Old 09-03-2008, 07:19 PM   #16
DAMN YANKEE
New York/Conn VCA Member
DAMN YANKEE's Avatar
Default Re: I'm too LOUD !! help !!
OK.....plugged cats....here we go.....anybody. everybody....each and evey one of them.....that has a plugged cat has something else too....an absolutely crappy tune. Why? because the fact is that LAMBDA is LAMDA....and your cats.....a good quality high flow cat can handle LAMBA tunes ( or close to it) for a long long time. I have seen O2 sensors go in ONE hour on some rigs.....I have seen cats go in ONE week....why? Fuel being dumped into them....TUNE IT or LOOSE IT. Track car? No Cats.....Race Car, same thing. Road Viper.....not an issue.
In "Golden Collection of Viper Tricks and Traps" thread....(just use the search function). I wrote the following...
Selecting Exhaust system, Cats and Headers...
Hang out long enough (5 minutes) around here and you will be asked to comment on which cat, cat back, header, muffler, etc. etc. etc. is the right one for you. You've seen 'em, they come in droves. Hey, its a bolt on and it changes something fast that everybody can hear......
Regardless of which brand, what materials, which component to start with, there is one Golden Rule that is so grossly overlooked that it deserves special mention....
If you are going to select your exhaust system or any of its components by the way it SOUNDS...judge it by WHAT IS HEARD FROM THE DRIVER'S SEAT. Do not select your system by how it sounds as it drives by as....you got it...you won't be hearing and living with it from there...unless you left your rig running in San Fran and forgot to pull up the parking break......then..that would be your rig you hear just before it hits the trolley...But, it sounded SO good before the screaming started.
Sound great outside.....best bet is that it will sound grating on the inside......Sound great on the inside....best bet is that YOU WILL BE HAPPY WITH IT.....
Old 09-03-2008, 08:18 PM   #17
2002_Viper_GTS_ACR
NorCal VCA Member
2002_Viper_GTS_ACR's Avatar
No bad tune, Woodhouse installed the SCT DC Performance tune for my setup.
Originally Posted by plumcrazy View Post
DLM told me to add a set of burns SS mufflers in place of the cats. i dont know the dimensions but he said they were small and made a decent difference. not cheap but the best quality too.
I'll look at those Burns SS mufflers. Possibly add the vortex cones too.
Jon
2002 Viper GTS ACR Graphite (Sold)
2005 Viper SRT-10 Black (Bought 4 Dad)
2006 Viper SRT-10 Coupe "Viper Slate Crystal Pearl Coat" (Woodhouse delivered 6/27/2006)
Old 09-03-2008, 08:34 PM   #18
Nader
NY VCA Member
Nader's Avatar
Call Sean Roe and ask him about his high flow cats. I have a set and 100% happy. I doubt he would selll product that underperformed or clogged.
Old 09-03-2008, 08:51 PM   #19
ILLSMOQ
I saw the title of the thread and thought "wow....he finally gets it" Then I opened the thread and realized you were actually talking about the car. Oh well.
As to your problem and possible fixes....
I've tried the following
Dynomax race bullets in different lengths - did little to muffle the engine
Burns Stainless - beautiful mufflers, same as dynomax for noise reduction, not very robust - these mufflers are intended to be placed at the back of an exhaust system and will not support other exhaust components for very long also the bolts that hold them together are very small and vibrate loose
Magnaflow - muffled good enough but the packing blew out after a while
Roe racing mufflers - muffled quite well and might even suite your needs but I don't see them listed on the roe site any longer....also they may be a bit on the long side for your project ( they look very similar to the dynomax 6" diameter ultra flow mufflers)
Aero turbine - these also muffle quite well. the 3030 would be the one you want to try.
The Roe (if you can get them) and the Aero turbine might work for you but I bet you have to cut most of the piping off them to get them to fit in front of your corsa. It will be a lot of work to get it all to fit in there and not contact the side sill.
I'd say get another set of cats in there. I have Talamos 3" LG motorsports cats(talk to him if you want them) that were on his car for 2 days and I have a set of stock SRT cats that were opened up to 3". Both sets are metal substrate.
your friend,
Old 09-03-2008, 08:53 PM   #20
ILLSMOQ
I'm pretty sure Jon had random tech metal substrates.....those are supposed to be the best cats out there right?
Old 09-03-2008, 09:20 PM   #21
Kai SRT10
Kai SRT10's Avatar
I use Dynatech Vortex cones.
