Roland L-Ocala FL
Get that baby up on a lift and check for leaks from underneath. Check at the head gaskets especially. The coolant bottle should have a mark on it or a mark in the fenderwll, when you stick a light inside the fender after you remove the big rubber plug in the front of the fenderwell. There is a viewport or slot in the fenderwell that you can see the level of antifreeze from, but it should be about 1/2 full when cold, from what I remember. Hope this helps, and check the board archives for this, there is a lot if information on this there.
