Old 09-04-2008, 03:03 PM   #16
PaViper
PaViper's Avatar
Default Re: Clunking from the rear when going over bumps?
Originally Posted by Viper Wizard View Post
This is what I have found for that right rear rattle: Remove you right rear inner fender well/skirt and directly above the tire you'll see a bolt hanging down, it will be a 13mm on top, see if that is loose? If so tighten it up and see if your rattle is gone? That bolt has been the source for rattles on 7 or 8 Vipers so far!
I will be checking that this weekend, if that is what it is, you truly are "the Wizard", but then we already knew that
06 VCA Coupe #38
02 FE GTS #173 (Sold)
Hood Paint Bumps 94 RT/10 sdaddy RT/10 and GTS Discussions 5 01-11-2007 07:51 PM
Clunking in rear end DviperX RT/10 and GTS Discussions 29 11-01-2004 06:46 PM
speed bumps? Eulogy RT/10 and GTS Discussions 2 08-23-2004 09:53 AM
Clunking rear end when shifting after 3.55 installl - Could be normal. djemcee SRT10 and SRT10 Coupe Discussions 4 07-31-2004 08:44 PM
Help Needed with Loud Clunking sound at rear under hard accel???? SF Final 286 RT/10 and GTS Discussions 10 05-29-2004 05:43 PM
