#31 |
it might cost you an engine if its on the dyno and clogged though, dont let it get that far....
#32 | |
#33 |
How do you know when a cat goes bad?
Great question. First, how many actually know what a cat is doing? The cat is converting harmful gases to water and other more benign gases. The catalysts include:
![]() "The average light off temperature at which the catalytic converter begins to function ranges from 400 to 600 degrees F. The normal operating temperature can range up to 1,200 to 1,600 degrees F. But as the amount of pollutants in the exhaust go up, so does the converter's operating temperature. If the temperature gets up around 2,000 degrees F or higher, several things happen. The aluminum oxide honeycomb begins to degrade and weaken. The platinum and palladium coating on the honeycomb also starts to melt and sink into the ceramic substrate reducing its effect on the exhaust. This accelerates the aging process and causes the converter to lose efficiency." They can fail from essentially four reasons. 1. Bad tunes (PCM plus whatever your using) send way too much fuel (rich, unburned) through them and they become so hot that they fail or are "poisoned". 2. Bad valves, they can do the same thing. 3. Bad plugs...of course, bad plugs, fouled plugs do the exact same thing....unburned fuel down the tubes. 4. Crap cat construction. So, given all that what should one do....or, how can one tell. 1. Car running poorly? 2. Sills red hot? 3. Smoke, fumes out the exhaust? 4. Hard starting, or better yet...starts then chocks out? 5. Got a Fuel/Air meter? Are you running near Lambda? Air fuel meters are a must for large engines. 6. Logs showing variations, especially at higher RPMs? 7. Stuck in Open Loop all the time? Some guys remove the front O2 sensor and see if the motor runs better. Some guys check back pressure. Best shot...tune it yourself and check it every four months....or go to a great tuner and have them tune it regularly.
2000 GTS, Roe 5lbs, VEC3, JMB Performance intakes, Tator Titanium CMC Cannister Coils and Injection Tap Caps, Yeti Plate, Corsa Cat Back, Innovate LC-1 WB |
#34 |
so the research continues.
I have contacted a number of mfgers. And so far this is what I have: Vortex Cones reduce sound by 3BDAs (Which the Dynatech/Vortech technician told me is actually almost inaudiable difference to the human ear... aka doesn't do much). VERY surprised but appreciative to hear this 'frankness' from their own engineer. next he told me that their Dynatech Split Flow would be a better option as it does 6-8 DBAs reduction. So I asked him could I just combine them both and hopefully get 11 BDAs reduction and he said its certainly an option. Didnt sound like he was completely sold on the 'stacking' of them adding up to be 100% of the two together. might mean I only get 9-10DBAs by doing both. I am trying to get a hold of Moroso to find out what their spiral flows do for DBA reduction numbers. Jon
2002 Viper GTS ACR Graphite (Sold) 2005 Viper SRT-10 Black (Bought 4 Dad) 2006 Viper SRT-10 Coupe "Viper Slate Crystal Pearl Coat" (Woodhouse delivered 6/27/2006) |
#35 |
update update.. can't get anyone at moroso to answer the phone or call me back.
![]() so i ordered Dynatech Vortex Cones and Aero exhaust AR30 : 3 inch vehicle resonator, AR30, Exhaust Systems But also because of feedback from others I also ordered moroso Spiral flows, and will return either them or the AR30s based on which ones work for my application the best. Jon
#36 | |
Why don't you just do like the ricers and make a silencer for each side?? ![]() ![]() |
#37 | |
| Too loud with top down? | ViperGTS | RT/10 and GTS Discussions | 3 | 04-03-2007 06:40 PM |
| How loud is too loud???? | ViperCrazed | RT/10 and GTS Discussions | 18 | 05-02-2006 02:32 PM |
| de cat but now very loud!! | carl B | RT/10 and GTS Discussions | 1 | 06-15-2005 05:57 PM |
| Will this be loud enough? | jp | RT/10 and GTS Discussions | 8 | 04-18-2002 09:27 AM |
| not very loud | crayne hurst | Archive Management | 1 | 05-28-2001 05:42 PM |
