Well, I took the Viper out for a drive yesterday and when I got it up on my lift I noticed that the drivers side rear corner of the oil pan has just a tiny smear of oil that ran from the rear bolt. The bolt head is also wet. Anybody know what a dealer charges to replace an oil pan gasket? How hard is it to replace yourself?
the gen 2 vipers were known to have problems with the original oil pan gasket. I just had mine replaced at a local dodge dealer for my 02 RT/10. fortunatley I purchased the extended warranty years ago. the list price for a replacement gasket from dodge is $185 (commonly referred to as financial rape). there is a certain type of sealant that should be placed on the bolts holding the oil pan in place as well. don't remember the name of it. it is very easy to replace if you have access to a lift. there is nothing in the way of it when removing it (i.e. exhaust pipes). naturally you will have to change the oil as part of the job. the bolts I believe should be torqued to 29 ft-lbs. I have the service manuals for the 2002 vipers. I would have to double check that specification. do you have a gen 2 viper?
Mine's a gen III, I've got a lift and was going to change the oil next weekend. I figured if it wasn't too bad I'd go ahead and swap out the gasket too.
First I've read about on the Gen 3. On my Gen 1 when this happened, I first cleaned the area with starting fluid, took out the bolts that the leak was coming from, added a dab of Red High Temp RTV, and torqued to specs and no more leaks. As stated above, Viper tax on this gasket is ridiculous.
VIPER - It's NOT a car - it's an OBSESSION! '05 SRT Dark Kandy Red Street Serpent. '93 RED RT/10 - Sold. |
#5 | |
Are you still under warranty? 2003 have a 7/70 warranty on power trains. You did not say what year your viper was.
Rob Rossiter AtRo Racing 203-641-8569 |
Mine's an 04
| Oil Leak - Retainer Gasket | my viper | RT/10 and GTS Discussions | 1 | 11-09-2006 07:28 PM |
| Oil Leak - timing cover gasket | my viper | RT/10 and GTS Discussions | 8 | 09-09-2006 05:54 AM |
| OBDII code P0456 - Evaporative emission leak detected (very small leak). | AviP | Driven | 1 | 10-14-2005 06:08 PM |
| Oil leak from head gasket on 2001 GTS...help! | MichaelP | RT/10 and GTS Discussions | 0 | 05-20-2002 08:48 PM |
| Head Gasket Leak REPAIRED!! | Roland L-Ocala, FL | RT/10 and GTS Discussions | 6 | 02-03-2002 10:18 PM |
