Old 02-28-2008, 10:20 PM   #1
oufan2929
OK VCA Member
Default what size tires do I need to get for my 19X10.5 I-forged front rims?
Thanks--Andy
oufan2929 is offline   Reply With Quote
Old 02-28-2008, 10:29 PM   #2
Viper Specialty's Avatar
Default Re: what size tires do I need to get for my 19X10.5 I-forged front rims?
295/30/ZR19:
https://www.viperspecialtyperformanc...roducts_id=102
If you have 19" rears:
https://www.viperspecialtyperformanc...products_id=99
If you have 20" rears:
https://www.viperspecialtyperformanc...roducts_id=101
25 profile rears also available, though most of the guys who see the 30 profile in person like it more... better traction, safer for the wheels, and fills out the wheel well better, even before lowering.
Dan Lesser, Owner
www.ViperSpecialty.com
(716) 912-5336
WNY Tech / VCA Activities
Old 02-28-2008, 11:19 PM   #3
MikeR
MikeR's Avatar
I have a 275/30/19 PS2, it is a little stretched on the 10.5, but still looks very good. Next time i may go to a 285/30, but it is just a hair taller sidewall,so it will make it look slightly bigger in front if you go with a 345/25/20 rear. So I definately wouldnt go with a 295, if you run the 345/25/20.
If you opt for a 285, your choice is Pirelli Rosso or Nitto invo. And then you can use their 345/25/20.
If you opt to use the PS2 , your only choice for rear is a 335/30/30, which is a little too tall, so then you could use a 275or a 295 front.
I always go to tirerack.com, see what the height is of the factory wheels, then you can look at the 19/20" options to get the correct sizing you want.
Heres my set up, 19x10.5 and 20x13 Iforged, with 275/30/19 and 335/30/20 PS2's. Next I may go back to Pirelli, since I want a little smaller sidewall in rear , I had to raise rear up a hair from where I had it sitting before to fit the PS2's, but im torn because the PS2 is a awesome street tire.
05' SRT10 Copperhead #019/300
674 rwhp/631 rwtq- Paxton
Old 02-29-2008, 12:17 AM   #4
ILLSMOQ
CA VCA Member
ILLSMOQ's Avatar
very informative post MikeR
if you run the 335/35/20 the 295 will look ok...both are too big but it wont look bad.
if you lower the car the 335/30/20 will put holes in your fender wells...tire hooks big time though.
I'm back to to the 345/25/20 pirellis.
Old 02-29-2008, 12:01 PM   #5
oufan2929
OK VCA Member
Thanks Mike, your car was a big inspiration for getting some i-forged! I'm actually going w/a 19" in the rear as well. Mainly so I can keep a sticky tire (hoosier R6) back there for when I make some decent power w/the paxton..
Old 02-29-2008, 01:33 PM   #6
MikeR
MikeR's Avatar
So if you go 19" all the way around, whatever size tthe rear sidewall is, just make sure the front is the same if not smaller otherwise it looks funny.
So in your case the Hoosier A6, your only real option for front tire in 19" is a 295 and then a 345 rear. The rear is 26.8" tall, the front is 26.1, so the front tire will have less sidewall, which will look ok.
On a side note, the PS2 in 20" is a 1" bigger then normal 20" tires and sticks well. So for the Paxton it is good as it actually lowers your gearing and gives you more sidewall for putting the power down. If you already ordered 19" , then it will still look good, but if you have the option still ,the 19/20 " looks killer.
Old 02-29-2008, 11:02 PM   #7
oufan2929
OK VCA Member
no doubt 20" will look better, but I really wanted a real sticky tire. nothing can replace the hoosier in the 20" category from my experience. and the 19 will still look killer, just not quite as killer as the 20"
Can I use 305/30/18 size front tires for racing ? Schulmann RT/10 and GTS Discussions 2 11-28-2006 12:42 AM
What size tires should I use in the front? SSSSE YA RT/10 and GTS Discussions 3 04-18-2006 01:04 PM
IForged arriving tomorrow! Tire size for 19X10 and 20X13? Blue Batmobile RT/10 and GTS Discussions 7 03-23-2006 10:44 PM
Plus Size rims/tires Tusc RT/10 and GTS Discussions 7 01-13-2003 01:27 PM
what size are these rims? and Whos tires are these? Toby RT/10 and GTS Discussions 16 06-30-2002 04:17 PM
