Thread: any tips on racing a 68 Camaro 396??
Reply to Thread
Results 1 to 24 of 24
  1. #1
    Join Date
    May 2002
    NY
    Default any tips on racing a 68 Camaro 396??
    I have a $1,000 dollar run this coming saturday in English town with a friends 68 Camaro..No slicks, all street tires..He is putting on only Mickey thomson race tires..He has a 396 big block, around 400 horses..Car is worked nice..Probably in high 11"s or mid 12"s..Can anyone tell me how to launch the car with spinning them???
  2. #2
    Join Date
    Oct 2000
    San Antonio, Tx, US
    Default Re: any tips on racing a 68 Camaro 396??
    I would just say to keep in mind the Viper is not set up nor was it intended to be a quarter mile car. In the Viper world we say: It's not a matter of IF a Viper will pass you but when. In the long run the Viper will win.
  3. #3
    Join Date
    May 2002
    Duluth, Minnesota 55812
    First of all, I am NO expert
    I sure hope you get in some practice runs first, or that'll be an expensive day for you if it's a high 11 second / low 12 car. It took me alot of practice to get my best time, and there's so much more to learn. I was told to lauch from barely over idle, slipping the clutch out to a good roll before nailing it. With that advice, I was able to pull off a 12.29. That was on street tires. If you're running Pilots, and he gets to run street slicks, that seems a little unfair to me. Put some slicks on yours, and you'll be a good race.
    My 2 cents
  4. #4
    Join Date
    Feb 2002
    laytonsville MD
    Becareful !! I have a 69 Z-28 w/ a 383 stroker..these are 1/4 mile cars...My Rt has alot more top end, but in the quarter? not a chance..They hook alot better than vipers do..However, a supercharger or NX system could help ya ! Good luck....If its a stock 396 ..you'll when !
    2000RT (steel Grey)
    1969 Z-28 (383 stoker)..
  5. #5
    Join Date
    Aug 2001
    The 68 Camaro with 396 is a dog if stock check their times 13.20 to 12.60's. however if it has been worked that's a different story. You should do your homework before putting up your dollars, good luck.
  6. #6
    Join Date
    Feb 2001
    Sarasota, Florida
    <HR></BLOCKQUOTE>
    Do you know which M/T tire that is? ET street will hook almost as well as a slick. Stock the 396 would be a low 13 sec car and with good tires maybe mid 12's If the motor has some work done then, as you said, low 12's high 11's would be a good estimate. Hooking a Viper with stock tires is very hard to do, it depends alot on the track prep. Good luck
  7. #7
    UT/AZ
    Former National President
    Marv S's Avatar
    Join Date
    May 1998
    Scottsdale, AZ
    If it's a stock 396 camaro you will have no trouble at all.
    I recall a kid in high school with the big bad '68 396 camaro. 4.56 gears and a high stall th-400 trans. Car had huge rears and front skinneys. Looked fast. Sounded even faster. It never went under 14.0 at Firebird or Beeline.
  8. #8
    Join Date
    Jun 2001
    Enterprise, AL USA
    Get ya some Kumho's for the race!!!!
  9. #9
    Join Date
    Dec 2001
    Dalton Ga. (Chatt. Tn.)
    Surely your not going to do this with no experience with street tires on a dragstrip? Good luck, 2000 - 2500 rpm and slip the clutch out before you hammer it.
  10. #10
    UT/AZ
    Marv S's Avatar
    Join Date
    May 1998
    Scottsdale, AZ
    <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by BACKNBLACK:
    <HR></BLOCKQUOTE>Tony, If that's what you want just rev the car to 4,000 rpm, drop the clutch and mash the go pedal. That may give some impressive sounds and smells but I'd recommend a launch without spinning them (too much)if you want to win a race.
    <FONT COLOR="#ff0000" SIZE="1" FACE="Verdana, Arial">This message has been edited by Marv S on 10-31-2002 at 08:33 PM</font>
  11. #11
    Join Date
    Apr 2001
    Barrington,il
    Here's a guaranteed method that you can practice on the street and easily mirror at the track.Snap the clutch back from an idle,while hammering down the throttle.you'll probably get a 1.9to2.0 60ft.with a 12.20-12.40run.The problem with leaving like a pro at 2500-4000 and slipping the clutch is the major smoke the tires high 12-13second screw up factor for drag strip beginners.One or two tenth optionsump up the fronts 45psi and rears down to 25,remove your air filter,make sure your clutch is cooled down between runs.Last guaranteed tip,rent a TOOFAST NOS system and we'll split the winnings
  12. #12
    Join Date
    Nov 2000
    Norfolk, VA, USA
    Give him the $1000 for the Camaro then crush the thing.
