Old 09-04-2008, 02:20 PM   #16
adg44
Default Re: 3rd gear whine
Originally Posted by Schulmann View Post
Check if this noise is also present in 5th gear too.
It might be either a gear or a bearing ....
I was at my local VW dealer getting the car state and emissions inspected, and I went out for a ride with one of their senior tech's. He heard the noise and said it sounds definitely like a transmission whine. If it was the rear diff, I should be hearing it in every gear.
When I was driving back, I turned off the a/c and the radio, and I listened. It's very loud in 3rd gear, and when I shifted to 5th, I could faintly hear the same whining/howling.
Also, when I was at the VW dealer, I saw one of the service writers from the Dodge dealership, so I spoke with him for a bit and am going to swing by the dealer tomorrow and go for a ride with their Viper tech. Small world.
adg44 is offline   Reply With Quote
Old 09-04-2008, 02:21 PM   #17
adg44
Originally Posted by deam View Post
As Fast Too said, it might be the powersteering pump
If it was the power steering pump, wouldn't you hear that regardless what gear you are in?
Old 09-17-2008, 05:03 PM   #18
adg44
I went by the Dodge dealer today and took a ride with their Viper tech, and he said it is definitely gear whine. I'm taking it in next Monday, and most likely it will be getting a new transmission.
- Anthony
Old 09-17-2008, 05:25 PM   #19
ILLSMOQ
- Anthony
might want to see if they will work with you on ordering the trans and then calling you when it comes in. my car was at the dealer for 2 months waiting on a transmission
Old 09-21-2008, 10:02 AM   #20
adg44
Yes, I will see what they say tomorrow. If it is going to take a while, I will have them give me the car back until it comes in. So, I will ask that they don't remove my transmission until they have the new one in hand.
- Anthony
Old 09-26-2008, 11:23 AM   #21
adg44
Got a call from the dealer, they said they talked to Chrysler and that the gear noise is normal. Chrysler said they replaced 300 units and the noise was still there, so they are calling it normal.
Old 09-26-2008, 10:02 PM   #22
PaViper
PaViper's Avatar
Over the years I have found that if you drive a vehicle til something falls out, they have a lot less trouble admitting that something is wrong
06 VCA Coupe #38
02 FE GTS #173 (Sold)
Old Yesterday, 10:12 AM   #23
adg44
Following up on this, as the noise is getting worse. I spoke with Tony Parr at DC Performance and he said this wasn't normal. I then checked with mjorgensen, who went out of his way and looked into this for me, and he told me it wasn't normal. Apparently this was an issue with the early transmissions because of a bad gear contact pattern caused by a machine setup that was off during manufacture. Apparently a new 3rd gear and countershaft can fix this problem.
So, back to the dealer I go, and many thanks to Mark for finding this out for me. I hope this helps anyone else that has the same issue that I do.
- Anthony
Old Yesterday, 01:15 PM   #24
Newport Viper
Newport Viper's Avatar
LOL! How true that is!
1995 Viper (sold)
Old Yesterday, 02:24 PM   #25
bluesrt
bluesrt's Avatar
if your noise is only in certain gears and not in others while driving the same way in each gear,certain years are noisier than others in the gearbox,if its a noise that just appeard differantly than ur used to hearing,have a gearbox specialist go for a drive with you,most wont charge you to go for a drive.
bluesrt is offline   Reply With Quote
Trans./Gear whine - 5th gear at about 60mph, anyone?? TAXIMAN1 RT/10 and GTS Discussions 7 10-29-2007 03:51 PM
Transmission whine Iceman RT/10 and GTS Discussions 10 05-05-2005 09:25 AM
Do Paxtons have a whine to them? 4207henri RT/10 and GTS Discussions 31 04-30-2005 07:38 AM
5th Gear Whine 2BADD 4U RT/10 and GTS Discussions 7 04-08-2004 08:02 PM
New whine after 355 swap? JonB - PartsRack RT/10 and GTS Discussions 5 08-18-2002 06:43 PM
