Old 04-25-2008, 10:55 PM   #1
PJJP
TX VCA Member
PJJP's Avatar
Location: See avatar above because you will not be able to read my plate from your distance behind me.
Default Paxton Supercharger 10lb pulley
Anyone running this? I saw it on the racing solutions web site. will this put me over the limit for the stock bottom end?
'06 Red Vert - Bone Stock "making headlines, scaring passengers, and offending decent people on the street"
PJJP is offline   Reply With Quote
Old 04-26-2008, 12:09 AM   #2
Paul Hawker
Paul Hawker's Avatar
Default Re: Paxton Supercharger 10lb pulley
Tread very lightly on increasing the stock Paxton output without beefing up your internals and driveline. The stock Paxton comes very close to being the maximum output while still being very reliable.
Paul Hawker, San Diego
Baby you can drive my car,
beep beep, beep beep YEA!
VCA # 05669
Old 04-26-2008, 12:45 AM   #3
ILLSMOQ
sounds very interesting...Doug Levin has answers to this, give him a call
ILLSMOQ is online now   Reply With Quote
Old 04-26-2008, 07:07 AM   #4
yeah call DLM . 305-249-7223 id be more worried about the fuel system but im sure the bottom end is close to its end at that point. but doug WILL have those answers for sure.
Old 04-26-2008, 09:25 AM   #5
Bobpantax
FL VCA Member
Bobpantax's Avatar
Yes. Minimally you will need to change out your pistons. And, as stated above, give one of our sponsor tuners a call. Doug's in Florida. Dan Cragin is in California.
Things go better with boost.
Bobpantax is online now   Reply With Quote
Old 04-26-2008, 09:30 AM   #6
ILLSMOQ
what you'll "need" to do depends on your tune.
Old 04-26-2008, 02:19 PM   #7
PJJP
TX VCA Member
PJJP's Avatar
I was actually curious if more boost + a more safer/conservative tune would still be ok for a net small net increase in power. I will call Doug next week.
Old 04-26-2008, 11:11 PM   #8
ILLSMOQ
I have a "conservative" tune.....With the stock pully I saw low 11/high 12 AFR. With the 10 pound pully I see mid 11's on a warm day and 12.0's on a colder day.
Data logging with the LM1 wide band
Data loggin with the split second R4 program
here is a pic of the pully
not much to look at...but the trained eye can pick it out as I found out last night. I was hoping to keep this one a secret for a while but, Mr 2002 GTS ACR knows his supercharged vipers pretty well
Old 04-26-2008, 11:12 PM   #9
ILLSMOQ
oh and I run a 50/50 mix of 100/91 octaine or better...
Old 04-26-2008, 11:20 PM   #10
black mamba1
NY / CT VCA Member
black mamba1's Avatar
Does that higher octane mixture actually help? Going to too high an octane can actually hurt power if u dont have the c/r to take advantage of it....flame propagation may not have enough time to reach its optimal temp. U done dyno's with and w/out this mixture?
Old 04-26-2008, 11:26 PM   #11
ILLSMOQ
We drive these things pretty hard out here, I'm willing to give up some HP for some added safety.
This is the fuel mixture I run in this car...so yes, all of my dyno runs with the SC have been with this fuel...I'm due to dyno it again...currious to see if I break the "700" mark.
Old 04-27-2008, 06:48 AM   #12
PJJP
TX VCA Member
PJJP's Avatar
So...you actually have this installed...was this your 'secret weapon'?
good to know I will not be the test rat. I will be running on 93 octane.
I bet you hit the 700 mark. Please let us know.
Old 04-27-2008, 07:01 PM   #13
MikeR
MikeR's Avatar
Yep, he made up his loss to me with the pulley and 3:55 gears. Now he edges me out, where I had him pretty good before. And when his lighter rotors get here next week, he will definatley leave me behind. My reign was short lived, oh well, guess I need a pulley now too.
05' SRT10 Copperhead #019/300
674 rwhp/631 rwtq- Paxton
Old 04-27-2008, 07:14 PM   #14
ILLSMOQ
any bets as to who pops a motor first???
Old 04-27-2008, 07:33 PM   #15
ILLSMOQ
If you intend to make this pulley change you may want to look into switching over to the ati damper as well. The stock damper is not that strong and quite a few have had them break or crack. The smaller pully will put more stress on the stock damper. Doug urged me to swap the damper and I had reason enough to change it just from reading posts on this site about the stock one breaking.
One thing worth noting on the ati damper.....it needs to be machined for the SRT timing cover. If it is not machined it will make contact with the cover and that could be a problem. I ended up getting the pully, belt and damper from Doug and the roe crank pin kit from roe racing. When I installed the parts I saw what Doug ment about the necessity of machining the damper. Everything fit perfect.
call Doug.
Wanted...10lb Roe s/c pulley 1TONY1 RT/10 and GTS Discussions 2 09-09-2007 03:47 PM
Drag times, fuel questions with 8lb/10lb Pulley on Roe blower Schulmann RT/10 and GTS Discussions 14 07-28-2006 08:16 AM
Underdrive pulley + Paxton = ? Vipermann SRT10 and SRT10 Coupe Discussions 0 04-06-2006 07:42 AM
Supercharger, What's the difference between 5, 7 or 8 PSI pulley? HARDVIPER RT/10 and GTS Discussions 37 07-13-2004 07:24 PM
Has anyone thought of doing this to pin a Paxton pulley ab RT/10 and GTS Discussions 2 12-25-2003 03:31 PM
