Thread: 2001 Rear Brake Pad Replacement
Reply to Thread
Results 1 to 3 of 3
  1. #1
    Join Date
    Oct 2000
    Houston, TX.
    Default 2001 Rear Brake Pad Replacement
    I'm putting the EBC Greens on my 2001 and I see the rear brakes are a lot different from the earlier models. Can someone tell me - do I take out the two 12mm bolts to separate the caliper assy.? (as opposed to the pin and spring in the pre 2001)
    Don't have the manual with me unfortunately
    Thanks for any help -
  2. #2
    Join Date
    Jun 2001
    Abilene, TX
    Default Re: 2001 Rear Brake Pad Replacement
    Rich, make sure you have the correct tool for the job. The 2001+ require some special caliper tool. JonB usually has them in stock.
    That's about all I know about it though
  3. #3
    Join Date
    Oct 2000
    Houston, TX.
    Thanks - yes I have the new caliper tool for the rears. The fronts were a breeze and I expected the rears to be as straightforward - no such luck. It's supposed to rain all weekend here in Houston and this looked like the perfect project, but my manual is in Dallas - oh well...
  1. 2001 Viper rear brake tool...and SnapOn kit...long
    By Steve-Indy in forum RT/10 and GTS Discussions
    Last Post: 02-13-2003, 03:28 PM
  2. 2001 Wheels/Replacement under Warranty?
    By ViperGTS in forum RT/10 and GTS Discussions
    Last Post: 03-20-2002, 01:09 AM
  3. Rear brake pads for 2001
    By viperdoctor in forum RT/10 and GTS Discussions
    Last Post: 07-27-2001, 10:42 PM
  4. 2001 Rear Brake Tip - 2001 owners:
    By JonB in forum RT/10 and GTS Discussions
    Last Post: 07-27-2001, 08:29 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
