Thread: Anyone Interested in Custom Made 10.5mm Plug Wire loom
Reply to Thread
Results 1 to 16 of 16
  1. #1
    Join Date
    Mar 2002
    Houston, TX
    Default Anyone Interested in Custom Made 10.5mm Plug Wire loom
    I have a friend at work that can make custom plug wire loom for our V10 for 10.5mm wires. Anyone interested. If I get enough responses we can make mass quantity and keep production prices low. I plan on making this wire loom out of black Delrin. I considered aluminum but was worried about arcing (sp?).
  2. #2
    Join Date
    Jul 2001
    LAS VEGAS, NV
    Default Re: Anyone Interested in Custom Made 10.5mm Plug Wire loom
    I would be interested. Would like to see some
    pictures. Thanks.
  3. #3
    Join Date
    Nov 2001
    Dallas, Texas
    I would be interested, but would like to see pictures.
  4. #4
    Join Date
    Dec 2001
    Morgan Hill
    Price?
  5. #5
    Join Date
    Mar 2002
    Houston, TX
    These are all good questions. I have a VERY good machinest over here. I dont even have any prototypes made up yet. If there was enough interest, I would have them made up via CAD. Otherwise I could have him make up some one-off pieces. Depends on how much interest there is. Im not doing this to make any money, just as a favor to fellow Viper owners. I will charge just for materials. He is a friend of mine so he probably wont charge any/minimal/token labor.
  6. #6
    Join Date
    Feb 2001
    Clearwater,FL.USA
    See pics and price please....
  7. #7
    Join Date
    Jun 2001
    Western New York, USA
    Here is a pic of my 10.5 red wire loom from a local race shop.
    They are brand name smoothie. They are only $35
    And the v-8 setup worked just fine. I actually bought 2 sets not knowing if i would need 2. But did not 1 set worked just fine.
    The other set I sent to KenH maybe he still has the package and can give us the part #?
    Seeing the they are available and cheap, may not be worth all the work making them??
    JIM
  8. #8
    Join Date
    Dec 2001
    Mountain View, CA, USA
    I'd be interested.
    -Par
  9. #9
    Join Date
    Mar 2002
    Youngstown, Ohio
    im no mechanic, isnt anything over 8.5mm detrimental and in actuality hampering to performance. simple laws of conductivity and electricity here, too much flow.
  10. #10
    Join Date
    Oct 2001
    Portland, OR, USA
    The wire loom in Jim's picture is made by 'Made for You Products' PN 50-71013. They are made out of red nylon for 10.5mm wires and are a vertical mount which screw into the valve cover bolt locations. Jim, the ones in your pic seem to be a horizontal mount.
    rdustman, the larger diameter is just due to a thicker silicon insulation, and there is no adverse electrical effects over the thinner wires.
    --- Ken
  11. #11
    Join Date
    Jun 2001
    Ken,
    My vipertech installed my wires and loom.
    so not sure how he installed them.
    but i love the way they came out!!
    JIM
  12. #12
    Join Date
    Mar 2002
    Youngstown, Ohio
    Ken H, hmm thats not what i been told and im not (yet) disagreeing with you. to my understanding the diameter is a direct correlation to conductivity and one thing i know is larger diameter, more flow, and with regard to electrical current this is not always optimum, hence 8.5 being the standard for the viper. if i am wrong please educate me as all i am after is the best for my snake
  13. #13
    Join Date
    Oct 2001
    Portland, OR, USA
    rdustman,
    I think your confusing the size (and hence conductivity) of the inner core of the wire with the size (thickness) of the insulation which surrounds that core.
    In the case of Magnecor wires, the inner core is the same between the 8.5 and 10mm wires and the impedence/conductivity of the wires (for emi suppression) is the same between them.
    The difference in thickness of these wires is strictly due to a thicker silicon coating over the core. The thicker insulation has no direct affect on the electrical energy going down the conductor, but it does provide a little more insulation between the conductor and any adjacent conductors or the engine to reduce any chance of arc-over which would really only be a concern if you are running a very high energy ignition system. The thick silicon sleeving also provides a little more protection against header heat as well.
    I doubt that anyone driving a Viper truly NEEDs 10mm wires, since I don't think anyone is running a real high energy ignition system, but they do look good!
    PS There may be other mfr. who adjust their core construction between 8.5 & 10mm wires, but I am not aware of them. In general though, lower impedence on spark plug wires does not mean lower performance of the engine, only of the radio
    --- Ken
  14. #14
    Join Date
    Oct 2000
    Hawthorn Woods, IL
    Jim and Ken,
    I like the 'Made for You Products' wire looms, but since these mount to the bolts that hold down the valve covers I am wondering what you guys did about the threaded studs that protude from the valve covers that the normal looms mount to.
    I think they would somewhat spoil the neat and trim look of the new looms. Can they be removed?
  15. #15
    Join Date
    Nov 2000
    Pittsburgh, PA
    any new information on this???
    Randy
    [email protected]
  16. #16
    Join Date
    Oct 2000
    Southern California
    <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by bigr1:
    Randy
    [email protected]
    <HR></BLOCKQUOTE>
    If you are seeking info on Smokin's wire looms then you won't be finding it here. Smokin' HAS LEFT THE BUILDING!!!!!!!
  1. Plug Wire looms?
    By DC VENOM in forum Performance Modifications
    Last Post: 12-27-2006, 09:44 AM
  2. Wire Loom attachment to engine
    By Purdue_Boiler_Viper in forum RT/10 and GTS Discussions
    Last Post: 02-17-2006, 02:54 PM
  3. Plug wire separators
    By Simms in forum RT/10 and GTS Discussions
    Last Post: 10-19-2004, 07:43 AM
  4. help-plug wire order
    By VIPR GTS in forum RT/10 and GTS Discussions
    Last Post: 11-14-2002, 07:37 PM
  5. Free OEM gen-II plug wire loom
    By treynor in forum Archive Management
    Last Post: 05-22-2001, 11:25 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
