Old 12-21-2007, 06:30 PM   #1
oufan2929
OK VCA Member
Default Anyone know how much the upgraded DLM intercooler for the paxton is?
Just what the title says. Thanks--Andy
oufan2929 is offline   Reply With Quote
Old 12-21-2007, 06:49 PM   #2
MikeR
MikeR's Avatar
Default Re: Anyone know how much the upgraded DLM intercooler for the paxton is?
Id start by calling DLM to be exact but ballpark is around $ 650.
05' SRT10 Copperhead #019/300
674 rwhp/631 rwtq- Paxton
Old 12-22-2007, 11:54 PM   #3
oufan2929
OK VCA Member
Yea, I did but no one was in and being around Christmas I figured they wouldn't be. Thanks for the heads up. That seems cheap!
Old 12-24-2007, 12:45 PM   #4
I was at dougs shop yesterday afternoon, there is a HUGE difference in the pump and cooler. whatever DLM charges, I'm sure its worth it and dougs very fair.
CALL HIM !!
Old 12-24-2007, 12:48 PM   #5
mjorgensen
Woodhouse Viper Service Manager - Site Supporter-VCA member
mjorgensen's Avatar
It is $1000 installed option from DLM
Woodhouse Motorsports Division Mgr.
800-889-1893 work
402-677-2935 cell
2008 Viper Blk/Red 1of1
Old 12-24-2007, 01:20 PM   #6
Hiss
Hiss's Avatar
I had DLM install the SC with the cooler and pump. As mentioned it was around 1000 installed. Worth every dollar paid.
Pic of DLM cooler and pump compared to stock Paxton.
Call DLM
Hiss is offline   Reply With Quote
Old 12-24-2007, 02:18 PM   #7
Twister
Wow...Ill be getting that when I order the paxton
Twister is online now   Reply With Quote
Old 12-24-2007, 02:29 PM   #8
Jim Wilson
VCA Member AZ
Jim Wilson's Avatar
Hey Hiss, what are the dimensions of the DLM intercooler including thickness?
I assume it mounts in front of the radiator? If so, I wonder if it could be mounted elsewhere with a couple SPAL fans?
Thanks!
Jim
Jim Wilson is offline   Reply With Quote
Old 12-24-2007, 05:22 PM   #9
Hiss
Hiss's Avatar
Jim-Here are the measurements
24"- wide
7 1/2"- Height
1 1/2 - thick
It does fit in front of the radiator. As far as fitting elsewhere - be difficult to do.
With the DLM install and the cooler & pump- during the very hot weather the Viper ran at 200-205 degree around town and less on the highway. No problems with over heating.
With the 08 hood the Viper even runs cooler.
Gene
Old 12-24-2007, 07:06 PM   #10
Bobpantax
FL VCA Member
Bobpantax's Avatar
"With the DLM install and the cooler & pump- during the very hot weather the Viper ran at 200-205 degree around town and less on the highway. No problems with over heating."
The purpose of the intercooler/aftercooler is to cool the charge of air going into the engine so that the air is more dense and the explosiuon in the cylinder more powerful. As Doug said, it does not eliminate heat soak. It also is not a part of the cooling system of your engine unless I am missing something. Please explain.
Things go better with boost.
Bobpantax is offline   Reply With Quote
Old 12-24-2007, 11:50 PM   #11
Hiss
Hiss's Avatar
I understand that
The reason for my statement was that some feel the added cooler in front of the radiator especially the larger DLM cooler may cause the car to over heat. Ive had pm's asking me this after the sc install. I may be wrong but I think Jim had this concern about the large cooler installed in front of the radiator.
I had the same concern and DLM assured me that the larger cooler in front of the radiator would not cause the engine to over heat, and it did not. In fact my Viper engine stock ran 200-205 degree, and sometimes would reach 210-215 and with the large DLM cooler in front of the radiator it has never reach the 210-215.
Old 12-25-2007, 04:29 AM   #12
it allows more air in and around it to get to the radiator helping it cool the engine temps....
Old 12-25-2007, 12:17 PM   #13
2000 GTS Owner
Contact Dan (Final Gts) as he sell's these as well. He also has a much larger pump .I just recently started to work for dan and we just installed this kit to a customers car,work's great!!
2000 GTS Owner is offline   Reply With Quote
Old 12-25-2007, 06:45 PM   #14
Doug Supercharged Vipers
S. Fla. VCA Member
Site Sponsor
Hi Bob,
Yes, you did get a little side tracked - we are talking about the front mount intercooler (in front of the radiator). This is where SC/Turbo cars in general, compromise the thermal efficiency of flowing ambient air into the vehicles radiator. Most prominent on air/air intercoolers.
It's a double edge sword; the "front mount intercooler" is cooling down the supercharger's or turbo's boost, yet blocking the ambient air flow to the radiator. The radiator doesn't get enough air flow to provide adequate heat exchange to the car's radiator, therefore heating up the engine's cooling system's temperature.
The reason we typically encounter this on air/air intercoolers is the coolers "core thickness" needed to provide adequate cooling and lower psi (boost pressure) loss. And of course if the intercooler is mounted on-center of the radiator.
