Old 02-05-2010, 05:17 PM   #1
ShadowLight
Default Locked keys in 2004
I locked the keys in my 2004. I do have the trunk open still if that helps. What are my options? Are there any tricks? Or am I heading down to the dealer to get a second set made?
ShadowLight is offline   Reply With Quote
Old 02-05-2010, 05:25 PM   #2
BlknBlu
VCA member
BlknBlu's Avatar
Default Re: Locked keys in 2004
There is a trick to get in, but I am not sure what it is. It has been mentioned on here but not wriiten down on a public forum.
Bruce
2009 Viper ACR GTS Blue with Black stripes (1 of 2)
2008 Viper Coupe GTS Blue with Black stripes (1 of 6)
FOR SALE $78,500
BlknBlu is online now   Reply With Quote
Old 02-05-2010, 05:39 PM   #3
Tom Sessions
If you locked them in the trunk I could help you out. But cant help you get into the car. You can try unhooking the battery and then hooking it back up and see if you can open the door then. Not sure if it will reset the alarm module but worth a try since you can get to the battery
Tom Sessions is offline   Reply With Quote
Old 02-05-2010, 08:05 PM   #4
FastestBusaAround
You mean a "3rd set" - they all come with 2 sets of keys from Dodge.
FastestBusaAround is offline   Reply With Quote
Old 02-06-2010, 10:26 AM   #5
ShadowLight
please refrain from profanity, thank you
Old 02-06-2010, 11:17 AM   #6
Steve-Indy
IN/KY VCA Member
I hope that Tom's solution works for you. 03-06 locked vert is not an easy problem...short of the above mentioned new key. If you do need to go the new key route, be sure to lube the lock before you use it...also, remember to push on the rear of the door with you hip while turning the key and pushing down on door latch.
Good luck, and please post outcome.
Old 02-06-2010, 04:46 PM   #7
intense5.5
intense5.5's Avatar
How about trying to pull the lock button, or hook the keys and pull them out with a coat hanger? Never met a car I could'nt get in (no,I don't steal cars, I used to help out at a friends' towing company).
'05 Black Vert,corsas'w/random cats,k&n,mgw short shift,rb1,much more to come
'05 Redneck Eng. custom rigid chopper
VCA Certified Deviled Eggspert
intense5.5 is offline   Reply With Quote
Old 02-07-2010, 08:35 AM   #8
ShadowLight
Next time something goes wrong with your car I'll be sure to point out the most obvious and yet unhelpful thing in the world.
'please refrain from profanity, thank you again.'
I called the dealer, it was $11 for them to grind a new key on a Chrysler blank and $25 for a Viper one. I did the Chrysler.
Old 02-07-2010, 10:38 AM   #9
Steve-Indy
IN/KY VCA Member
intense5.5, having looked closely at our 2003 vert's interface between the windows and soft top, I could probably get a wire into the car...BUT, I feel there is a good possibility of causing a little visable damage...so that procedure is not something I usually suggest to others.
Old 02-07-2010, 12:29 PM   #10
ShadowLight
That was the conclusion I came to. It's not worth it for $11.
Old 02-07-2010, 04:26 PM   #11
FastestBusaAround
Maybe a brain and a valium might be well deserved in your case.
Old 02-07-2010, 05:51 PM   #12
eucharistos
isn't $25 for a Viper key from a dealer a good deal
eucharistos is online now   Reply With Quote
Old 02-08-2010, 06:32 AM   #13
ShadowLight
Yeah it is, but they had to order it and I wanted to drive my car over the weekend. I don't get that much satisfaction from a logo :P
Old 02-08-2010, 10:16 AM   #14
eucharistos
that's better than some
Old 02-08-2010, 04:03 PM   #15
SkyBob
And when you open your locked car with your non-logo key you will be able to reach your Viper-logo key you left inside. Then the non-logo key can go in the house.
SkyBob is offline   Reply With Quote
Old 02-09-2010, 06:46 AM   #16
ShadowLight
Yep, it's sitting in my file cabinet Hopefully to never be used again.
Old 02-09-2010, 01:22 PM   #17
SkyBob
File cabinet, hmmm? And where do you live?
Old 02-09-2010, 02:42 PM   #18
LifeIsGood
CO VCA Member
LifeIsGood's Avatar
It's not a good idea to advertise where your keys are...they should all be very well hidden and/or locked away when they're not in the car.
Ken
2001 RT/10 VRY (Viper Race Yellow) - K&N filters with smooth tubes
LifeIsGood is offline   Reply With Quote
Old 02-10-2010, 04:02 PM   #19
ShadowLight
I've got bigger problems if someone can get to my file cabinet. I guarantee not everyone is actively hiding all their keys when they come home.
Maybe they are, I hope they aren't heavy drinkers then!
Locked Keys In Car Need Help Please QUICKSRT10/SRT8 RT/10 and GTS Discussions 7 09-28-2009 04:38 PM
Keys locked in 01 GTS callred RT/10 and GTS Discussions 36 06-21-2006 10:50 AM
Keys Locked in RT/10 Trunk Jerry Dobson RT/10 and GTS Discussions 1 06-17-2006 08:54 AM
Keys locked in trunk, help Fred(DrivingSchool)Kinder SRT10 and SRT10 Coupe Discussions 10 06-11-2006 11:31 AM
Keys in car and I'm locked out!! vipernate RT/10 and GTS Discussions 18 05-18-2005 02:19 PM
