Old 02-06-2010, 01:51 PM   #1
Paul Hawker
Paul Hawker's Avatar
Thumbs up Check your tire pressures
For some reason tire change monkeys seem to air up fresh and repaired tires to 45 lbs. This makes Vipers ride hard, and very darty.
Everytime you have someone mess with your tires or change to different wheels, check the pressures yourself and adjust to the magic 29 lbs.
Paul Hawker, San Diego
Baby you can drive my car,
beep beep, beep beep YEA!
VCA # 05669
Old 02-06-2010, 01:54 PM   #2
JonB - PartsRack
Site Sponsor Since 1998
JonB - PartsRack's Avatar
Default Re: Check your tire pressures
I have seen scores of Vipers with LOW tires......worse still than overfilled.
But Paul is 100% correct: Race cars adjust their tires as little as 1lb to creat "stagger" and assist turns toward the low side. Your Viper is a "Race Car" chassis and WILL handle adversely if you have imbalanced pressures side-to-side, or improper pressures. Buy a GOOD guage, and pay attention at every third tankful of gas.....or sooner.
JonB-PartsRack
www.partsrack.com
Old 02-06-2010, 02:50 PM   #3
Chuck 98 RT/10
Spiffy Florida VCA Member
Chuck 98 RT/10's Avatar
No problem. It isn't the tire changer's job to set the pressure perfect anyway, it's the driver's job. Some guy making $8/hr to mount tires, does any Viper owner not go over the work to make sure it is right? It's common sense.
Chuck 98 RT/10
BabelMotorsports.net
SAFEMotorsports.com
Old 02-06-2010, 03:59 PM   #4
Yellow32
TX VCA Member
Yellow32's Avatar
Simple, they air it up to set the bead on the rim, if you watch them do it, it goes "pop" when it snaps into place.
Just be sure to tell them what pressure you want the tire set to after they mount and balance.
For pilot sports I find 32 pounds to be a safer rider than the "gas mileage" setting of 29. And, if it is raining, put them up to 35-36 pounds as the tire will not get a good of a chance to "heat up" and therefore the tire pressure will remain low.
-J
'05 Racing Yellow Special Edition #32 *SOLD* '01 Sapphire/Silver Stripe ACR *SOLD*
'09 Viper Blue/Black Centerband ACR
Yellow32 is offline   Reply With Quote
Old 02-06-2010, 04:22 PM   #5
2000_Black_RT10
Ontario VCA Member
2000_Black_RT10's Avatar
Just babbling.. but fyi.. it's a slip angle, the contact patch can maintain adhesion if the tire can flex in relation to the wheel or spindle axis (typical tire manufacturers are 6 degrees). Think of a tire in a static position on pavement, if you were to turn your steering wheel, the tire will flex before losing grip or scrubbing on the pavement, and this happens in a dynamic situation at high speeds. Hence the dartiness, the tire having more pressure making it more rigid. Tires with stiff sidewalls (i.e. runflats) or lower profile will also be worse having less of a slip angle or flexibility, all tires are different, different handling results depending on inflation psi for a particular brand of tire and size.
Regards,
Mike
Dedicated to babbling on forums having 20 years of automotive design experience and because it makes me feel virtually special
2000_Black_RT10 is offline   Reply With Quote
Old 02-06-2010, 04:36 PM   #6
gb66gth
TX VCA Member
gb66gth's Avatar
didn't they check the pressures in the factory when they built the car? why should I have to do it again?
'05 Black SRT10 vert.
'08 Black SRT10 vert.
'66 Shelby GT350H "Rent-A-Racer"
gb66gth is offline   Reply With Quote
Old 02-07-2010, 09:27 PM   #7
Achilles99
GA VCA Member
Achilles99's Avatar
I bought solid rubber tires. No need to air them up. I love them.
