Old 09-03-2008, 09:40 PM   #1
SCOTTB
PA/WV VCA Member
SCOTTB's Avatar
Default WET FLOORBOARD??????
My passenger side floorboard is always wet after a wash. Is it common for these to leak seems like its coming from under glove box
03 Red vert
07 Jeep Commander Limited HEMI
God made VIPERS so vette guys could have heros
SCOTTB is offline   Reply With Quote
Old 09-03-2008, 09:45 PM   #2
TBarrow
Default Re: WET FLOORBOARD??????
Reach your hand under the dash and see if it is leaking from the blower motor. If it is email me and I will send you pictures of what I did to fix mine.
Todd
skullnbones322@gmail.com
TBarrow is offline   Reply With Quote
Old 09-03-2008, 09:47 PM   #3
SCOTTB
PA/WV VCA Member
SCOTTB's Avatar
10-4 give me a day or 2 thanx
03 Red vert
Old 09-04-2008, 07:59 AM   #4
kennyhemi
I had the same problem with my 06 copperhead coupe and had to replace the weatherstrip that raps around the door opening, Mine was on the driver side. (warranty)
kennyhemi is offline   Reply With Quote
Old 09-04-2008, 08:06 AM   #5
mjorgensen
Have seen a couple of these also ended up being a kinked weatherstrip that was allowing the water to get through and follow the bracing to the middle of the dash on either side.
Woodhouse Viper Service Mgr.
800-889-1893 work
402-677-2935 cell
Old 09-04-2008, 08:41 AM   #6
SylvanSRT
SylvanSRT's Avatar
i had similar problem and the actual frame from inside engine compartment was leaking where the parts of the chassis parts(more specifically the top of the foot boxes) are joined and the dealer found some pin holes that would leak from rain or washing
'91 BRG SE Miata S/C zoom-zoom
'01 RT/10 yellow sold
'02 RT/10 graphite sold
'03 SRT-10 Silver....ZOOM-ZOOM!
K & N, Corsa, Mopar swing arm oil pan, Autoform rollbar,TeamTech harnesses,RPS light flywheel,SRT Sidewinders
Old 09-04-2008, 05:09 PM   #7
Kenneth Krieger
Arizona VCA President
It could also be the drain for the condensation of your A/C unit......make sure that the drain is not clogged or that the drain line is kinked!!
I have water in my passenger floorboard ?? npeifer RT/10 and GTS Discussions 5 04-14-2006 08:41 PM
passenger floorboard 95Viper RT/10 and GTS Discussions 1 07-26-2004 06:24 PM
