Old 02-24-2008, 02:39 PM   #1
voi9
voi9's Avatar
Default Any advice on removing wheel weight adhesive?
What a PITA!
I am trying to remove the adhesive left on the rims from the old wheel weight's after getting the new PS2's on. I filed a piece of plastic to form a wedge and am scraping it off little by little but I still spent 45 min. on one rim that had a 1" by 3" piece. The biggest piece left to tackle on the remaining three other rims is about a 5" by 2" piece. Not looking forward to it at all. Any idea's on an easier way to get this stuff off without scratching the rims would be greatly appreciated.
BIBLE=Basic Instructions Before Leaving Earth
VIPER Verses: Acts 28:3 and Isaiah30:6
TATORS DODGE SAVED!!!!
voi9 is offline   Reply With Quote
Old 02-24-2008, 02:41 PM   #2
Ratical2
No California VCA Member
Ratical2's Avatar
Default Re: Any advice on removing wheel weight adhesive?
WD40 will work. It softens the adhesive. After the goo is gone, clean it with a degreaser like 409 or equivalent.
Old 02-24-2008, 03:33 PM   #3
TexasSnake
TX VCA Member
TexasSnake's Avatar
Or use gasoline to disolve it
'05 Silver SRT Vert (Paxton s/c, Belanger headers and stainless exhaust w/o cats, Competition cam, 60lb injectors, CP forged pistons, Oliver rods, MGW short throw shifter)
TexasSnake is offline   Reply With Quote
Old 02-24-2008, 04:07 PM   #4
Bluvenm97
AZ VCA Member
Bluvenm97's Avatar
3M adhesive remover, available at most auto parts stores, it comes in a small metal can.
Works very well, won't harm the surface...
Bluvenm97 is offline   Reply With Quote
Old 02-24-2008, 04:09 PM   #5
Janni
Carolinas VCA Member
Janni's Avatar
Brake cleaner....
Janni Cone
Carolinas Region Member
Janni is offline   Reply With Quote
Old 02-24-2008, 04:11 PM   #6
Asp Man
Western Canada VCA Member
Asp Man's Avatar
Xylene is what I've used.
Drive it like it's rented.
Asp Man is offline   Reply With Quote
Old 02-24-2008, 04:19 PM   #7
Phoenix SRT
VCA member
The 3M stuff is great. Goo Gone will also probably work, but go with the 3M stuff. I've used it on numerous wheels and it works very well and doesn't damage anything. I've not tried the Goo Gone on wheels, but it works well on other stuff. I also haven't tried any of the other suggestions, so maybe some of them work.
Phoenix SRT is offline   Reply With Quote
Old 02-24-2008, 04:35 PM   #8
If the wheels are clear coated on the inside, gasoline, xylene and brake cleaner will all harm that coating. The 3M stuff, WD40 or charcoal starter are much better choices.
If the wheels have no clear coating on the inside then use anything.
Old 02-24-2008, 05:00 PM   #9
voi9
voi9's Avatar
Thank's for the reply's everyone! I'll try the WD40 first only because I have some in the garage. If I decide to buy something else I'll go to Autozone and get some 3M adhesive remover.
Old 02-24-2008, 07:29 PM   #10
mygpw
I just used WD40 on a wheel rim recently. Worked great.
Its also a great aftershave.
mygpw is offline   Reply With Quote
Old 02-27-2008, 09:29 AM   #11
Racer Robbie
New England VCA Member
Racer Robbie's Avatar
We use Rosin lighter fluid
Rob Rossiter
AtRo Racing
203-641-8569
Old 02-27-2008, 11:41 AM   #12
mad0953
Oregon VCA Member
mad0953's Avatar
I use the 3M stuff to take all of the badges, plates, etc. off of all my cars (I hate them and no car company pays me to advertise for them) and it has never hurt the paint.
Old 02-27-2008, 12:52 PM   #13
29OUTLAW
My favorite adhesive remover is denatured alcohol (which is probably just the same as lighter fluid which Robby mentioned but 10x cheaper)
29OUTLAW is offline   Reply With Quote
Old 02-27-2008, 01:10 PM   #14
2002_Viper_GTS_ACR
NorCal VCA Member
2002_Viper_GTS_ACR's Avatar
Since I have done this EXACT thing. I can ASSURE you, the easiest and SIMPLEST and least amount of work is GOOF OFF. squirt a little on the sticky spot and wipe away.
This easily beats the brake fluid, wd40, and alchol tricks.... how do I know? I TRIED THEM ALL..
GOO GONE, GOOF OFF... whatever name the local hardware store calls them, its the CHAMP !!
Jon
2002 Viper GTS ACR Graphite (Sold)
2005 Viper SRT-10 Black (Bought 4 Dad)
2006 Viper SRT-10 Coupe "Viper Slate Crystal Pearl Coat" (Woodhouse delivered 6/27/2006)
Old 02-27-2008, 01:32 PM   #15
29OUTLAW
Jon
The treatment you try last always works best because the previous ones loosened everything up.
Removing adhesive...... malcoll RT/10 and GTS Discussions 7 04-24-2006 10:16 AM
wheel weight? syclone1157 RT/10 and GTS Discussions 16 06-26-2005 05:24 PM
Removing Wheel Scratch BobK898 RT/10 and GTS Discussions 2 03-22-2004 08:23 AM
ACR wheel weight? Russ M RT/10 and GTS Discussions 2 08-28-2003 09:54 AM
Removing the spare tire for less weight SSSSE YA RT/10 and GTS Discussions 2 08-12-2001 10:17 AM
