custom Wheel - Welcome) and he says the SP16 style wheel he makes would be the lightest he can do for this application (stock sized wheels), though I was unable to get an exact weight figure from him.
Don't forget that in addition to stock width, the wheels must also have an offset within 1/4" from stock.
Oh, and as for wheel widths, for performance applications involving turns, it is generally best to have wheel widths at the wide end of the range, and perhaps even a bit wider. In some cases up to 1.5-2" wider than the wide end of the suggested range. Of course in Stock class we're stuck with stock-width wheels, where conversely, we are often forced to stick too wide a tire on our too-narrow rims. For instance, I am convinced the Viper will be faster with a 315/30-18 (11-12" sugg. wheel width) than the 295/30-18 (9.5-11" sugg.) up front.
j-rho is offline   Reply With Quote
Old 11-13-2007, 03:32 PM   #5
Vipermann
I recall that the Sidewinders were stated as saving 34lbs per set when Dodge first introduced them. I think that probably works out to a savings of about 8lbs per front wheel, and 9lbs per each rear wheel. ... If true that puts the stock wheel weights at about 25.5lbs and 34lbs, front and rear, respectively.
I would be curious to see how the stock wheels really do compare to some other aftermarket wheels. 3-piece wheels are said to often not save that much weight because of the weight of the bolts around the rim, with the primary benefit being custom fitment and looks. If wheels are Chromed that adds more weight. Over-size set ups (e.g. 20s) weigh more than the same wheel design in a 19, etc. (wheels weigh more than tire sidewalls, which is why racers run 18s).
The Sidewinders look 'OK' to me, and I had them on my '05. For 34lbs total, it's probably worth it, but if a set of wheels only saves 4-5lbs per wheel, I'm probably inclined to stay with stock ... and I like the look of the new Razors.
Vipermann is offline   Reply With Quote
Old 11-13-2007, 03:43 PM   #6
MikeR
MikeR's Avatar
There was a post awhile back of someone who changed out the 06 5 spoke wheels with runflats and he put on Sidewinder wheels and PS2's. I think the weight savings was like 70lbs total for all 4 wheels/tires. It was huge weight savings, especailly considering rotational mass.
05' SRT10 Copperhead #019/300
674 rwhp/631 rwtq- Paxton and I'm gay
Old 11-13-2007, 03:49 PM   #7
Vipermann
A big part of that would be getting rid of those heavy run-flats with their thick sidewalls.
Old 11-13-2007, 04:05 PM   #8
MikeR
MikeR's Avatar
Suprisingly, the PS2's last time I checked Tire rack, were only about 3 lbs lighter then runflats. So a total of 12lbs savings. Though when you pick up a runflat tire, you would think the weight savings would be more, those suckers are heavy.
Old 11-13-2007, 04:08 PM   #9
Vipermann
If true, then the 70lb total savings was overstated. The Viper magazine clearly quoted SRT as saying the Sidewinders netted a total weight savings of 34lbs. per set of four wheels.
Old 11-13-2007, 04:21 PM   #10
MikeR
MikeR's Avatar
Maybe, scales are like dynos, they all vary. lol So maybe with 12-14lbs savings on tires, you could gain 50lbs savings, thats still pretty darn good. Im actually in process of selling my Sidewinders and going to 19"/20" setup for looks. I guess I may be gaining a few pounds then.
Old 11-13-2007, 10:54 PM   #11
rcl4668
rcl4668's Avatar
Originally Posted by j-rho View Post
Hi Rich,
J-rho: Thanks for the information. Given that I may use the car in stock Solo or other similar stock classes, I am probablylocked in to buying rims with the identical dimensions as the OEM rims (18 x 10 and 19 x 13). I did not even know about the offset requirement so that is good to know.
Regarding research on lightweight rims, it looks like SRT/Mopar did a great job with the Sidewinders, especially for a "factory" , OEM rim. As I stated before, I weighed the rims at 17.5 lbs front and 25 lbs rear. I have the latest issue of Grassroots Motorpsorts in front of me and the Tirerack lists the weights of various lightweight competition rims. Just to give you an idea, the SSR Type C/Type C-RS rims are 22 and 24 lbs in the 18 x 10.5 and 18 x 13 sizes. The OZ Ultraleggera (ultralight in Italian) is 27 lbs and 24.5 lbs for the 20 x 10 and 20 x 11 sizes. I have not really researched magnesium or carbon fiber wheels though.
I recall the Forgeline VR1 one-piece rim being fairly lightweight but don't know specifics and am not aware if it is still available in 19'' sizes.
/Rich
Old 11-14-2007, 10:05 AM   #12
j-rho
Just FYI, non-metallic (i.e. carbon) wheels are not legal in SCCA Solo2, in any class. It may be just as well, if you happen to find any they're likely to be pretty expensive.
I imagine the CCW one-piece wheels like the SP16A are likely to be a bit lighter than the 3-piece Classics of similar size. My last set of Classics were 18x11 front (about 20lbs.) and 18x12.5 rr (about 22.5 pounds). So I'm guess the 18x10's would be about 18 pounds, and the 19x13 about 23 pounds. I suppose that's not much lighter than the Sidewinders, but on the plus side you can almost buy a complete set of CCWs for the cost of 1 Sidewinder wheel from the dealer...
Old 11-14-2007, 02:05 PM   #13
rcl4668
rcl4668's Avatar
J-rho: Again, thanks for the useful information about carbon fiber wheels in Solo2. Maybe I should just buy another set of Sidewinders for track use?
/Rich
Old 11-14-2007, 02:46 PM   #14
madman
Banned
Just to give you an idea, the SSR Type C/Type C-RS rims are 22 and 24 lbs in the 18 x 10.5 and 18 x 13 sizes. /Rich
UhOh... SSRs are MUCH lighter. Around 15lbs or even less.
madman is offline   Reply With Quote
Old 11-14-2007, 03:25 PM   #15
JonB - PartsRack
Site Sponsor Since 1998
JonB - PartsRack's Avatar
Rich.... you forgot to say where you purchased your 2008 ACR-style wheels ! Thanks.
The 34-35 lbs saved was off the 2003 10-spoke (boat-anchor)wheel weights.
It saves 25 lbs off the 2006 5-spoke wheels.
Doris has a set of Techno-Magnesio wheels on her RT10 PIR Pace Car-Track car..... in OE 18" They are even lighter than SSRs which weighed here at 21 lbs F and 23.5 R. Technos were the "secret Weapon" of ORECA in 99-00 and Daivid Donohue claimed his TMs saved him 1 sec PER LAP when qualifying. At his level, that is HUGE......
We also have 1 set of CARBON FIBRE SRT10 RIMS / MAGNESIUM CENTERS that is 12 lbF and 15R as I recall, but not OE sizes.
JonB-PartsRack
www.partsrack.com
What is the lightest 18/19 set up? Disturbed RT/10 and GTS Discussions 4 11-12-2007 06:06 AM
96 gts w/ stock 17" rims, want to go to 18" or 19" rims. how will it Edward 96GTS RT/10 and GTS Discussions 1 11-18-2005 11:09 PM
Anyone want to get rid of some GTS rims? got one RT/10 and GTS Discussions 13 12-20-2004 11:26 PM
Carbon fiber parts (world's lightest steering wheel?) Fiorano RT/10 and GTS Discussions 5 07-28-2003 07:13 PM
What is the lightest wheel suitable for street use? jrkermode RT/10 and GTS Discussions 1 07-21-2003 10:00 PM
