Old 05-14-2008, 07:57 PM   #1
black mamba1
NY / CT VCA Member
black mamba1's Avatar
Question At 4000 rpm in second before she hooks up?
When I accelerate hard from a dead stop I spin 70% thru first, then I shift into second..and spin all the way to 4000 rpm. I am actually in second gear only about 2 sec before I redline..then I shift to third. A buddy of mine says something is not right, but I am easily at 100-110 mph or so by the time I hit third gear. I had Tator check my tires about 3 weeks ago, he said they are fine.
Is this normal for a 528 rwhp SRT?
black mamba1 is online now   Reply With Quote
Old 05-14-2008, 09:04 PM   #2
bluestreak
Default Re: At 4000 rpm in second before she hooks up?
Is this a complaint? Most guys complain about not enough wheelspin. If your car is spinning the tires like that in 1rst and second, means it's healthy and strong, time for some better tires.
bluestreak is offline   Reply With Quote
Old 05-14-2008, 09:35 PM   #3
Blainne
This is pretty normal for any car with a manual tranny and 500+ horsepower. Your first 3 gears are gonna be hard to prevent severe wheel spin and keeping the nose of your car pointing forward under full acceleration.
A day of practice at a local drag strip focusing on your 60ft times may help you find the best launch technique. Mashing your gas pedal to the floor is a bad idea of a launch technique. A gentle feathering of the gas pedal and a proper release of the clutch are the key to keeping your tires within their limit of grip which isn't an easy task on street tires.
Blainne is offline   Reply With Quote
Old 05-15-2008, 12:12 AM   #4
black mamba1
NY / CT VCA Member
Thanks guys, your info is really helpful. I see youtube videos of guys drag racing and it seems they are in 2nd gear longer than me. But my car seems to be really strong, stronger than after I dynoed it a while back. She never used to spin like this, even when I had run craps, now she spins and pulls really hard.
I dont see how the supercharged and turbo charged guys have any luck keeping an 700 rwhp or 900 rwhp under control. My car is a handful as she is!
Old 05-15-2008, 12:24 AM   #5
Russ M
I see a retaining wall in your near future unless you learn to modulate the gas pedal considerably better.
Remember just because you can floor it 100% of the time does not mean you should.
Russ M is offline   Reply With Quote
Old 05-15-2008, 12:54 AM   #6
black mamba1
NY / CT VCA Member
You are probably 100% correct. I cannot get used to "feathering" the power thru first and second, I just stomp it.. I have managed to keep her straight enough to avoid the retaining walls so far, but it has been a challenge.
So what you are telling me is that w/ 528 rwhp I should not keep her floored thru the first two gears?
Old 05-15-2008, 01:03 AM   #7
Blainne
Not a good idea. Full Throttle is possible, but only if you ride the clutch. But then you'll have a new clutch in your distant future. Pedal Modulation during wheel spin is best; once you get enough speed that your tires shouldn't break loose.. then you can floor it. I've even known some peaple at the drag strip start off in 2nd gear to lesson wheel spin. or you can slap on some drag slicks, but then you'll have a rear diff in your future...
Old 05-15-2008, 07:08 AM   #8
wallbanger
North Texas VCA Member
wallbanger's Avatar
You could upgrade the diferential.... the 08 diferential is a major upgrade....Many times i have launched hard from a stop full expecting tire spin BUT the car just launched amazingly hard
wallbanger is offline   Reply With Quote
Old 05-15-2008, 10:03 AM   #9
MikeR
MikeR's Avatar
I could spin tires thru 3rd gear if I tried when I was at 500 rwhp N/A. And at the drag strip I had to modulate power. Mash the gas and you get 2.2 + 60 fts, modulate and you get 1.8 60 fts no problem. When I leave a light I actually kinda bog it, so that I dont spin and I beat most people out of the hole. Modulate and I dont power shift the 1-2. 2nd gear Ill modulate until above 4k, then I m hammering it thru third gear.
Also, the warmer it is, the better your tires will stick, get some stickier tires, ditch the runflats. Also, check your airpressure. I run 30lbs cold in rear on the street. At drag strip I run 25lbs hot.
05' SRT10 Copperhead #019/300
674 rwhp/631 rwtq- Paxton
Old 05-15-2008, 10:17 AM   #10
softuff
What kind of tires are you running?
I know the PS2's suck when the temps below 50......We have an 800HP Ford GT and don't have the problems you describe....I did however have the exact same problem with my previous daily driver(Z06),but it was because of the tires....PS2's.
Good luck and be careful
softuff is offline   Reply With Quote
Old 05-15-2008, 10:22 AM   #11
STUGOTS
kumhos!!!!!!!
STUGOTS is offline   Reply With Quote
Old 05-15-2008, 11:20 AM   #12
MikeR
MikeR's Avatar
Almost any tire under 50 degrees, will suck if you have big power. My Paxton Viper is close to 800hp and I use the PS2's. I love them. They stick. I do run a bigger 20" tire, its about .7" taller then stock.
Old 05-15-2008, 12:50 PM   #13
softuff
Don't get me wrong.....the PS2's are great when it's warm,but they do drop off in grip when it's cold more than any other tire I've ever used.
The PS2's even have a warning label stating something to that effect.
Old 05-15-2008, 01:41 PM   #14
Paul Hawker
Paul Hawker's Avatar
Another option, but much less fun, is to roll on the throttle.
Snapping on the throttle out of the hole can break loose the tires, and once set spinning, they are hard to stop.
Same thing in second. Let out the clutch just a hair slower, and roll the throttle on. You might be able to get more power down this way.
Oh, yeah, congratulations on having an exceptionally well running Viper.
The reason the Paxton guys don't spin so much is because the power comes on smoothly, no snap.
Paul Hawker, San Diego
Baby you can drive my car,
beep beep, beep beep YEA!
VCA # 05669
Old 05-15-2008, 02:04 PM   #15
black mamba1
NY / CT VCA Member
Ok, this makes me feel much better since the car is actually performing as expected. But now drag racing just got much harder! I actually have to know what I am doing...no more simply flooring it like I did my Vette in my previous mentally challenged life.
This is going to take quite a bit of practice I see, and explains why really good guys like Jamie Furman and MikeR , IllSmoq, ViperX (just to name a few) get really good times at the drag strip...and why some guys continue to get 12.4 or 12.5 even, even with mods.
So, in first and second do you guys try to prevent wheelspin altogether? Or simply reduce it as much as possible for the best times?
Forgeline 18" VR-1. Bulk Order In Place. Under $4000/set JonB - PartsRack New Products, Supplier Specials, and Group Buys 2 04-20-2006 09:45 PM
What mods what you guys do with about $4000. Martin2000GTS Performance Modifications 33 12-14-2004 12:44 AM
Question about pinging at WOT and at higher RPM (4000 or more) only! Toronto_ACR RT/10 and GTS Discussions 16 06-08-2004 10:19 PM
Shelby Cobra CSX 4000- What do you think? NascarDave RT/10 and GTS Discussions 17 02-25-2004 11:28 PM
strange smell ~3500-4000 rpm.. phiebert Interior and Exterior 2 11-01-2000 12:23 PM
