Old 05-15-2008, 02:05 PM   #16
black mamba1
NY / CT VCA Member
black mamba1's Avatar
Default Re: At 4000 rpm in second before she hooks up?
Originally Posted by Paul Hawker View Post
Another option, but much less fun, is to roll on the throttle.
Snapping on the throttle out of the hole can break loose the tires, and once set spinning, they are hard to stop.
Same thing in second. Let out the clutch just a hair slower, and roll the throttle on. You might be able to get more power down this way.
Oh, yeah, congratulations on having an exceptionally well running Viper.
The reason the Paxton guys don't spin so much is because the power comes on smoothly, no snap.
Thanks!
I am gonna go and try this tactic today.
blk 04 SRT bullet-proof NA motor by Tator, ported heads, comp cam, Belanger exhaust, VEC 3, comp oil pan, roll bar, nav, 08 Lemke hood, 528 rwhp/537 rwtq
black mamba1 is online now   Reply With Quote
Old 05-15-2008, 02:06 PM   #17
black mamba1
NY / CT VCA Member
Originally Posted by softuff View Post
What kind of tires are you running?
I know the PS2's suck when the temps below 50......We have an 800HP Ford GT and don't have the problems you describe....I did however have the exact same problem with my previous daily driver(Z06),but it was because of the tires....PS2's.
Good luck and be careful
I run PS2's, I really lov em! You get traction w/ an 800 hp Ford GT? Wow! Does the engine being in the back really help that much?
Old 05-15-2008, 02:08 PM   #18
black mamba1
NY / CT VCA Member
Originally Posted by MikeR View Post
I could spin tires thru 3rd gear if I tried when I was at 500 rwhp N/A. And at the drag strip I had to modulate power. Mash the gas and you get 2.2 + 60 fts, modulate and you get 1.8 60 fts no problem. When I leave a light I actually kinda bog it, so that I dont spin and I beat most people out of the hole. Modulate and I dont power shift the 1-2. 2nd gear Ill modulate until above 4k, then I m hammering it thru third gear.
Also, the warmer it is, the better your tires will stick, get some stickier tires, ditch the runflats. Also, check your airpressure. I run 30lbs cold in rear on the street. At drag strip I run 25lbs hot.
Hey Mike, what do you mean when u say you "kinda bog it"?
Old 05-15-2008, 03:00 PM   #19
Paul Hawker
Paul Hawker's Avatar
10-15% slip is the goal. Wild spinning gets you nowhere. No spin = bog.
Just a bit of slip is the best.
Paul Hawker, San Diego
Baby you can drive my car,
beep beep, beep beep YEA!
VCA # 05669
Old 05-15-2008, 05:47 PM   #20
Viper X
So Cal VCA President
Paul and MikeR are both correct,
Slip the clutch a bit, spin the rears just a little bit, kinda bog it and go. Learn to roll on the throttle, not stab it, unless you want to spin big time.
PS2's are OK tires when warm but not very sticky for bigger power in the lower gears. Lousy when cold - traction wise.
Someone said the magic word in this post, "Kumho's". Very hard to beat on the street for traction. Very, very sticky with reasonable wear.
I can get 0 to 60 times around 3.0 seconds in my Paxton car with Kumho's and a good take off procedure in warm weather. Very little spining if I do it right. If I get too excited (and we all do at times), my tires will go up in smoke and my engine hits the rev limiter in about 1 second (it seems like it anyway).
Keep working on it.
Dan
2006 VOI9 Coupe
Old 05-16-2008, 08:23 AM   #21
black mamba1
NY / CT VCA Member
This is a good discussion, cuz it also helps to keep the car straight. I got my ass kicked from 0-60 by an M3 about a month ago b/c I wasnt really focusing and simply stabbed it, fishtailed, left, fishtailed right, then simply had to get out of it. The M3 was a car and a half in front of me by then.
My revs build up so fast my tach gage cannot keep up when I simply stab it like that, the rev limiter kicks in before the gage is actually at 6000 rpm, which makes it difficult for me to actually know when to shift.. Is this normal?
Old 05-16-2008, 10:48 AM   #22
softuff
Being a mid engine does indeed help traction somewhat....but the bigger factor is gas pedal modulation....and slipping the clutch.
Just keep practicing.....you'll get it!
softuff is offline   Reply With Quote
Old 05-16-2008, 09:58 PM   #23
black mamba1
NY / CT VCA Member
I see why so many guys actually crash these cars....I have had my car for a year and a half but I have not ever received this much advice on how to launch my Viper. This is great! Maybe its purely my fault for not reserching previous threads, but no one has ever flat out TOLD me how to launch this powerful ass car from the dig with skill. My buddies up here either dont know much more than me, or they are keeping their launch skills a closely guarded secret.
Forgeline 18" VR-1. Bulk Order In Place. Under $4000/set JonB - PartsRack New Products, Supplier Specials, and Group Buys 2 04-20-2006 09:45 PM
What mods what you guys do with about $4000. Martin2000GTS Performance Modifications 33 12-14-2004 12:44 AM
Question about pinging at WOT and at higher RPM (4000 or more) only! Toronto_ACR RT/10 and GTS Discussions 16 06-08-2004 10:19 PM
Shelby Cobra CSX 4000- What do you think? NascarDave RT/10 and GTS Discussions 17 02-25-2004 11:28 PM
strange smell ~3500-4000 rpm.. phiebert Interior and Exterior 2 11-01-2000 12:23 PM