    One less ugly Chevy polluting the world ;-)
  13. #13
    Join Date
    Feb 2002
    laytonsville MD
    And a 1976 Grand Fury should be run off a cliff !!!
  14. #14
    Join Date
    Jul 2001
    Are you positive it's a 396? When we go to the street races, EVERY big block is a 396! LOL (In which case, we automatically assume it's a 468). With that said, check to see if he has aluminum heads on his "396". The average joe wouldn't waste the money putting aluminum heads on a 396.
    If the car is as you stated "Worked nice" and he will have M/T ET Streets (or M/T Sportsman Pros) then you might want to reconsider. From the surface, the advantage would go to the Maro.
    Just my 2 cents.
  15. #15
    Join Date
    Nov 2000
    Norfolk, VA, USA
    Now Now...that Gran Fury going off of a cliff...would hardly scrath the paint
  16. #16
    Join Date
    Jul 2001
    Lakeland,Fl
    Why would you bet a thousand dollars then ask how to drive your own car? Id think if you were confident enough to bet that kind of money,you should already possess the skill to back it up.Not a flame,just curious. Keep in mind,its all about the tires.He needs to run you on a radial,not a bias ply.
    Joe
  17. #17
    Join Date
    Dec 2001
    <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Marv S:
    Marv, Maybe you and toofast didn't understand. 2500 rpm and slip the clutch all the way out before applying the rest of the throttle. Its good for high 1.70 and 1.80 sixty foots at the track. I guess I don't really know what I am doing though, at VOI I believe I had everyone else in my class covered by two and a half tenths .25 I wish someone would post all the times. He11, send the info to me and I will post it. ta
    edit: This is with stock Michelins.
  18. #18
    UT/AZ
    Marv S's Avatar
    Join Date
    May 1998
    Scottsdale, AZ
    1TONY1, my response was not to you but to Tony aka BACKNBLACK in jest as he asked how to launch "With spinning them". we cool?
    What class, times and et did you run at VOI?
    ........Can anyone tell me how to launch the car with spinning them???
    <HR></BLOCKQUOTE>
  19. #19
    Join Date
    Dec 2001
    No problem here Marv, my bad. Didn't see another Tony. Is he not proud of his name ???? Class....ah ...whichever the bolt on / no power adder street tire class was, modI I think. 11.64 1/4 mile @ 123.?? 7.60 1/8 mile. No roller rockers, headers, high flow cats and exhaust, throttle bodies/filters....just the Venom 500 stuff. sorry, Tony
  20. #20
    Join Date
    Oct 2000
    NJ
    And the results were?
  21. #21
    Join Date
    Oct 2000
    NJ
    Bump
    What were the results?
  22. #22
    Join Date
    Aug 2001
    BACKANDBLACK did you or did you not race the camaro, you asked for help now tell us the results.
  23. #23
    Join Date
    Oct 2000
    NJ
    BUMP
  24. #24
    Join Date
    Jun 2002
    Newberg, (PDX) OR, USA
    <FONT COLOR="Black">How did it go? Did the '68 prevail?</FONT c><FONT COLOR="Red">
    <FONT size="5">Bump</FONT s></FONT c>
  1. Drag racing tips
    By Nich0las in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 02-08-2005, 02:09 AM
  2. Drag racing/tips and techniques
    By Andrew/USPWR in forum RT/10 and GTS Discussions
    Last Post: 10-17-2003, 08:19 AM
  3. Need some drag racing start up tips!!
    By ubnbit in forum RT/10 and GTS Discussions
    Last Post: 12-09-2002, 06:02 PM
  4. Ram kills Gen I Camaro (Dodge street racing ad -- why is this ok?)
    By Venom Lover in forum Sneaky Pete's Place
    Last Post: 10-14-2002, 11:07 AM
  5. Drag Racing tips needed for Saturday......Rookie here
    By HP in forum Viper Racing/Dyno Results/Time Slips
    Last Post: 08-29-2002, 05:30 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
