Old 02-08-2010, 08:08 PM   #1
HyperViper
HyperViper's Avatar
Default Any Issues or Recalls with 08
Since I just bought a new 08, just curious if their were any known issues to be aware of.
I only have 600 miles on it and will be heading up to SLC for VOI in September and just want to be ready
HyperViper is offline   Reply With Quote
Old 02-08-2010, 08:22 PM   #2
gbatejan
MA VCA Member
gbatejan's Avatar
Default Re: Any Issues or Recalls with 08
Only two things I'm aware of. One, there was a PCM software update on some 08s. Dealer did mine soon after I took delivery in March, not a big deal. Second, there were some injectors that were defective. They would be replaced under warranty if defective. There was a specific part/batch number that was affected (I want to say part number beginning with 73, but do a search to be sure). Not all injectors beginning with this number were defective, but if you notice a problem and had these they would be replaced. Otherwise a great car, I love mine.
Oh, one other thing, some 08s, mine included, did not have their clutch properly bled and the factory may have used DOT 3 fluid instead of DOT 4. I lost my clutch pedal and had to have the system flushed and bled.
2006 Supercharged First Edition
2008 Viper Bright Blue Roadster
Keep building the Viper!!!
gbatejan is offline   Reply With Quote
Old 02-08-2010, 08:31 PM   #3
HyperViper
HyperViper's Avatar
Thanks for the info
My car was built July 08, do you think any of that would have corrected?
Old 02-08-2010, 08:51 PM   #4
EZ 2B Green
NH VCA Member
My Viper was built in April 08 and the only issue I had was that the clutch needed to be bled. I've been on some 1000+ mile trips without a hiccup. If your clutch is good when the car gets hot, then I think you are good to go!
2008 SSG Roadster
Thank you Detroit!
EZ 2B Green is offline   Reply With Quote
Old 02-08-2010, 09:08 PM   #5
HyperViper
HyperViper's Avatar
Thanks Man! How many miles do you have on yours?
Old 02-09-2010, 08:38 AM   #6
firecatcamino
Only recall listed in dealerconnect is a addemdum to owners manual. If you pm last 8 of your vin I can check for that and any other TSB for yours.
firecatcamino is offline   Reply With Quote
Old 02-09-2010, 08:45 AM   #7
gbatejan
MA VCA Member
gbatejan's Avatar
My clutch went out after 500 miles. PCM software was updated at the same time the Tech did the clutch. I bought my 08 in March of 09 but I don't know when it was built.
Old 02-09-2010, 09:22 AM   #8
ViperGTS
VCA Member Bavaria
ViperGTS's Avatar
1) Defective front sealing main shaft behind the damper -> loosing a lot of OIL after I drove 1000 miles over the first weekend!!!
2) NO grease in ball joints - suspension!
#4 2008 SRT-10
#3 2002 FE GTS
#2 2002 RT/10 = crashed by stealership
Old 02-09-2010, 05:46 PM   #9
HyperViper
HyperViper's Avatar
PM sent. Thanks
Old 02-09-2010, 05:48 PM   #10
HyperViper
HyperViper's Avatar
I know you know this but...build date is inside your door jamb FYI
Old 02-09-2010, 05:50 PM   #11
HyperViper
HyperViper's Avatar
Thanks for the heads up on the ball joints and will definitely keep an eye out for any oil leaks at the front seal.
Old 02-09-2010, 10:11 PM   #12
SilveRT8
SilveRT8's Avatar
I know that early built 08's have hollow rear half-shafts and at some point in production they upgraded to the solid ones as found in the ACR.
Mine was built Feb 25, so I think I may have hollow ones. If so, I would like to know if it's possible to get the upgrade under warranty?
Claude ...........08 Roadster Blk/SS
563 RWHP/533 RWTQ/ Mopar Contr,Roe H/F Cats, K&N CAI, KW2, Euroteck rotors, MGW shifter
SilveRT8 is offline   Reply With Quote
Old 02-10-2010, 11:32 AM   #13
MY600HP
MY600HP's Avatar
Why would Chrysler cover that under warranty? If you don't track your car with slicks you don't need the solid shafts anyway. Besides, the hollow shafts are 3 lbs lighter and have less rotational inertia.
MY600HP is offline   Reply With Quote
Old 02-10-2010, 07:29 PM   #14
HyperViper
HyperViper's Avatar
I believe I have the super heavy solid ones
Old 02-10-2010, 07:41 PM   #15
bluesrt
bluesrt's Avatar
600 hp with hollow halfs? yuky----- mine was built in october so i think i got the big heavy ones. my car was almost a year old by the time i got it,ordered it in march. lol
bluesrt is offline   Reply With Quote
Recalls & TSBs DublinOH RT/10 and GTS Discussions 2 04-28-2008 09:51 AM
What recalls have been done? radta7 RT/10 and GTS Discussions 4 07-19-2004 09:02 PM
ANy issues or recalls I need to check for on the 04 SRT 10 Dr Roof SRT10 and SRT10 Coupe Discussions 4 05-16-2004 07:06 PM
Speaking of recalls. J DAWG RT/10 and GTS Discussions 3 11-07-2003 10:59 PM
Recalls COOLASP RT/10 and GTS Discussions 4 07-06-2003 11:27 PM
