Old 08-14-2008, 03:33 PM   #1
Malu59RT
TX VCA Member
Malu59RT's Avatar
Default 08 ETC/MIL Light ?
The shop that's doing work on my car, called to let me know that my 2008 Viper's Electronic Throttle Control(ETC) light, and MIL light are on. No indication that the ETC light was flashing, but the car is seeing reduced engine power. Any thoughts on what could cause this? The bumper has been off of the car, the mufflers replaced with a straight pipe, and lowering caps installed, and that is it as far as modifications to the car.
My only thought was the straight pipe, but all of the cats are untouched. I can't imagine this causing issues, but even if that were the case, would the ETC light come on? Thanks for any and all help.
Malu59RT is offline   Reply With Quote
Old 08-14-2008, 03:40 PM   #2
pe5787
Default Re: 08 ETC/MIL Light ?
It was the cam sensor for my brothers ACR and several other 08s in the area.
pe5787 is offline   Reply With Quote
Old 08-14-2008, 03:42 PM   #3
rcl4668
rcl4668's Avatar
Malu --
Sent you a pm.
/Rich
Old 08-14-2008, 04:16 PM   #4
Malu59RT
TX VCA Member
Malu59RT's Avatar
PM replied, thanks Rich
Old 08-14-2008, 04:22 PM   #5
Malu59RT
TX VCA Member
Malu59RT's Avatar
my car has already had the flash performed, so I don't think that is the problem
Old 08-15-2008, 06:10 AM   #6
pe5787
He also had the flash and it was the cam sensor. It needed to be replaced. Good luck.
Old 08-15-2008, 06:18 AM   #7
Malu59RT
TX VCA Member
Malu59RT's Avatar
Well now I have a couple of things to look for. Thanks for the help!
Old 08-15-2008, 06:41 AM   #8
pe5787
No problem. Its a bummer that it happend. FYI - His light went off at 50miles.
Gas Light BigSaleen SRT10 and SRT10 Coupe Discussions 6 02-24-2006 12:03 AM
looking for a fog light that will fit a 94 RT/10 beretta1 RT/10 and GTS Discussions 3 05-30-2003 03:14 PM
check engine light was on, drove the car, light is off, what does it mean??? striker79 RT/10 and GTS Discussions 1 09-16-2002 11:03 PM
Let There Be Light!!, (H.I.D. light for Vipers that is)... Sean Roe New Products and Supplier Specials 1 11-29-2000 07:02 AM
Let There Be Light!!, (H.I.D. light for Vipers that is)... Sean Roe Archive Management 0 11-28-2000 07:21 PM
