Hello all,
Just wondering from those who have the moton clubsports on your snake what you run for street and road course? I have 500lb front and 800lb rear eibach springs and at the moment I have 125psi front cans and 150psi rear. They came with 185psi new. I think I have mine set at 3 compression and 2 rebound for front and 3/3 on rear. Prior to that I had each comp/rebound set at one click stiffer all around but it was a bit to stiff. On the current setting it feels less stiff but still planted up front but the rear still is bouncy. Running 295/30/19's up front and 335/30/20's rear ps2's set at 30lb's on heavy Iforged Revs. Took the snake to storage and picked up my C6Z which is running the eibach pro calloway coilovers and boy what a ride. I had not driven the vette in some time so I forgot what it road like. It feels much more planted and no bouncy bouncy in the rear. I took the vette to 130 today and the ride gave me lots of confidence. I wish I could say that about my snake. Even with the motons I am still saying prayers I don't hit a bump in the road in the snake at 130, I want to have that confidence in my snake too. Any help would be great. Thanks. |
TommyG,
My .02 cents is as follows: 1 - Increase the nitrogen pressure in the canisters to a minimum of 150 psi all around. 175 would be better. FYI at 100 psi or less, the fluid in the shock will boil. It needs pressure to keep it liquid and working correctly. 2 - Set the fronts at 2 clicks from full soft compression, 3 rebound. Same for the rears. 3 - The small sidewalls of the 19 / 20 combo will not help the ride quality in any car. You can let a bit of air out and that will help. Try 28 psi. Good luck, Dan
2009 ACR, 2006 VOI9 Coupe 2004 Black SRT-10, 925 rwhp Paxton beast 2001 GTS ACR |
Dan,
Thanks for the reply. Do you have the portable tank like Tom Nader sells or a tank at home. Just wondering where I should go to add some psi? The rep at moton was the one who suggested going to 125ft/150rear for street, I forget his name? I'll try your set up and see how it feels. BTW, my side walls on the 295/30 19's and 335/30/20's are actually quite tall, even a tad taller than stock so I was supprised you mentioned that. I'm sure the heavy wheel tire combo can't help though. Thanks! |
What Viperx says is similar to what I do. 150psi all around (I have toms fill kit) and I do 2 clicks front and 3 back. Works very well for the track on my car. Hope that helps. On the street I keep it around 125psi and do 3 click all around makes for a very nice ride!
05 Modded to Hell And I like it that WAY!Motons, Quaife, Corsa,Vec3, Headers, Corsa,CC OilPan, StopTechs, Roll Bar, Splitter, Wing
#5 | |
I run my pressure at 175 all the time on the street. At the track I do dial it up to 185. I just like the more aggressive ride. I took some weight off of each corner with stoptechs and lighter rim/tire setup so it is not as jarring as the stock setup.
Compression i have set at 3 all around and rebound I have 2 from 3 back. Quote:
2004 Black Mamba 003/200 Motons, OS Giken, 3.33s, HRE 545Rs, Stoptechs, Corsa Track, DC Programming, Single Blad TB, custom dash |
TommyG,
I bought a tank and pieced together a nitrogen shock filling set up before Tom developed his kit. I'd buy his kit now if I were in the market. Dan
| Moton rebound settings? | Shandon | SRT10 and SRT10 Coupe Discussions | 1 | 11-14-2008 08:34 PM |
| Guys with Moton Club sports - what settings? | Viper X | SRT10 and SRT10 Coupe Discussions | 20 | 06-17-2006 09:23 AM |
| Dynamic Shock Settings - Street / Track for ACR? | Viper X | RT/10 and GTS Discussions | 0 | 04-10-2005 11:59 PM |
| Brake Bias knob -- what are the right brake settings for street and track ? | MannyC | RT/10 and GTS Discussions | 9 | 07-27-2003 06:21 PM |
| ACR owners with Konis, what settings are using on your shocks? for street | TZL | RT/10 and GTS Discussions | 3 | 04-16-2003 04:53 PM |
