ILLSMOQ is installing my new rear end on Monday. I ordered a exchange housing with Quaife and 3:33 gears. Anyone have any tips or tricks for removing rear end. I heard its pretty straightforward and only takes a couple hours. No special tools needed.
If anyone has any info, instructions or tips, please post up. Thanks
05' SRT10 Copperhead #019/300 508 rwhp/522 rwtq 11.6 @ 120mph- N/A 674 rwhp/631 rwtq- Paxton |
OK VCA Member
Congrats on the quaiffe! You'll love it. I know I do mine! Wish mine had the 3.33's though. I'll probably make that switch at one point this year from the 3.55's...especially once the paxton goes on!
I just completed a diff swap on my car. Took me more than a couple hours, but I did it on my back in a small single-car garage. I also don't have the tools to properly undo the ball joints (you should use a correctly sized puller, not a pickle fork), so I had to unbolt the control arms, which makes the job tougher.
The manual recommends getting new driveshaft "straps" - a pair of small metal brackets that hold the rear u-joint together - any time it is disconnected, which it will be in this case. Have fun! |
How much was the quaife with the excange, and without?
You're going to enjoy the quaife. Great choice in going with 3.33's.
2008 VIPER COUPE: SSG w/White Stripes & 5-Spokes, Belanger Headers, Moton ClubSports & Eibach Springs, Quaife w/3.33's, StopTech 2pc Slotted Rotors |
How many miles on your car when you did the job, do you track your car and was it dirty. What fluid did you put back. Thanks
2005 SRT-10 Street Serpent # 5 Venzano Interior, Belanger Headers,Cats, Motons & EibachSprings.When I'm president mini vans will be banned from the high speed lane. |
#7 | |
Mike, PM sent. |
Group buy for the quaife will be official next week. i'll have much more info for those interested first of the week.
FL VCA Member
Joe... Let me know... seriously...
I need one... Joe |
Im doing a exchange. Its the easiest way in my opinon. It will be all set up with Quaife and unitrax 3:33 gears. I got it from Parts Rack around $2900 shipped. It arrived at my work about 1 week after ordering.
#12 | |
When we changed my fluid we went with stock fluid to refill, but the new exchange rear end comes with a fluid they recomend, havent opened box yet to see what it is.
TN VCA Member
I am interested in the group buy.
"Any society that would give up a little freedom to gain a little security will deserve neither and loose both." Benjamin Franklin
Price on the quaife unit will be ~1620 and with full exchange ~2400 (that means installed in the unit). details to come tomorrow or Tues at the latest!
JD |
TN VCA Member
Does that include the ratio change or just the posi unit? Either way I'm interested. I can get the gears for around $200. Thanks
That involves installing whatever gears you want in it. If you want to change, you'll just provide the new gears.
TN VCA Member
I've been told there are only a couple of shops qualified to install a quaife. Who is going to do the set up and what type of warranty comes with it. Also, is this the same price for a gen 3?
Thanks alot. I look forward to more details. |
#19 | |
$2400.00 for an exchange unit is better than anything else I've heard of by quite a lot. Joseph what gears and what bearings will you be using for the exchange units? |
#20 | |
The unit MikeR bought came with the recomended oil and the u-joint straps and bolts. |
#21 |
Joe,
This pricing is very attractive. My cost is considerably higher than this. Do these units come with new gears, bearings, seals, fluid and driveshaft straps? Does the Quaife unit include a lifetime warranty? If so, please call me I am interested.
#22 |
Joseph, I am interested, please let us know when ordering will happen.
08 ACR Orange/Blk Hardcore-full tilt, 06 SRT-10 blue vert 2006 Porsche 997S X-51 AERO, 95' 928 GTS 2010 Benz GL 550, 2010 TL-SH AWD,2003 Benz ML 500 |
#23 |
As soon as the VCA gets the check, the deal will go down. the set-up will be the same as the world-challenge set-ups... so that you'll have new bearings, seals, etc. Quaife unit has a lifetime warranty. as for gears, old gears are re-used unless you want to purchase or provide a new set. that is your call.
once the deal is officially a GO i will post it here and it'll get moved to the group-buy section. easy stuff. options will be the quaife only (if you want someone else to install it for you) or you send in your housing and it will be installed for you in the pumpkin. more to come... JD |
#24 |
So $2400.00 does not include new gears then and these are not going to be exchange units.
#25 |
Kurtis, Id just go with the exchange unit from Parts Rack. Its was $2900 shipped. New gears(your choice), bearings ,seals , oil etc and Quaife with lifetime warranty. You wont have to wait weeks while you send out your rear end. You can drive car until the exchange unit shows up and swap out same day.
#26 |
More like days not weeks... but to each his or her own.
#27 | |
Thanks. |
#28 | |
hey MikeR ...you DID just go with the exchange unit from parts rack. ![]() ![]() For some reason I was expecting Josephs $2400.00 deal to include new gears. Unless there is something wrong with your original gears, you won't really need to replace the gears....but that would be my preference. |
#29 |
These units will have modifications and machining to the stub axles.This has to be done with the Quaife .the only way to retain the stubb into the diff is with AN hardware.
The stub axle bores are machined for circlips. The circlips will retain the stub axle bearings into the housing so they will not float when the the diff gets to temp. This is the same set-up the world challenge cars have. Once the check to the VCA clears for the sponsor, this will be a go. And if we get 20 people, the price drops another $200. AND, if you'd rather have someone else do the labor, you can do that too. JD |
#30 |
JD - What is the latest on the Quaife group buy???
'06 First Edition 194/200
| Installing a Quaife? | MikeR | SRT10 and SRT10 Coupe Discussions | 19 | 03-06-2008 01:46 PM |
| Quaife??? why | Jsparks | SRT10 and SRT10 Coupe Discussions | 16 | 02-23-2008 06:06 AM |
| Installing a Quaife differential | Parisianviper | RT/10 and GTS Discussions | 14 | 09-11-2006 02:41 AM |
| I have the Quaife bug | Vipermann | SRT10 and SRT10 Coupe Discussions | 9 | 02-24-2006 08:50 AM |
| Will Gen II Quaife, fit in Gen III? | Andrew/USPWR | SRT10 and SRT10 Coupe Discussions | 2 | 02-11-2006 04:52 PM |
