Thread: Clay Bar step by step
Reply to Thread
Results 1 to 9 of 9
  1. #1
    Join Date
    Mar 2000
    Quantico, VA
    Default Clay Bar step by step
    Can someone please explain how to properly use the Zaino Clay Bar? [I cannot access archives currently, and this morning I used my new clay bar as per the directions given but did not see or feel any results]
    Thank you-
  2. #2
    Join Date
    Oct 2000
    Langhorne, PA USA
    Default Re: Clay Bar step by step
    I used Zaino's #6 to wet a portion of a panel...then glide the clay over. Wipe dry. It will remove al kinds of surface contaminents. You could also mix up a solution of Zaino's car wash with water in a spray bottle. You may want to check the Zaino site as well. zainobros.com.
  3. #3
    Join Date
    Mar 2000
    Quantico, VA
    How wet should the surface be? This morning I mixed the car wash up with water for a solution but it seemed much too wet and soapy...it didn't seem as if the clay bar was having any effect.
  4. #4
    Join Date
    Oct 2000
    San Diego, CA. USA
    Make sure it is real wet. Glide over like everyone says and fold over the clay bar often.
  5. #5
    Join Date
    Feb 2001
    scottsdale, az
    You should use a Wipe and Shine or Quick Detailer to lubricate the surface. Wet the surface with a couple of "squirts" and slide the clay bar back and forth in the wet area with very little force. Wipe it clean. Spray the area once more and wipe to a shine... That should do it!
  6. #6
    Join Date
    Mar 2000
    Quantico, VA
    I just did my hard top as per everyone's suggestions. My verdict: I think they are overrated.
    Maybe I don't have many contaminents to take off???
  7. #7
    Join Date
    Feb 2001
    scottsdale, az
    Clay bars are not over rated, more than likely you don't have a paint issue where a clay bar is required. The ONLY time that a clay bar will work is when you can "feel" these contaminants. If it's on top of the paint and you can feel or hear it as you drag your towel or hand across it, a clay bar is the answer. The only time that I know of that this rule does not apply is when the contaminant is "rail dust". This requires an acid bath, another kind of problem and solution altogether.
  8. #8
    Join Date
    Mar 2000
    Quantico, VA
    Got it; thanks!
  9. #9
    Join Date
    Oct 2000
    Somewhere in southern NJ
    Since I work in a school I was wondering if I took some clay from the art teacher if it woould work as well as Zaino's clay bar? What is nice is that I can get some red clay and use it on the red paint...which may even fill in any chips...
  1. Anyone have a step by step instruction for replacing springs?
    By Inferno in forum RT/10 and GTS Discussions
    Last Post: 12-01-2005, 02:59 PM
  2. Anyone give me a step by step process on how to take cats off?
    By Early93Viper in forum RT/10 and GTS Discussions
    Last Post: 01-25-2005, 08:14 AM
  3. Step by step instructions for replacing flywheel
    By 95Viper in forum RT/10 and GTS Discussions
    Last Post: 06-25-2004, 11:12 AM
  4. Step away for a few hours
    By Chuck 98 RT/10 in forum Sneaky Pete's Place
    Last Post: 10-22-2002, 12:34 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
