My 08 coupe just developed a rattle that sounds like it is coming from the instrument cluster area. It seems to happen when you hit bumps in the pavement. I will hold the shifter and see if that helps
#17 | |
rattle in dash is the defroster duct i have the old tsb from 2003 saved in my email put dont know how to post it here. can someone help or give me a email and ill forward it on to you. easy fix with the directions and photos. thanks Benny
yea i have the same rattle and it is the center defroster duct,,, some days it rattles some days it doesn't
#20 |
My '08 has the same rattle - appeared after 1200 miles. It is the defroster vent. I haven't had the time to fix it. Can't be that difficult. Just fixed the same rattle in my Jetta diesel – two years to get to it – one hour to fix.
#21 | |
Also seems closest to the AC vents. Will check with the dealer to see what they think. |
#22 |
I had the defroster vent rattle on my 04, I can't believe they are still putting the same part in knowing that it was too long and rubbing up against the housing. It is indeed avery easy fix, you have to pop out the defroster vent, and shave off the bottom edge of the plastic and put it back in. The TSB number is 23-027-03 NOV 03
06 VCA Coupe #38 04 Black Mamba #171 from Woodhouse (Sold) 02 FE GTS #173 (Sold) |
#23 |
TX VCA Member
My 08 vert has/had a dash rattle that was intermittent but we seem to have isolated it as being the windshield defroster vent.
#24 | |
Charlie |
#25 |
I had thec same problem with my 08 coupe. It was making me crazy so I purchased TSB 23-027-03 for a 03-04 car from All DATA.Ifollowed the instructions and removed the deforster duct. I was a little surprised at what I found. The flange on the duct was already grinded at the factory. It was not done well. It was uneven. I inserted a grinding attachment on my dremel and sheared off additional material on the flange. I reinstalled the duct took the car for a test on a rough bumpy road and to my statisfaction the rattle was gone. It seems that the factory is using the same part as they did on the 03 cars and grinding it. If they did not take off enough material on the duct in your car you will have a rattle because the duct will touch the deforster grill.
#26 | |
FTW Carl Bartlett 530-682-0871 |
#27 | |
Do you know what the torque settings are for the sway bar bolts....
#28 | |
08 Vert venom red, grey interior, razor wheels Previous - 06 RAM SRT10 & SRT6 |
#29 |
There is actually a tool that the dealers use, (trim removal tool), I don't know exactly what it looks like. You should be able to get under it and lift it.
#30 |
No sorry I dont. My local Viper Tech is the one who took care of it.
| 06 coupe dash rattle | BennyBad | SRT10 and SRT10 Coupe Discussions | 10 | 12-06-2006 08:23 AM |
| Defroster / Dash rattle | PaViper | SRT10 and SRT10 Coupe Discussions | 3 | 08-05-2005 11:48 AM |
| 04 SRT-10 DASH RATTLE! | RonnieSRT10 | SRT10 and SRT10 Coupe Discussions | 3 | 11-08-2004 02:31 PM |
| Rattle in Dash | Greg 99ACR Red and Silver | SRT10 and SRT10 Coupe Discussions | 2 | 09-02-2004 10:31 AM |
| REAR SQUEAK & DASH RATTLE...ANY IDEAS??? | DEVILDOG | RT/10 and GTS Discussions | 1 | 02-29-2004 04:37 PM |
