Old 09-02-2008, 09:14 PM   #1
MuscleJunkie
MuscleJunkie's Avatar
Default Troubling Dyno results for Stock 2006???
Went today for the first dyno pull on my 2006 Coupe (all stock - 5K miles)
One the 1st run I noticed that the power significantly dropped about 4500rpm for just a min (it felt like a hesitation) and then it returned back to normal. I guess they didn't have the A/F gauge in so the run was not recorded.
Did two more runs and this was the result
Run 2: Max Power = 422.8 Max Torque = 416.8
Run 3: Max Power = 428.6 Max Torque = 423.9
I do not have access to a scanner right now but will tomorrow and will post the graphs but did notice the following.
1. A/F on both runs from 2k rpm was just below 15 and then started dropping at 3100. At 3500 it was at 12 then at 4000 it was at 11. At 4500 it was at 10.5 and stayed there the rest of the runs (only run 2). Run 3 dropped below 10 at 4600rpm then came back up just above 10 about 5300rpm
2. On run 3 the torque was at 410+ at 4600rpm then DROPPED to about 380 then climbed back up about 5300rpm
3. On run 3 there was a drop in HP from 360 to 330 and then back up matching run 2 around 5300rpm
It seems I have some sort of problem but not even sure where or what to start with.
Run 2 was very even but runs 1 and 3 were pretty much the same sort of issue.???
Thanks for any advice. I'll post the graphs tomorrow.
Oh regarding the "weather question" I am not sure exactly but it was a bit hot. I did hear the dyno owner say something about a 26.50 or 26.5. Not sure what that means.
I have used this dyno for my 01 Z06 and had good and expected results during those runs.
MuscleJunkie
** viper.jlaforums.com **
MuscleJunkie is offline   Reply With Quote
Old 09-02-2008, 09:57 PM   #2
adamlotus
Default Re: Troubling Dyno results for Stock 2006???
hp look normal for a stock 06 torque a little low imo
adamlotus is offline   Reply With Quote
Old 09-02-2008, 10:21 PM   #3
MuscleJunkie
Thanks for the response. Yeah I thought that the torque seemed off. The A/F seems to be really PIG RICH. Not sure what would be going on with this car to be getting this sort of dyno result?\\
What is the "actual" driveline loss figure for an 06?
MuscleJunkie
Old 09-02-2008, 10:29 PM   #4
pteam
OH VCA Member
pteam's Avatar
at 15% 428.6 = 504 hp 422.8 = 497
a little low for sure.
05 Viper VCA Special Edition #49 of #50 - 803 HP (683 rwhp and 617.6 rwtq) Paxton Supercharged by Woodhouse, DC SCT Tune, corsa, - 2 cats, ps2s, HID fogs, heated seats, limo tint -- 08 Hummer H2, Boxster S, 15 limos. previous: 03 viper, lambo murci
Old 09-03-2008, 06:06 AM   #5
Fast Too
Fast Too's Avatar
I had similar results on my base dyno before mods. Max power was like 417RWHP, I forget the TQ.
'06 SRT-10 Coupe
Old 09-03-2008, 06:56 AM   #6
+1 on low. My '01 GTS with tubes, K&N's & cat-back was 436 rwhp. You should be at that or greater I would think.
Check the weather here for what it was that day...
Weather History for RALEIGH DURHAM INTER, NC - The Old Farmer's Almanac
Old 09-03-2008, 08:21 AM   #7
MuscleJunkie
So for that I am guessing that temperature was between 87 and 90 and pressure was 26.50 (based off what he said his meter showed??)
Does any of that have anything to do with the low numbers?
MuscleJunkie
Old 09-03-2008, 09:24 AM   #8
Fast Too
Fast Too's Avatar
If it was humid you were trying to push some very thick air through which would drive your numbers down. It was in the 90's and very humid when I did a 417rwhp base dyno.
'06 SRT-10 Coupe
Old 09-03-2008, 10:57 AM   #9
MuscleJunkie
What do you guys think about the really low figure on Torque and it seeming to really dump fuel at 4500Rpm, etc. I am getting ready to post the graph and you will see what I mean. Its not too pretty.
MuscleJunkie
Old 09-03-2008, 11:09 AM   #10
Fast Too
Fast Too's Avatar
Not sure whats up on your torque, but most graphs I have seen, mine as well, the car starts pushing fuel around that RPM as you start building manifold pressure.
'06 SRT-10 Coupe
Old 09-03-2008, 11:30 AM   #11
MuscleJunkie
Ok, here is my dyno graph on this.
MuscleJunkie
Old 09-03-2008, 11:36 AM   #12
Fast Too
Fast Too's Avatar
Kind of hard to see what is going on the graph. Can your tuner e-mail you the actual dyno file so we can look at it in the winpep7 program. We can see other contributing factors to your dyno with that program such as conditions, your A/F through the pulls etc.
'06 SRT-10 Coupe
Old 09-03-2008, 11:39 AM   #13
MikeR
MikeR's Avatar
What kind of dyno was it on? Numbers seem low, especailly torque. I would think you would be somewhere around 430 rwhp/ 460 rwtq
05' SRT10 Copperhead #019/300
674 rwhp/631 rwtq- Paxton and I'm gay
Old 09-03-2008, 11:44 AM   #14
Fast Too
Fast Too's Avatar
Hopefully it was dynojet so we can look at the files if he can get them.
'06 SRT-10 Coupe
Old 09-03-2008, 11:45 AM   #15
Roadrunner
Ouch... if the pressure was 26.5" Hg.... that's only 670torr... sea level would be 760torr. You were lacking nearly 13.4% of available air due to low density. Power should have fallen similarly. Don't know what correction factor was being used at your dyno though.
Roadrunner is offline   Reply With Quote
mostly Stock Dyno Results Canyon707 Dyno Results 12 11-25-2008 01:26 PM
mostly Stock Dyno Results Canyon707 SRT10 and SRT10 Coupe Discussions 17 10-13-2007 02:46 PM
o2 rt/10 dyno results stock WANTED RT/10 and GTS Discussions 7 06-09-2004 08:18 AM
stock dyno results luv2race2 SRT10 and SRT10 Coupe Discussions 5 10-03-2003 12:21 AM
Dyno results for my stock '96 Tiepilot Viper Racing/Dyno Results/Time Slips 3 03-25-2003 07:49 AM