2006 Blue/White SRT Coupe
Previous: 1997 Blue/White GTS (800+ rwhp), 1997 Red/White GTS (700+ rwhp), 2002 Red GTS, 2001 Red/Silver GTS (1 of 36), 1998 Red GTS, 2000 Red RT/10
Achilles99 is offline   Reply With Quote
Old 02-08-2010, 12:34 AM   #8
pteam
OH VCA Member
pteam's Avatar
I often wonder why they dont make solid rubber tires? Probably cause they'd never sell a 2nd set lol
Just think they'd be 10000x times safer
1. no flat tires (less crashes and deaths)
2. no nair in the tire crash (drive away with 100 nails in them lol)
3. never ending burnouts (until you run out of gas )
05 Viper VCA Special Edition #49 of #50 - 803 Horsepower Paxton Supercharged by Woodhouse, DC SCT Tune, corsa, - 2 cats, ps2s, HID fogs, heated seats, limo tint
Old 02-08-2010, 01:01 AM   #9
eucharistos
and no more fillings left in your head
eucharistos is offline   Reply With Quote
Old 02-08-2010, 02:58 AM   #10
ViperGTS
VCA Member Bavaria
ViperGTS's Avatar
check the tire pressure at least visually every gas stop you do
plenty of time to walk around the car and check - and in case you see something "different" you can use the pressure gage ... get used to the
procedure and you will almost never have a tire problem.
#4 2008 SRT-10
#3 2002 FE GTS
#2 2002 RT/10 = crashed by stealership Nov-2008
Old 02-08-2010, 07:19 PM   #11
Achilles99
GA VCA Member
Achilles99's Avatar
Not if you get a Tweel tire
HowStuffWorks "How the Tweel Airless Tire Works"
Old 02-08-2010, 08:47 PM   #12
treesnake
Gateway VCA Member
What do you mean? Check the tires? Why, I have the SRT TPMS system. It tells me when my tires are low. Doesn't yours?
I have a whole bucket of those worthless paperweights. You can't trust them.
I check the tires with a gauge, along with the oil, EVERY TIME I drive.
treesnake is offline   Reply With Quote
Old 02-08-2010, 08:59 PM   #13
Achilles99
GA VCA Member
Achilles99's Avatar
Haha. Even when they work, they seem to only do relative tire pressures for me. IE, if all go to 22psi, things are fine with the tpms. Only when one is really off does it seem to do anything lol.
Old 02-09-2010, 09:43 AM   #14
Socrates
Socrates's Avatar
I've always been a stickler for inspecting my tires/pressures prior to every drive. Speaking of which, does anyone have any suggestions on the ideal pressures to run the Pilot Cup Sports on the street? Right now I'm following the OEM recommendation of 29 PSI front/back, but the tramlining is awful with these tires, and it makes me wonder if adjusting them a little might help with that issue.
2009 ACR Graphite/Black
2007 Lotus Exige S
Socrates is offline   Reply With Quote
Old 02-09-2010, 09:47 AM   #15
goldcup
Kansas City VCA Member
goldcup's Avatar
I check tire pressures every time I drive.
Right after I lube the windshield wiper bearings!!!!!!!!!!!!!
"Any society that would give up a little freedom to gain a little security will deserve neither and loose both."
Benjamin Franklin
Old 02-09-2010, 10:53 AM   #16
Chuck 98 RT/10
I've got one tire that goes low quicker than the others. I check it and the others and fill as necessary then I'm good to go for another month or two. I don't know what is so difficult about regular vehicle maintenance, particularly with sports cars.
Chuck 98 RT/10
SAFEMotorsports.com
Old 02-09-2010, 11:22 AM   #17
eucharistos
just caught you bought them....
what did you mount them on?
pics
Old 02-10-2010, 11:11 PM   #18
Achilles99
GA VCA Member
Achilles99's Avatar
I was just joking I run Nittos on the street and R888's on the track.
Tire Pressures SRT 10 VIPER GTSR 91 SRT10 and SRT10 Coupe Discussions 2 02-13-2009 12:48 PM
ACR tire pressures? Grant SRT10 and SRT10 Coupe Discussions 4 11-29-2008 07:36 PM
tire pressures gb66gth SRT Engineering Q/A Area 1 07-27-2008 11:07 AM
Hoosier Tire pressures CANTDRIVE55 Performance Modifications 1 06-14-2006 08:24 AM
Tire Pressures on the Track Maverick The Electrician Performance Modifications 2 12-02-2000 04:09 PM
