Old 09-02-2008, 02:38 PM   #1
adg44
Default Clunking from the rear when going over bumps?
It seems like it's the convertible top or something similar, but I hear a clunking coming from the right rear of the car when I go over bumps. The previous owner took the car into the dealer for this and the report said they found it to be normal for the convertibles.
Can anyone confirm this?
- Anthony
adg44 is offline   Reply With Quote
Old 09-02-2008, 02:44 PM   #2
Fast Too
Fast Too's Avatar
Default Re: Clunking from the rear when going over bumps?
Sure it is not coming from under the car like from a half shaft or a bad shock?
'06 SRT-10 Coupe
Old 09-02-2008, 11:07 PM   #3
adg44
Not sure... it sounds like it's the convertible top clunking a bit, but I doubt it would move when it's latched down in place.
It sounds like a suspension clunk to be honest. It's pretty noticeable.
Old 09-03-2008, 05:55 AM   #4
PaViper
PaViper's Avatar
It is not just the convertibles, my 06 coupe and my previous 04 Mamba vert had the same sound, right rear over choppy bumps.....have yet to find out what it is
06 VCA Coupe #38
02 FE GTS #173 (Sold)
Old 09-03-2008, 08:50 AM   #5
Bobpantax
FL VCA Member
Bobpantax's Avatar
Since it is only over bumps, you might want to check the battery to see if it is secured properly. I have not heard of anyone having this problem but there is always a first time. I am assuming that you have a stock suspension - correct?
Things go better with boost.
Bobpantax is offline   Reply With Quote
Old 09-03-2008, 08:57 AM   #6
29OUTLAW
Just want to throw out there that when my passenger side seat belt is tangling behind the passenger seat, it rattles against the plastic piece behind the seat when I go over bumps. Took me a while to figure out where that noise was coming from.
29OUTLAW is offline   Reply With Quote
Old 09-03-2008, 08:58 AM   #7
adg44
The battery was previously replaced, so I will check that again. However isn't the battery on the drivers side?
And yes, I do have the stock suspension.
Old 09-03-2008, 08:59 AM   #8
TTviper
CO VCA Member
I have an '08 black coupe and had a similar noise where there was a bind then release...
It was tracked down to a bushing with the RR sway bar...
Terra
08 Black Coupe
TTviper is offline   Reply With Quote
Old 09-03-2008, 09:19 AM   #9
adg44
Yeah, I've noticed that too. However, this is a much, much louder clunking noise.
Old 09-03-2008, 09:21 AM   #10
Fast Too
Fast Too's Avatar
Good suggestion, although the battery is on the left. I guess it could make one think it is the right corner. I'd check that to as Bob suggests. Who knows.....
'06 SRT-10 Coupe
Old 09-03-2008, 09:24 AM   #11
Bobpantax
FL VCA Member
Bobpantax's Avatar
The battery is a bit to the left of the center as you face the rear of the car but I have found that the direction of the source of a sound is sometimes hard to determine in the Viper. Once you figure it out, please post.
Old 09-03-2008, 12:36 PM   #12
Peter Nielsen
NC VCA Member
Peter Nielsen's Avatar
I experienced the exact same thing in my '06 and never could figure out where the rattling sound came from. Since the rattle was way more obvious with the convertible top up, I incorrectly assumed it was the top that made the noise... Tom Sessions (my vipertech) quickly figured out that it was the seatbelt after taking the car for quick test drive
Anyway, I'd say that the seatbelt makes a rattle, not a clunk...
Peter Nielsen is offline   Reply With Quote
Old 09-03-2008, 06:43 PM   #13
adg44
I'm starting to wonder if this problem isn't related to this: 3rd gear whine
Old 09-04-2008, 09:23 AM   #14
Viper Wizard
Viper Wizard's Avatar
Question Re: Clunking from the rear when going over bumps?
This is what I have found for that right rear rattle: Remove you right rear inner fender well/skirt and directly above the tire you'll see a bolt hanging down, it will be a 13mm on top, see if that is loose? If so tighten it up and see if your rattle is gone? That bolt has been the source for rattles on 7 or 8 Vipers so far!
CHUCK TATOR
1975-USAF/SAC/KC-135/FB-111
NRA Life Member
Viper Tech Since 1993
Viper Owner 94/RT#902
TATOR'S DODGE SINCE 1914!
Old 09-04-2008, 09:26 AM   #15
adg44
Great, thanks. I will check that when I flush the brake fluid hopefully this weekend.
- Anthony
Hood Paint Bumps 94 RT/10 sdaddy RT/10 and GTS Discussions 5 01-11-2007 07:51 PM
Clunking in rear end DviperX RT/10 and GTS Discussions 29 11-01-2004 06:46 PM
speed bumps? Eulogy RT/10 and GTS Discussions 2 08-23-2004 09:53 AM
Clunking rear end when shifting after 3.55 installl - Could be normal. djemcee SRT10 and SRT10 Coupe Discussions 4 07-31-2004 08:44 PM
Help Needed with Loud Clunking sound at rear under hard accel???? SF Final 286 RT/10 and GTS Discussions 10 05-29-2004 05:43 PM