Our DLM front mount air/water cooler is very thin, so it negligibly restricts the ambient air flow to the vehicles radiator.
I hope this helped with any confusion.
Doug
Doug Levin Motorsports Inc.: www.douglevinmotorsports.com
305 249-RACE (7223)
N.M.B., Florida
Doug Supercharged Vipers is offline   Reply With Quote
Old 12-26-2007, 07:45 AM   #15
Jim Wilson
VCA Member AZ
Jim Wilson's Avatar
Thanks for the reply Hiss. Your right, heat is my main concern. With the
air-to-air intercooler that I'm running which entirely covers the radiator and is 3" thick, she runs way too hot in the summer months. It sounds like the DLM air/water setup may help this issue greatly.
Old 12-26-2007, 07:51 AM   #16
jim, you will need an air/water cooler (aftercooler) AKA the brick as well....and some fab work.
im trying to find a brick myself to do this.
Old 12-26-2007, 12:51 PM   #17
Jim Wilson
VCA Member AZ
Jim Wilson's Avatar
I hear ya Phil, my brains been squirming like a toad regarding that one. With our additional injector setup, it will have to be a custom charge cooler (as you stated, some fab work on the piping).
As an alternative, we could delete the additional injectors and go with fuel rails on the motor w/ bigger injectors, and use the Paxton charge cooler. But that might get expensive.
Just brainstorming here on the rest of the system…..I’m also thinking about installing water injection. The tank is 2.5 gallons and fits great behind the passenger side wheel well. The plan would be to run insulated lines to the intake. So just thinking out loud, why not use that tank as a reservoir for the water/air intercooler as well and mount the pre-cooler to the belly pan (drill some hole in the pan for ventilation and add a SPAL fan). The result would be even less restriction at the radiator.
Old 12-26-2007, 01:28 PM   #18
S. Fla. VCA Member
Site Sponsor
Hey Jim,
Let me know if you need some assistance - you won't have to change any injectors!
Best regards,
Doug
305 249-RACE (7223)
N.M.B., Florida
Old 12-26-2007, 03:09 PM   #19
Jim Wilson
VCA Member AZ
Jim Wilson's Avatar
Thanks for the reply Doug, I'll be contacting you very soon.
Old 12-26-2007, 03:40 PM   #20
jim, dont call doug...he's busy...
Old 12-26-2007, 04:12 PM   #21
Fast Too
Fast Too's Avatar
Doug,
I have your tensioner system and cooler installed on my car. Great products, but is there a plan in the future for mounting brackets of some sort for the DLM charge cooler? Mine is held in place by tie wraps and I think at some point, probably at an inopertunitive moment, a tie wrap is going to break.
'06 SRT-10 Coupe
Old 12-26-2007, 06:35 PM   #22
S. Fla. VCA Member
Site Sponsor
Originally Posted by Fast Too View Post
Doug,
Hello Fast Too,
I really appreciate your support! The reason I utilize the zip ties instead of "fixed brackets" is because the front cooler is VERY fragile, you actually want it to move or break a zip tie, otherwise if we were to fasten it too securely, a good hard bump to the front end will indeed break the cooler. The cooler extends very close to the bottom of the belly pan; more surface area, but easier to bump.
If it would give you some piece of mind, I could attach fixed brackets to your unit (free of charge ) and get it right back to you asap. It would be my pleasure.
Also, make certain to fasten the lower bottom of the cooler to the Power Steering hose.
Thanks again!
Doug
305 249-RACE (7223)
N.M.B., Florida
Old 12-26-2007, 06:38 PM   #23
S. Fla. VCA Member
Site Sponsor
I'll be here
I'll be here busy
305 249-RACE (7223)
N.M.B., Florida
Old 12-27-2007, 06:29 AM   #24
Fast Too
Fast Too's Avatar
Doug - Appreciate the explanation as to the rational on the tie wraps. Thanks for the great offer on installing fixed brackets but I sure don't want to break my cooler, so I'll leave as installed now that I understand the why. Also, thanks for being a great sponsor to the site and keep kicking out these great products.
'06 SRT-10 Coupe
Old 12-27-2007, 09:29 AM   #25
Hiss
Hiss's Avatar
I really appreciate Doug. He is a very busy man but always takes time to help any way he can. Like my son says "that man knows his stuff."
What intercooler should I buy for my Paxton S/C? Viper 23 SRT10 and SRT10 Coupe Discussions 5 08-07-2007 10:03 PM
Paxton intercooler- anyone test it for restrictions at higher boost? qwiketz Performance Modifications 1 03-05-2007 08:29 AM
Paxton Upgrade Advice for the Intercooler GR8_ASP SRT10 and SRT10 Coupe Discussions 18 01-26-2007 07:40 AM
Intercooler for Roe SC 2MANYTOYS RT/10 and GTS Discussions 3 12-05-2003 10:57 PM
If I put a front mount intercooler on the paxton set up... ab RT/10 and GTS Discussions 4 11-08-2003 02:11 AM
