Old 04-13-2008, 09:12 PM   #1
PJJP
TX VCA Member
PJJP's Avatar
Location: See avatar above because you will not be able to read my plate from your distance behind me.
Default Lighter flywheel question
Will a lighter flywheel show any power inprovement on the dyno or just SOTP feel?
'06 Red Vert - Bone Stock "making headlines, scaring passengers, and offending decent people on the street"
PJJP is offline   Reply With Quote
Old 04-13-2008, 09:55 PM   #2
MikeR
MikeR's Avatar
Default Re: Lighter flywheel question
Ive heard it is more seat of the pants and quicker revving. But some have said it takes more to get the car rolling and so its difficult to drive around town. Some have installed and then had removed. If it was a track only car then maybe, but for street i decided not to do it.
I think you have rotors coming, so that will help, Also, if you dont have gears already, the 3:33's are nice. I heard roller rockers add about 30 rwhp.
You'll either get to a point where you just happy with it and leave it be, hope it doenst break. Otherwise you'll have to go to your other plan and build the motor, spend some big money and get 900-1000rwhp.
05' SRT10 Copperhead #019/300
674 rwhp/631 rwtq- Paxton
Old 04-14-2008, 08:32 AM   #3
Racer Robbie
New England VCA Member
Racer Robbie's Avatar
Right on Mike. the heaver OEM flywheel has more rotating mass therefor making it easier to drive on the street from a stop. On the track you are running at high RPM's therefor a lighter flywheel and clutch assembly has great benefits as there is less rotating mass. Chuck Tator has told me many times that he only installs factory OEM flywheels, pressure plates, and clutches with good reason. give him a call to discuss.
Rob Rossiter
AtRo Racing
203-641-8569
Old 04-14-2008, 09:03 AM   #4
PJJP
TX VCA Member
PJJP's Avatar
I keep going back and forth on the flywheel thing. I would like to find someone locally who has one and would let me drive it so I can see how it is in daily driving.
Mike, I was not aware you could do roller rocker on the Gen3. I will probably stick with my 3.07 gears for now.
Old 04-14-2008, 09:41 AM   #5
robbie is right on this one. call tator and ask him why not to use a lightweight flywheel
Old 04-15-2008, 09:47 AM   #6
mjorgensen
The Viper has more than enough torque to use a light flywheel with no ill effects. The heavy flywheel will help powerless cars but the Viper is definitely NOT that.
Old 04-15-2008, 09:51 AM   #7
PJJP
TX VCA Member
PJJP's Avatar
seems like there is no consensus among everyone. I think if I can drive one, I could make my decision in about 10 minutes....
Old 04-15-2008, 10:25 AM   #8
viperbilliam
TX VCA Member
PJJP, it's very hard to get a strong and clear consensus with this motley bunch! I've wondered about the lightweight flywheel but I don't want to do anything that might contribute to drivetrain lurching.
2005 Commemorative Edition; other hot rod; 2007 Chrys 300C. Two bikes - 97 Harley Superglide & 06 Honda 1KRR.
viperbilliam is offline   Reply With Quote
Old 04-15-2008, 10:31 AM   #9
Andrew/USPWR
Andrew/USPWR's Avatar
It's great for the track but not for the road. I took mine off my GTS.
2005 Silver SRT/10
2000 Steel Gray GTS (sold)
Old 04-15-2008, 10:37 AM   #10
VIPER GTSR 91
VIPER GTSR 91's Avatar
I had a light weight flywheel installed several years ago on my 99 and am very happy with it and have had zero problems in both street and track use. I noticed right away that the revs come quicker.Plus the reduced weight
HOUSTON VCA MEMBER
VIPER GTSR 91 is offline   Reply With Quote
Old 04-15-2008, 10:53 AM   #11
Steve 00RT/10
Steve 00RT/10's Avatar
49,000 miles so far with lightweight flywheels on 2 different cars. One of them has 19" tires, making the effective rear end ratio a 2.92. Absolutely zero drivability issues. I've started a few xcrosses in 2nd from 1500 RPM (not the 2.92 car) and spun till I lifted. I have done this with both 3.07s and the 3.45s in there now. As a test, I've also started from a stop in our neighborhood in 4th gear (3.45s). A little tricky, but very little slippage overall from a very low RPM start. Even with the flywheel, the Viper is probably the easiest clutched vehicle I've ever owned...and I've never been without one since the 60s.
Unless your new to a clutched car, it's hard for me to fathom the lurching thing. All stock flywheeled Vipers buck a little in 1st sometimes -- especially before completely warmed up.
IMO, the flywheel definitely adds to the package. Instant throttle response...I would guess like bigger throttle bodies provide. Better / shorter braking -- which counts on the street as well for a safety factor. Less rotating mass to stop.
Steve
Old 04-15-2008, 10:54 AM   #12
anaconda666
I have one on my 98 GTS. Great for matching revs on down shifting, not so great if you make a slow upshift, and it definately "lurches" at low rpm's. All in all, I don't know if it is beneficial. It was on the car when I purchased it. Ron.
anaconda666 is offline   Reply With Quote
Old 04-15-2008, 11:04 AM   #13
redtanrt10
So Cal VCA Member
redtanrt10's Avatar
My understanding is that you will show a slight increase on a dyno as you have less drivetrain loss with a lightweight flywheel.
You definately will feel the car rev quicker. I've got one on my Gen I, Gen II and Gen III,
no issues with street driving.
94 RT/10 (Red-Tan)
99 GTS-ACR (Red)
06 SRT-Coupe (Red/Silver RIP #101215)
06 SRT-Coupe (Red/Silver)
redtanrt10 is offline   Reply With Quote
Old 04-15-2008, 03:47 PM   #14
Coloviper
CO/UT VCA Member
Coloviper's Avatar
Installed the Fidanza Lightweight Flywheel and 3.55 gears to my stock 06' Viper. It is great and revs way, way quicker. Much improved kick in the pants and the way the car should have been delivered IMHO.
Bucking or lurching is minimal but will happen in some real low RPMS in the first few gears. Once it starts bucking, you just push in the clutch and let it out smoothly. Bucking goes away instantaneously. Honestly I feel the minor bucking or lurching comes more from the gear change than the flywheel.
I guess I am pretty use to this action from my S351R Saleens and other hi-Po cars I have owned with short gears.
As far as reliability, it is just fine so far. In town driving is not affected, but then again I am very use to this set-up.
Coloviper is offline   Reply With Quote
Old 04-15-2008, 04:37 PM   #15
Viper X
So Cal VCA President
Old topic. Lots of info in the archives.
More a matter of preference.
My 02 cents, don't do a light flywheel on a Paxton car.
Do a light flywheel on all N/A cars, you will feel the difference. You may have a short "re-learning to drive the car" period (took me 5 minutes the first time).
In my 06 coupe with a light flyweel / stock clutch, you can get the car moving by just letting the clutch out, no revs necessary, no problems driving it.
FYI, the 2008 car has a lighter flywheel / clutch assembly than others before it.
Dan
2006 VOI9 Coupe
Anyone selling a lighter flywheel for a gen3? bigmike32172 SRT10 and SRT10 Coupe Discussions 6 02-10-2007 08:31 AM
Flywheel question mntngts99 RT/10 and GTS Discussions 10 05-15-2006 05:39 AM
Lightweight flywheel question MoparMan RT/10 and GTS Discussions 16 12-12-2003 05:39 PM
Lighter flywheel? varanus RT/10 and GTS Discussions 33 09-27-2003 06:51 AM
Flywheel question Fiorano RT/10 and GTS Discussions 11 12-21-2002 03:24 AM