Made a significant difference in volume (but they also stopped the flames from shooting out of my side pipes when I downshift.) Before and after dyno showed no difference. (lost 2 or 3 hp, gained 2 or 3 tq, which is within the margin of error for the dyno.)
Dynatech Vortex Insert Cones - summitracing.com
2004 SRT-10 609rwhp; 609rwtq, Naturally Aspirated
Old 09-04-2008, 08:46 AM   #22
FE 065
I used long (30"?) 6"OD Dynomax SS on my cat-less '94 Viper, trying both 2.5" and 3" ID. I think the packing's guaranteed for life. You'd never call it loud, though my car wasn't supercharged. That RT/10 had a nice deep and well muffled tone. If your Corsas are the type with no packing inside-just the RSC technology, you might consider using a muffler with as large an OD and as long a length as you can.
A guy who lives about a mile away makes these mufflers and swears they sound great. Haven't heard them on a car myself.
- If you've got access to a welder and want to experiment I've got an idea that might quiet it down and not restrict power at the same time. Something gleaned from Gordon Jennings' Two Stroke Tuner's Handbook of all places..
Old 09-04-2008, 08:51 AM   #23
2001 GTS
I use the moroso spiral flows, one on each side and it takes the harshness out but still sounds good.
Note: no cats for years, and the dynamax bullets barely did much.
Old 09-04-2008, 10:20 AM   #24
99 R/T 10
99 R/T 10's Avatar
The Moroso spiral flows would be a great choice and cheap too. If you have the room up front go with the Dynomax Ultraflows. Not sure of the 6" round muffler will fit though.
Old 09-04-2008, 10:43 AM   #25
FE 065
Looking at a Corsa Track photo, if the in and out tubing shown there is 3", then it looks like their mufflers could be at least 6"OD.
Old 09-04-2008, 11:19 AM   #26
Paul S Lacey
VCA President United Kingdom
Paul S Lacey's Avatar
On my GTS/R with a B&B full system and hi flow cats the Vortex Cones seemed to make no difference
Paul 2004 White Mamba #86
GTS/R #52 The Justin Bell Car
Audi RS4 Street Sleeper
PT Cruiser by Startech
Harley Davidson Street Glide with 1 of 200 paint
Full Time Score Tators 1 Chrysler 0
Paul S Lacey is offline   Reply With Quote
Old 09-04-2008, 12:15 PM   #27
copper57head
if its too loud your too old!!!!!!!! the harley guys give me looks and i love it!!!!
copper57head is offline   Reply With Quote
Old 09-04-2008, 12:23 PM   #28
pteam
OH VCA Member
pteam's Avatar
Originally Posted by MikeR View Post
He had hi-flow cats. As most are finding out, if you drive your car alot and hard, the cats plug up. Then you have a crappy running car with no power. This is probably the 20th post ive seen over last few months of cats plugging up on Gen 3's, some with big mods, some with minor mods. As much as Id like to quiet mine down some, I dont want cats that will just plug up and fail.
This is what I'm worried about as I have 2 cats removed. How do you tell when the cats start to go bad?
05 Viper VCA Special Edition #49 of #50 - 803 HP (683 rwhp and 617.6 rwtq) Paxton Supercharged by Woodhouse, DC SCT Tune, corsa, - 2 cats, ps2s, HID fogs, heated seats, limo tint -- 08 Hummer H2, Boxster S, 15 limos. previous: 03 viper, lambo murci
Old 09-04-2008, 01:05 PM   #29
put your hand behind the tail pipe and feel the pressure. if its less than another viper, you got a problem. DONT ASK HOW I KNOW THIS...lol
a tuner i know doesnt like cats on cars with 700 or more rwhp.
510 Stroker, Greg Good heads, DLM Paxton, Rebuilt and Tuned by DLM. Still need more boost......
Old 09-04-2008, 01:57 PM   #30
2002_Viper_GTS_ACR
NorCal VCA Member
or A dyno !!
Thats how I found out I was 90 RWHP down.
Jon
Too loud with top down? ViperGTS RT/10 and GTS Discussions 3 04-03-2007 06:40 PM
How loud is too loud???? ViperCrazed RT/10 and GTS Discussions 18 05-02-2006 02:32 PM
de cat but now very loud!! carl B RT/10 and GTS Discussions 1 06-15-2005 05:57 PM
Will this be loud enough? jp RT/10 and GTS Discussions 8 04-18-2002 09:27 AM
not very loud crayne hurst Archive Management 1 05-28-2001 05:42 PM
