Hi Im trying to find out the factory speaker sizes want to make some changes without making new mountings. Thanks and it is for my 08 coupe.
08 viper violet coupe with white stripes 06 red viper conv traded in on 08 71 Detomaso Pantera |
Dash speakers: 3/4" silk dome tweeters
door speakers: 6-1/2" midrange , 3 hole fit , not 4 hole rear fill speakers (behind seats): 2-3/4" midrange sub: 6-1/2" woofer in ported enclosure between seats do a search on speakers , there is a ton of good info
08 viper red -motons-belanger system-chrome H rims-stoptech rotors
Is the '03-'06 speaker set the same as the '08 speaker set?
...But you can call me City. ![]() 2001 RT/10 (just about gone) ![]() 2008 SRT (just arrived) ![]() Thanks Chuck!
good question, and i'm not 100% sure, i do know the door speakers are the same as i have already dropped in the polks on my 08
will those speakers fit a gen1? pm me instead of dumpsterville.
1995 Black RT/10 |
Does upgrading just the speaker make a lot of difference?
EBAY is the cheapest by far....the DB650 have been discontinued but still pop up occasionally.. the replacements the DB651 model have the four hole design so they do not fit... the DB651S do have the three hole design and fit .....
i did a quick search on ebay , the db650 have a slightly higher power handling than the db651s but the 650 are hard to find since being discontinued POLK DB651S 6.5" SHALLOW MOUNT SPEAKERS NEW *PAIR* 165W - eBay (item 220275345201 end time Sep-06-08 09:49:18 PDT) great bang for the buck and install is a breeze, upagrading just the door speakers makes all the difference.. with the top down and going 70 there is no way i could here the stock radio... with the polk upgrade i can jam along at 90-100mph even with the belanger system... ![]() Polk Audio db650 - car speaker Reviews. Car speakers Reviews by CNET.
Thanks Wallbanger, much appreciated !
thanks for the info Wallbanger
Wallbanger - did you have to do any other modifications to the system? You are just running the 6.5's in the door and left all the other speakers the same?
I agree that I think those would be the best bang for the buck upgrade, and the install looks like a breeze. I assume the only thing you would have had to change may be the connector for the speakers? - Anthony |
dose anyone has a wire diagram for the factory amp? Im thinking about putting in components instead of coaxes ?
#13 | |
![]() So, you think that upgrading the door speakers is a higher priority than upgrading the rear speakers? My rear speakers (not sure which one) seems to distort first, although the door speakers may be doing the same but they're much further away from my ears. Anyway, since you think it's a worthwhile upgrade to begin with the door speakers (alone) it seems like a no brainer for the $. Thanks for the info!
Vipers have speakers?
2006 SRT-10 Bumblebee Coupe, VEC 3, Corsa Exhaust 2007 Porsche Cayman S SUPPORT TATOR'S DODGE!!!!!!!!!!!!!!!!!!!!!!!!
here is a previous post with pics on install.. look at how small the stock speakers are...
$100,1HOUR,HOWTO/MUST DO,SPEAKER UPGRADE(PICS) Key tips on install 1...the stock speakers have a plastic connector that u see in the pics.. in order to disconnect it u can't just pull on it u have to lift up the clip in the middle 2... Once u disconnect the wires from the stock speaker u can install speaker wire clips which u can pic up from u're local stereo guy.. then they just snap on
| Gen 1 RT/10 Speaker/Amp Recommendations | Red94Roadster | RT/10 and GTS Discussions | 4 | 06-16-2006 04:04 PM |
| Speaker Crackle | KHitman | RT/10 and GTS Discussions | 13 | 05-31-2006 09:23 PM |
| 1992 viper factory speaker, grill and cup installation help | genelumpkins | RT/10 and GTS Discussions | 0 | 04-07-2005 02:19 PM |
| Speaker plates ??? | Wayne | RT/10 and GTS Discussions | 1 | 07-25-2004 04:47 PM |
| Speaker problem with viper! | gowings | SRT10 and SRT10 Coupe Discussions | 2 | 05-02-2004 12:48 AM |
